查看: 15724|回复: 73
[每日一码] 编程创建文字样式(带truetype字体)
 火 [复制链接]
发表于 2014-12-20 13:31:58 | 显示全部楼层 |阅读模式
How to programmatically create a new text style (with truetype fonts)
Question
When I create new text styles based on truetype fonts, how do I know which fonts
are available?  When I type certain font names as they are listed in the STYLE
dialog box, AutoCAD tells me that the font name does not exist.
Using Visual LISP, how do I create a new style without using (command "style"
new-style full-style-name "" "" "" "" "" "") ?
Answer
It seems that with some fonts, mostly Swiss and Dutch, the font name is abbreviated
in AutoCAD's STYLE dialog.  Some of the common abbreviations used are:
Bd = Bold
Blk = Black
Cn = Condensed
Ex = Extended
It = Italic
Out = Outline
Rm = Roman
Xbd = Extra Bold
For example:
Swis721 BlkEx BT  would be written as  Swiss 721 Black Extended BT
Swis721 BdCnOut BT  would be written as  Swiss 721 Bold Condensed Outline BT
Dutch801 Rm BT  would be written as  Dutch 801 Roman BT
Dutch801 Xbd BT  would be written as  Dutch 801 Extra Bold BT
Note: Using Windows Explorer, you can see the actual spelling of the font names,
in theFonts directory (ex: C:\WINNT\Fonts).
There are two lisp approaches to create a new style, without using (command
"style"...etc), but you will need the name of the actual .ttf file to do so.
Again, Windows' Fonts directory lists the font names and the related .ttf filename.
For example: Swiss 721 Bold Condensed Outline BT is found in the file swisscbo.ttf.
With this information, we can proceed to entmake a new text style.  First,
the old AutoLISP approach, using entmake:
游客,如果您要查看本帖隐藏内容请回复
In either case, the resulting style "myNewStyle" will utilize the desired font.
已领礼包: 3199个
发表于 2014-12-20 13:34:47 | 显示全部楼层
N版,你这是想将今年的全部发完啊
已领礼包: 2965个
财富等级: 家财万贯
发表于 2014-12-20 14:07:10 | 显示全部楼层
谢谢分享!!
已领礼包: 5800个
发表于 2014-12-20 14:48:03 | 显示全部楼层
顶顶顶,N版加油!
发表于 2014-12-20 15:22:05 | 显示全部楼层
只有“顶”字了
已领礼包: 343个
发表于 2014-12-21 00:46:21 | 显示全部楼层
已领礼包: 2476个
发表于 2014-12-21 13:11:31 | 显示全部楼层
学习..............
已领礼包: 264个
发表于 2014-12-21 18:57:43 来自手机 | 显示全部楼层
不一定有ttf,只有ttc
那你是怎么办的呀?  详情 回复 发表于 2014-12-31 10:07
已领礼包: 2874个
财富等级: 家财万贯
发表于 2014-12-22 14:22:00 | 显示全部楼层
今年喜事特别多:)
已领礼包: 329个
发表于 2014-12-22 17:20:43 | 显示全部楼层
学习学习。。。。。。。。。。。
发表于 2014-12-25 14:24:32 | 显示全部楼层
谢谢分享~~~~
已领礼包: 604个
发表于 2014-12-31 10:07:30 | 显示全部楼层
iLisp 发表于 2014-12-21 18:57
不一定有ttf,只有ttc
那你是怎么办的呀?
已领礼包: 1268个
发表于 2014-12-31 10:09:17 | 显示全部楼层
command
发表于 2015-1-5 11:09:36 | 显示全部楼层
鸟文看得有点头大
已领礼包: 196个
发表于 2015-1-5 13:01:54 | 显示全部楼层
不会 来学习 谢谢
GMT+8, 2026-11-3 01:51 , Processed in 0.584872 second(s), 60 queries , Gzip On.
