查看: 1383|回复: 0
[分享] Quick way to find number of entities in modelspace
已领礼包: 859个
发表于 2015-1-13 20:38:06 | 显示全部楼层 |阅读模式
Quick way to find number of entities in modelspace                         By Balaji Ramamoorthy
LINQ provides an easy way to find the number of entities in modelspace without having to iterate on our own. The IEnumerator exposed by BlockTableRecord can be cast as IEnumerable<ObjectId> to find the count. Here is a code snippet :
using  System.Linq;
Document doc  =  Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
using  (Transaction tr   = db.TransactionManager.StartTransaction())
     BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
      ObjectId modelSpaceId  = SymbolUtilityServices.GetBlockModelSpaceId(db);
      BlockTableRecord btr = tr.GetObject(modelSpaceId,  OpenMode.ForRead) as BlockTableRecord;
      System.Collections.Generic.IEnumerable<ObjectId>   idCollection = btr.Cast<ObjectId>();
      doc.Editor.WriteMessage(
                 String.Format("{0} Model space count : {1}" ,
                 Environment.NewLine, idCollection.Count<ObjectId>()));
      tr.Commit();
GMT+8, 2026-11-3 06:12 , Processed in 0.750469 second(s), 28 queries , Gzip On.
