查看: 2652|回复: 11
[每日一码] 由弦及弓高获取对应弧模拟点
已领礼包: 1268个
发表于 2014-12-14 12:53:43 | 显示全部楼层 |阅读模式
游客,如果您要查看本帖隐藏内容请回复
按默认弧段 200
_$ (XD::Geom::ChordToArcSamplePoints (getpoint) (getpoint) (getdist))
((35828.0 -7699.33 0.0) (35827.5 -7677.11 0.0) (35827.6 -7654.88 0.0) (35828.5 -7632.67 0.0) (35830.1 -7610.5 0.0) (35832.4 -7588.39 0.0) (35835.5 -7566.37 0.0) (35839.3 -7544.46 0.0) (35843.7 -7522.69 0.0) (35848.9 -7501.07 0.0) (35854.8 -7479.63 0.0) (35861.4 -7458.4 0.0) (35868.6 -7437.39 0.0) (35876.6 -7416.63 0.0) (35885.2 -7396.14 0.0) (35894.5 -7375.94 0.0) (35904.4 -7356.05 0.0) (35915.0 -7336.49 0.0) (35926.2 -7317.29 0.0) (35938.0 -7298.47 0.0) (35950.4 -7280.04 0.0) (35963.5 -7262.02 0.0) (35977.1 -7244.44 0.0) (35991.2 -7227.31 0.0) (36005.9 -7210.65 0.0) (36021.2 -7194.47 0.0) (36037.0 -7178.81 0.0) (36053.2 -7163.66 0.0) (36070.0 -7149.05 0.0) (36087.2 -7134.99 0.0) (36104.9 -7121.51 0.0) (36123.0 -7108.6 0.0) (36141.5 -7096.29 0.0) (36160.4 -7084.59 0.0) (36179.7 -7073.51 0.0) (36199.3 -7063.07 0.0) (36219.2 -7053.26 0.0) (36239.5 -7044.12 0.0) (36260.0 -7035.63 0.0) (36280.9 -7027.82 0.0) (36301.9 -7020.69 0.0) (36323.2 -7014.25 0.0) (36344.7 -7008.51 0.0) (36366.3 -7003.47 0.0) (36388.1 -6999.13 0.0) (36410.1 -6995.51 0.0) (36432.1 -6992.6 0.0) (36454.2 -6990.42 0.0) (36476.4 -6988.95 0.0) (36498.6 -6988.21 0.0) (36520.8 -6988.19 0.0) (36543.1 -6988.89 0.0) (36565.2 -6990.31 0.0) (36587.4 -6992.46 0.0) (36609.4 -6995.33 0.0) (36631.4 -6998.91 0.0))
_$
绘制矢量弧
_$ (apply 'xdrx_grdraw (cons 1 (cons 1 (XD::Geom::ChordToArcSamplePoints (getpoint) (getpoint) (getdist)))))
T
_$
负距离为另一方向弧
_$ (apply 'xdrx_grdraw (cons 1 (cons 1 (XD::Geom::ChordToArcSamplePoints (getpoint) (getpoint) (- (getdist))))))
T
_$
forum.php?mod=attachment&aid=MTIwODB8YzViNGY4NWV8MTQxODUzMjk3MnwxMDEwOHw2NzgwNTM%3D&noupdate=yes.gif
已领礼包: 604个
发表于 2014-12-14 13:14:18 来自手机 | 显示全部楼层
按弧弓比取点,是不是看起来不精确,按度数取
已领礼包: 1268个
 楼主| 发表于 2014-12-14 13:19:38 | 显示全部楼层
主要用于动态绘制
发表于 2014-12-14 14:42:11 | 显示全部楼层
是不是用GE库实现的?
发表于 2014-12-14 14:51:09 | 显示全部楼层
继续每日回帖
发表于 2014-12-14 14:51:11 | 显示全部楼层
感觉可以写个做云线的命令?
已领礼包: 1268个
 楼主| 发表于 2014-12-14 15:16:44 来自手机 | 显示全部楼层
newer 发表于 2014-12-14 14:42
是不是用GE库实现的?
这个是用的Ge库,用xdrx_geom_3p2arc加一些判断也可以
已领礼包: 8644个
发表于 2014-12-14 15:30:58 | 显示全部楼层
这个强大,学习学习
已领礼包: 1268个
 楼主| 发表于 2014-12-14 16:01:01 | 显示全部楼层
Lisphk 发表于 2014-12-14 14:51
感觉可以写个做云线的命令?
这样?
已领礼包: 6468个
发表于 2014-12-25 17:34:25 | 显示全部楼层
看看。
已领礼包: 174个
发表于 2018-12-24 11:38:23 | 显示全部楼层
来学习一下
已领礼包: 216个
发表于 2020-1-15 17:15:51 | 显示全部楼层
继续每日回帖
GMT+8, 2026-11-4 08:15 , Processed in 0.656237 second(s), 60 queries , Gzip On.
