查看: 1440|回复: 0
[每日一码] 获取/修改 MLeader 文本
已领礼包: 859个
发表于 2015-2-2 10:17:08 | 显示全部楼层 |阅读模式
  1.         private static string MleaderTextString(MLeader mLeader)
  2.         {
  3.             var mtext = mLeader.MText;
  4.             var str = mtext.Text;
  5.             return str;
  6.         }
  7.         private static object MleaderTextString(MLeader mLeader, string str)
  8.         {
  9.             var mtext = mLeader.MText;
  10.             mtext.Contents = str;
  11.             mLeader.MText = mtext;
  12.             return true;
  13.         }
GMT+8, 2026-11-3 01:43 , Processed in 0.496752 second(s), 28 queries , Gzip On.
