查看: 2012|回复: 3
[分享] 求n以内素数的递归算法及筛法
发表于 2015-1-22 20:41:38 | 显示全部楼层 |阅读模式
;;;递归算法
(defun f (n)
     (if (= n 2)
         (setq va (list 2))
         (if (= n 3)
             (setq va (list 3 2))
             (if (= n 4)
                (if (= n 5)
                    (setq va (list 5 3 2))
                    (if (= (apply '* (mapcar '(lambda (x) (rem n x)) (f (fix (sqrt n))))) 0)
                       (if (> (rem n 6) 1)
                          (setq va (f (- n -1 (rem n 6))))
                          (setq va (f (- n 1 (rem n 6))))
                       (if (= (rem n 6) 5)
                         (setq va (cons n (f (- n -1 (rem n 6)))))
                         (setq va (cons n (f (- n 1 (rem n 6)))))
  va
(reverse (f 10000))
;;;筛法
(defun f (n)
   (setq i 3 lst nil)
   (while (<= i n)
          (setq lst (cons i lst))
          (setq i (+ i 2))
  (setq llst (cons (list 2) (reverse lst)))
  (while (and (< (car (car llst)) (sqrt n) )   (< (cadr llst) (sqrt n))   )
        (setq flst (cons (cadr llst) (car llst)))
        (setq plst (vl-remove-if '(lambda (x) (= (rem x (car flst)) 0)) (cdr llst)))
        (setq llst (cons flst plst))
  (setq alst (car llst) blst (cdr llst))
  (mapcar '(lambda (e) (setq blst (cons e blst))) alst)
   blst
(f 10000)
发表于 2015-4-27 13:27:17 | 显示全部楼层
收藏一下,多谢分享
发表于 2015-10-21 20:31:26 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2015-10-21 20:59:26 | 显示全部楼层
;;;上面的筛法有点复杂,没优化
;;;下面这个好理解
(defun f (n)
  (setq i 3 lst nil)
  (while (<= i n)
          (setq i (+ i 2))
  (setq llst (cons 2 (reverse lst)))
  (setq flst nil)
  (while (and (/= (cdr llst) nil) (/= (setq c (nth 0 llst)) nil))
       (setq flst (cons c flst))
       (setq llst (vl-remove-if '(lambda (x) (= (rem x c) 0)) (cdr llst)))
  (reverse flst)
GMT+8, 2026-11-22 09:57 , Processed in 0.269831 second(s), 19 queries , Gzip On, File On.
