查看: 1297|回复: 1
[教学] Convert 3dpoly to Lwpolyline
发表于 2015-4-30 08:23:06 | 显示全部楼层 |阅读模式
  1. (defun polyline->lwpolyline (pl / lst p nl h l tf)
  2.   (setq        l  (entget pl)
  3.         tf (vlax-curve-isclosed pl)
  4.   )
  5.   (while (and (setq pl (entnext pl))
  6.               (setq lst (entget pl))
  7.               (= (cdr (assoc 0 lst)) "VERTEX")
  8.          )
  9.     (setq p  (cdr (assoc 10 lst))
  10.           h  (caddr p)
  11.           nl (cons (list 10 (car p) (cadr p)) nl)
  12.     )
  13.   )
  14.   (entmakex (append (list '(0 . "LWPOLYLINE")
  15.                           '(100 . "AcDbEntity")
  16.                           '(100 . "AcDbPolyline")
  17.                           (cons        70
  18.                                 (if tf
  19.                                   1
  20.                                   0
  21.                                 )
  22.                           )
  23.                           (cons 90 (length nl))
  24.                           (assoc 8 l)
  25.                           (cons 38 h)
  26.                     )
  27.                     (reverse nl)
  28.             )
  29.   )
  30. )
已领礼包: 3199个
发表于 2015-4-30 09:26:30 | 显示全部楼层
谢谢大师分享!
GMT+8, 2026-11-6 05:15 , Processed in 0.361938 second(s), 31 queries , Gzip On.
