查看: 1496|回复: 0
[求助] 尺寸对齐程序,求修改
发表于 2015-5-19 19:47:17 | 显示全部楼层 |阅读模式
下面这个程序怎么按照全局比例调整对齐坐标,比如全局比例是12那么我对齐的尺寸不需要人工计算12*7,我只要永远输入7那么标注之间间隔就是全局比例*7,求大神修改,在线等!!!
;; DA标注对齐
;(princ "\n*** 程序运行:da 可以自动对齐标注线、引出点、标注文字。 ***")
(defun fun_begin()
        (setq
                osmode_old (getvar "osmode")
                cmdecho_old (getvar "cmdecho")
        (setvar "cmdecho" 0)
        (command "undo" "be")
(defun fun_end()
        (setvar "osmode" osmode_old)
        (setvar "cmdecho" cmdecho_old)
        (command "undo" "e")
(defun c:da ( / ang dot10 dot10other dot11 dot13 dot13new dot14 dot14new dotwznew entdim entdims entname index numdim ptbz ptbzother ptwz ptyq ssdim value70)
        (fun_begin)
        (princ "\n选择需要改变的标注:")
        (setq ssdim (ssget '((0 . "DIMENSION"))))
        (if ssdim
                (progn
                        (setq
                                entdim (entget (ssname ssdim 0))
                                numdim (sslength ssdim)
                        (if (member '(100 . "AcDbRotatedDimension") entdim)
                                (setq ang (cdr (assoc 50 entdim)))
                                (setq        dot13 (cdr (assoc 13 entdim))
                                                         dot14 (cdr (assoc 14 entdim))
                                                         ang (angle dot13 dot14)
;对齐标注线
        (setq ptbz (getpoint "\n选择标注线位置:"))
        (if ptbz
                (progn
                        (setq ptbzother (polar ptbz ang 100)
                                                index 0
                        (while (< index numdim)
                                (setq entname (ssname ssdim index)
                                                        entdims (entget entname)
                                                        dot10 (cdr (assoc 10 entdims))
                                                        dot10new (inters
        ptbz
        ptbzother
        dot10
        (polar dot10 (+ (* 0.5 pi) ang) 100)
        nil
                                                        index (1+ index)
                                (setq
                                        entdims (subst (cons 10 dot10new) (assoc 10 entdims) entdims)
                                (entmod entdims)
;对齐引出线
        (setq ptyq (getpoint "\n选择引出线位置:"))
        (if ptyq
                (progn
                        (setq index 0)
                                                        dot13 (cdr (assoc 13 entdims))
                                                        dot14 (cdr (assoc 14 entdims))
                                                        dot14new (inters
        ptyq
        (polar ptyq ang 100)
        dot14
        dot10
        nil
                                                        index (1+ index)
                                (if (member '(100 . "AcDbRotatedDimension") entdims)
                                        (setq dot13new (inters
        ptyq
        dot13
        (polar dot13 (angle dot14 dot10) 100)
        nil
                                        (setq dot13new (polar dot14new (angle dot14 dot13) (distance dot14 dot13)))
                                (setq
                                        entdims (subst (cons 14 dot14new) (assoc 14 entdims) entdims)
                                        entdims (subst (cons 13 dot13new) (assoc 13 entdims) entdims)
                                (entmod entdims)
;对齐标注文字
        (initget "R")
        (setq ptwz (getpoint "\n选择标注文字位置或仅自定义(R):"))
        (if ptwz
                (progn
                        (if (and (= (type ptwz) 'STR) (= (strcase ptwz nil) "R"))
                                (setq
                                        ptwz (getpoint "\n选择自定义标注文字位置:")
                                        user_only T
                        (if (= ptwz nil) (exit))
                        (setq index 0)
                                (setq
                                        dot11 (cdr (assoc 11 entdims))
                                        value70 (cdr (assoc 70 entdims))
                                        value70new (if (<= value70 128) (+ value70 128) value70)
                                        dotwznew
                                                (inters
                                                        ptwz
                                                        (polar ptwz ang 100)
                                                        dot11
                                                        (polar dot11 (+ (* 0.5 pi) ang) 100)
                                                        nil
                                        entdims (subst (cons 11 dotwznew) (assoc 11 entdims) entdims)
                                        index (1+ index)
                                (if (= user_only nil)
                                        (setq entdims (subst (cons 70 value70new) (assoc 70 entdims) entdims))
                                (entmod entdims)
        (fun_end)
GMT+8, 2026-11-6 07:02 , Processed in 0.508130 second(s), 29 queries , Gzip On.
