查看: 6521|回复: 22
[每日一码] 通过AutoLISP获得图形的 summary info 的代码
发表于 2014-12-14 15:16:06 | 显示全部楼层 |阅读模式
How to extract the drawing summary info using AutoLISP?
Question
I added drawing properties (summary info) to some drawings using the DWGPROPS
command. How do I extract this information using AutoLISP?
Answer
The summary information is stored in a dictionary called "DWGPROPS".
The first thing you need to do is test if the drawing contains the DWGPROPS
dictionary.
If the dictionary does not exist, the summary information is not stored in the
drawing.
If this dictionary exists, you need to obtain it so that you can extract the
group codes you want from fields in the DWGPROPS dialog.
The following lists the used group codes:
2        Title
3        Subject
4        Author
6        Comments
7        Keywords
1        Hyperlink
8        Last saved by
9        Revision
40        Editing time
41        Creation time
42        Last modified time
90        Number of custom properties
300-
309        Custom properties
NOTE: Group code 1 is used two times in the dictionary. The Hyperlink is stored
in the second one. The time values are specified in the Julian date/time format.
Look at the Julian.lsp file  in AutoCAD to see how to convert this format into a
'readable' format.
The following AutoLISP function extracts the summary information from the
current drawing (it does not convert the time values):
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 604个
发表于 2014-12-14 15:51:24 来自手机 | 显示全部楼层
这个信息倒是少有人去动它
发表于 2014-12-14 16:24:37 | 显示全部楼层
$ (dump (fy:SecurityParams) t)
; IAcadSecurityParams: 安全参数接口
;特性值:
;   Action = 0
;   Algorithm = 0
;   Comment = ""
;   Issuer = ""
;   KeyLength = 0
;   Password = ""
;   ProviderName = ""
;   ProviderType = 0
;   SerialNumber = ""
;   Subject = ""
;   TimeServer = ""
;无方法
T
_$
发表于 2014-12-14 17:19:55 | 显示全部楼层
太深,纯顶涮分
已领礼包: 590个
发表于 2014-12-14 19:02:38 | 显示全部楼层
第一次接触
发表于 2014-12-14 19:04:47 | 显示全部楼层
俺也看看,学习。
已领礼包: 1268个
发表于 2014-12-14 19:30:13 | 显示全部楼层
vla方法,设置和获取
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 264个
发表于 2014-12-14 20:45:49 来自手机 | 显示全部楼层
Document.comments
已领礼包: 4044个
发表于 2014-12-15 07:47:50 | 显示全部楼层
回复学习学习!:lol
已领礼包: 2965个
财富等级: 家财万贯
发表于 2014-12-15 09:47:24 | 显示全部楼层
不错不错,学习学习
发表于 2014-12-15 20:35:23 | 显示全部楼层
不错,值得一看。
已领礼包: 6468个
发表于 2014-12-25 17:48:29 | 显示全部楼层
看看
已领礼包: 329个
发表于 2014-12-26 12:05:51 | 显示全部楼层
学习..............
已领礼包: 376个
发表于 2016-10-21 14:26:46 | 显示全部楼层
学习学习学习学习学习学习
发表于 2017-7-27 18:38:38 | 显示全部楼层
谢谢,收获不小,谢谢了。
GMT+8, 2026-11-3 00:37 , Processed in 0.546556 second(s), 57 queries , Gzip On.
