查看: 1735|回复: 2
[求助] 求助相同的重叠文字和字符窜变色的LSP
发表于 2015-6-12 18:03:33 | 显示全部楼层 |阅读模式
求助重叠的文字和字符窜,当文字和字符窜重叠相同时,让这样重叠相同的字和字符串变色变色的LSP,(如PKPM计算书中的字符窜),麻烦哪位朋友有这样的LSP,或请高手编写一个
 楼主| 发表于 2015-6-14 12:51:40 | 显示全部楼层
下面是个LSP源码,是否可以按这个思路改下,由于本人不懂,所以请请高手编写一个重叠相同的字和字符串变色变色的LSP,万分感谢
(defun c:max (/              ss      ename   i%      ent     string  maxlist1
              x              y              h              ss1     ename1  string1 maxlist2
              n%      str1    str2    str3    newstr
  (command "_.undo" "begin")
  (command "_.color" "")
  (setq dimzin0 (getvar "dimzin"))
  (setq        ss (ssget (list        (cons 0 "TEXT")
                        (cons 62 5)
  (setq i% 0)
  (while (setq ename (ssname ss i%))
    (setq ent         (entget ename)
          string (cdr (assoc 1 ent))
    (setq maxlist1 (string->maxlist string))
    (setq x (cadr (assoc 10 ent))
          y (caddr (assoc 10 ent))
          h (/ (cdr (assoc 40 ent)) 2)
    (setq ss1 (ssget "X"
                     (list
                       (cons -4 "<AND")
                       (assoc 0 ent)
                       (assoc 50 ent)
                       (cons -4 "<NOT")
                       (cons 62 5)
                       (cons -4 "NOT>")
                       (cons -4 ">=,>=,*")
                       (list 10 (- x h) (- y h) 0)
                       (cons -4 "<=,<=,*")
                       (list 10 (+ x h) (+ y h) 0)
                       (cons -4 "AND>")
    (setq n% 0)
    (while (setq ename1 (ssname ss1 n%))
      (setq string1 (cdr (assoc 1 (entget ename1))))
      (setq maxlist2 (string->maxlist string1))
      (setq maxlist1 (mapcar 'max maxlist1 maxlist2))
      (entdel ename1)
      (setq n% (1+ n%))
    (setvar "dimzin" 8)
    (setq str1 (rtos (car maxlist1) 2 2))
    (if        (cadr maxlist1)
      (setq str2 (rtos (cadr maxlist1) 2 2))
    (if        (caddr maxlist1)
      (setq str3 (rtos (caddr maxlist1) 2 2))
    (cond ((wcmatch string "*-*-*")
           (setq newstr (strcat str1 "=" str2 "=" str3))
          (t
           (setq newstr str1)
    (setq ent (subst (cons 1 newstr) (assoc 1 ent) ent))
    (entmod ent)
    (setq i% (1+ i%))
  (setvar "dimzin" dimzin0)
  (command "_.undo" "end")
(defun string->maxlist
       (string / n str Posit1 posit2 str1 str2 str3 maxlist)
  (setq n 1)
  (while (if (wcmatch (substr string n 1) "@")
           (setq n (1+ n))
  (if (setq posit1 (vl-string-position (ascii "-") string))
    (progn
      (setq str1 (atof (substr string n  Posit1))
            str         (substr string (+ Posit1 2))
      (if (setq posit2 (vl-string-position (ascii "-") str))
        (setq str2 (atof (substr str 1 Posit2 ))
              str3 (atof (substr str (+ Posit2 2)))
        (setq str2 (atof str))
    ;无"-"
    (setq str1 (atof (substr string n)))
  (foreach i (list str3 str2 str1) (if i (setq maxlist (cons i maxlist))))
 楼主| 发表于 2015-6-14 12:54:58 | 显示全部楼层
下面是个选相同的字改粉色源码,是否可以把上面这两源码,按这2个思路改下,由于本人不懂,所以请高手编写一个重叠相同的字和字符串变色变色的LSP,万分感谢
(defun c:gt1(/ sstext text_sn cpl i)
(setq sstext (ssget '((0 . "text"))))
(if sstext
(progn
(setq i 0)
(repeat (sslength sstext)
(setq text_sn (ssname sstext i)
      plst (LM:GetTextBox text_sn 0)
      cpl (ssget "CP" plst '((0 . "text")))
(if (> (sslength cpl) 1)
(vla-put-color (vlax-ename->vla-object text_sn) 6)
(setq i (1+ i))
GMT+8, 2026-11-6 02:39 , Processed in 0.582305 second(s), 33 queries , Gzip On.
