查看: 1403|回复: 4
[LISP程序]:有没有提取最大数字的程序
发表于 2003-7-2 19:26:05 | 显示全部楼层 |阅读模式
问题:如何从  12-9-5 中提取出12这个数字(最大的一个)并用这个最大值替换整个字符窜?
已领礼包: 145个
发表于 2003-7-2 19:31:32 | 显示全部楼层
Re: [LISP程序]:有没有提取最大数字的程序
最初由 cadking 发布
[B]问题:如何从  12-9-5 中提取出12这个数字(最大的一个)并用这个最大值替换整个字符窜? [/B]
下面使用了XDRX_API函数,请加载XDRX_API后使用。
  1. [font=courier]
  2. (setq str "12-9-5")
  3. (setq mstr (xdrx_string_tok str "-"))
  4. (setq maxstr (itoa (apply 'max (mapcar 'atoi mstr))))
  5. [/font]
测试:
  1. [font=courier]
  2. 命令: (setq a (xdrx_string_tok "12-9-5" "-"))
  3. ("12" "9" "5")
  4. 命令: (setq b (mapcar 'atoi a))
  5. (12 9 5)
  6. 命令: (setq c (apply 'max b))
  7. 12
  8. [/font]
发表于 2003-7-14 10:15:49 | 显示全部楼层
  1. 我想你的函数基本上与xdrx_string_tok有些不用
  2.      (xdrx_string_tok "abc;;def;;ef;g;" ";;")=("abc" "def" "ef" "g")
  3.           (xdrx_string_tok "abc;;def;;ef;g;" ";") =("abc" "def" "ef" "g")
  4.           (xdrx_string_tok "abcddefgddzdf" "d") =("abc" "efg" "z" "f")
  5.           (xdrx_string_tok "abcddefgddzdf" "dd") =("abc" "efg" "z" "f")
  6.           (xdrx_string_tok ",1,2" ",")=("1" "2")
  7.           (xdrx_string_tok ",1,2,,,3," ",")=("1" "2" "3")
  8.           (SPLIT "abc;;def;;ef;g;" ";;")=("abc" "def" "ef;g;")
  9.           (SPLIT "abc;;def;;ef;g;" ";") =("abc" "" "def" "" "ef" "g" "")
  10.           (SPLIT "abcddefgddzdf" "d") =("abc" "" "efg" "" "z" "f")
  11.           (SPLIT "abcddefgddzdf" "dd")=("abc" "efg" "zdf")
  12.           (SPLIT ",1,2" ",")=("" "1" "2")
  13.           (SPLIT ",1,2,,,3," ",")=("" "1" "2" "" "" "3" "")
  14. ;;BY LUCAS
  15. ;;USAGE:(TT "1;12-9-5" ";-")
  16. ;;功能同xdrx_string_tok
  17. (defun TT (STR FG / STR1 LL WW N)
  18.   (setq        N 1
  19.         STR1 ""
  20.   )
  21.   (repeat (strlen STR)
  22.     (if        (wcmatch FG (strcat "*" (setq WW (substr STR N 1)) "*"))
  23.       (progn
  24.         (if (/= STR1 "")
  25.           (setq LL (append LL (list STR1)))
  26.         )
  27.         (setq STR1 "")
  28.       )
  29.       (setq STR1 (strcat STR1 WW))
  30.     )
  31.     (setq N (1+ N))
  32.   )
  33.   (if (/= STR1 "")
  34.     (setq LL (append LL (list STR1)))
  35.   )
  36.   LL
  37. )
发表于 2003-7-14 13:10:31 | 显示全部楼层
不用那么复杂吧?下面简单的程序码就能解决问题,还无需调用XDRX_API函数:
(setq a (vl-string-translate "-" " " "12-5-9"))
(setq b (apply 'max (eval (read (strcat "'(" a ")")))))
发表于 2005-2-17 23:27:57 | 显示全部楼层
能增加数字的数量统计吗
GMT+8, 2026-11-3 07:42 , Processed in 0.493844 second(s), 38 queries , Gzip On.
