查看: 2312|回复: 4
[每日一码] Example Add Method
已领礼包: 1268个
发表于 2014-12-14 19:36:18 | 显示全部楼层 |阅读模式
  1. (vl-load-com)
  2. (defun c:Example_Add()
  3.     ;; This example adds a block, dictionary, dimension style,
  4.     ;; group, layer, registered application, selection set,
  5.     ;; textstyle, view, viewport and UCS using the Add method.
  6.     (setq acadObj (vlax-get-acad-object))
  7.     (setq doc (vla-get-ActiveDocument acadObj))
  8.
  9. ;; ADDBLOCK:
  10.     ;; Create a new block called "New_Block"
  11.     ;; Define the insertion point
  12.     (setq insertionPnt (vlax-3d-point 0 0 0))
  13.
  14.     ;; Add the block to the blocks collection
  15.     (setq blocks (vla-get-Blocks doc))
  16.     (setq blockObj (vla-Add blocks insertionPnt "New_Block"))
  17.     (alert (strcat (vla-get-Name blockObj) " has been added."
  18.                     "\nOrigin: " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin blockObj)) 0) 2 2) ", "
  19.                                  (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin blockObj)) 1) 2 2) ", "
  20.                                  (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin blockObj)) 2) 2 2)
  21.            )
  22.     )
  23.
  24. ;; ADDDICTIONARY:
  25.     ;; Create a new dictionary called "New_Dictionary"
  26.     ;; Add the dictionary to the dictionaries collection
  27.     (setq dictionaries (vla-get-Dictionaries doc))
  28.     (setq dictObj (vla-Add dictionaries "New_Dictionary"))
  29.     (alert (strcat (vla-get-Name dictObj) " has been added."))
  30. ;; ADDDIMSTYLE:
  31.     ;; Create a new dimension style called "New_Dimstyle" in current drawing
  32.
  33.     ;; Add the dimstyle to the dimstyles collection
  34.     (setq dimStyles (vla-get-DimStyles doc))
  35.     (setq dimStyleObj (vla-Add dimStyles "New_Dimstyle"))
  36.     (alert (strcat (vla-get-Name dimStyleObj) " has been added."))
  37.
  38. ;; ADDGROUP:
  39.     ;; Create a new group called "New_Group" in current drawing
  40.
  41.     ;; Add the group to the groups collection
  42.     (setq groups (vla-get-Groups doc))
  43.     (setq groupObj (vla-Add dimStyles "New_Group"))
  44.     (alert (strcat (vla-get-Name groupObj) " has been added."))
  45.
  46. ;; ADDLAYER:
  47.     ;; This example creates a new layer called "New_Layer"
  48.
  49.     ;; Add the layer to the layers collection
  50.     (setq layers (vla-get-Layers doc))
  51.     (setq layerObj (vla-Add layers "New_Layer"))
  52.
  53.     ;; Make the new layer the active layer for the drawing
  54.     (vla-put-ActiveLayer doc layerObj)
  55.
  56.     ;; Display the status of the new layer
  57.     (alert (strcat (vla-get-Name layerObj) " has been added."
  58.                    "\nLayerOn Status: " (if (= (vla-get-LayerOn layerObj) :vlax-true) "1" "0")
  59.                    "\nFreeze Status: " (if (= (vla-get-Freeze layerObj) :vlax-true) "1" "0")
  60.                    "\nLock Status: "  (if (= (vla-get-Lock layerObj) :vlax-true) "1" "0")
  61.                    "\nColor: " (itoa (vla-get-Color layerObj))
  62.            )
  63.     )
  64.
  65. ;; ADDREGISTEREDAPP:
  66.     ;; Create a registered application named "New_RegApp" in current drawing
  67.
  68.     ;; Add the registered application to the registered applications collection
  69.     (setq regApps (vla-get-RegisteredApplications doc))
  70.     (setq regAppObj (vla-Add regApps "New_RegApp"))
  71.     (alert (strcat (vla-get-Name regAppObj) " has been added."))
  72. ;; ADDSELECTIONSET:
  73.     ;; Create a selectionset named "New_SelectionSet" in current drawing
  74.
  75.     ;; Add the selection set to the selection sets collection
  76.     (setq ssets (vla-get-SelectionSets doc))
  77.     (setq ssetObj (vla-Add ssets "New_SelectionSet"))
  78.     (alert (strcat (vla-get-Name ssetObj) " has been added."
  79.                     "\nThe number of items in the selection set is " (itoa (vla-get-Count ssetObj))
  80.            )
  81.     )
  82.
  83. ;; ADDTEXTSTYLE:
  84.     ;; Create a textstyle named "New_Textstyle" in current drawing
  85.
  86.     ;; Add the textstyle to the textstyles collection
  87.     (setq textStyles (vla-get-TextStyles doc))
  88.     (setq txtStyleObj (vla-Add textStyles "New_Textstyle"))
  89.     (alert (strcat (vla-get-Name txtStyleObj) " has been added."
  90.                     "\nHeight: " (rtos (vla-get-Height txtStyleObj) 2 2)
  91.                     "\nWidth: " (rtos (vla-get-Width txtStyleObj) 2 2)
  92.            )
  93.     )
  94.
  95. ;; ADDVIEW:
  96.     ;; Create a view named "New_View" in current drawing
  97.
  98.     ;; Add the view to the views collection
  99.     (setq views (vla-get-Views doc))
  100.     (setq viewObj (vla-Add views "New_View"))
  101.     (alert (strcat (vla-get-Name viewObj) " has been added."
  102.                     "\nHeight: " (rtos (vla-get-Height viewObj) 2 2)
  103.                     "\nWidth: " (rtos (vla-get-Width viewObj) 2 2)
  104.            )
  105.     )
  106.
  107. ;; ADDVIEWPORT:
  108.     ;; Create a viewport named "New_Viewport" in current drawing
  109.
  110.     ;; Add the viewport to the viewports collection
  111.     (setq viewports (vla-get-Viewports doc))
  112.     (setq vportObj (vla-Add viewports "New_Viewport"))
  113.     (alert (strcat (vla-get-Name vportObj) " has been added."
  114.                     "\nGridOn Status: " (if (= (vla-get-GridOn vportObj) :vlax-true) "1" "0")
  115.                     "\nOrthoOn Status: " (if (= (vla-get-OrthoOn vportObj) :vlax-true) "1" "0")
  116.                     "\nSnapOn Status: " (if (= (vla-get-SnapOn vportObj) :vlax-true) "1" "0")
  117.            )
  118.     )
  119.
  120. ;; ADDUCS:
  121.     ;; Create a UCS named "New_UCS" in current drawing
  122.
  123.     ;; Define the UCS
  124.     (setq origin (vlax-3d-point 4 5 3)
  125.           xAxisPnt (vlax-3d-point 5 5 3)
  126.           yAxisPnt (vlax-3d-point 4 6 4))
  127.
  128.     ;; Add the UCS to the UserCoordinatesSystems collection
  129.     (setq UCSs (vla-get-UserCoordinateSystems doc))
  130.     (setq ucsObj (vla-Add UCSs origin xAxisPnt yAxisPnt "New_UCS"))
  131.     (alert (strcat (vla-get-Name ucsObj) " has been added."
  132.                     "\nOrigin: " (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 0) 2 2) ", "
  133.                                  (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 1) 2 2) ", "
  134.                                  (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-Origin ucsObj)) 2) 2 2)
  135.            )
  136.     )
  137. ;; ADDMATERIAL:
  138.     ;; Creates a material named "New_UCS" in the current drawing
  139.     (setq oMaterials (vla-get-Materials doc))
  140.     (setq oMaterial (vla-Add oMaterials "TestMaterial"))
  141.     (vla-put-Description oMaterial "This example demonstrates how to add a material to a database.")
  142.     (vla-put-ActiveMaterial doc oMaterial)
  143.     ;; Display information about the material
  144.     (alert (strcat (vla-get-Name oMaterial) " has been added."
  145.                     "\nName: " (vla-get-Name oMaterial)
  146.                     "\nDescription: " (vla-get-Description oMaterial)
  147.            )
  148.     )
  149. )
已领礼包: 604个
发表于 2014-12-14 19:50:06 来自手机 | 显示全部楼层
向楼主学习
发表于 2014-12-14 20:12:20 | 显示全部楼层
今天热闹,停不下来的节奏。
已领礼包: 6468个
发表于 2014-12-25 17:47:38 | 显示全部楼层
第一个不用回复的每日一码。
已领礼包: 1094个
发表于 2021-8-3 00:22:32 | 显示全部楼层
感谢楼主分享Example Add Method
GMT+8, 2026-11-3 08:28 , Processed in 0.568489 second(s), 37 queries , Gzip On.
