查看: 1574|回复: 0
[分享] Retrieving entity properties using AccoreConsole
已领礼包: 859个
发表于 2015-7-22 18:56:38 | 显示全部楼层 |阅读模式
Retrieving entity properties using AccoreConsoleBy Balaji Ramamoorthy
The "dumpallproperties" is an easy way to list all the properties of an entity using Lisp. Unfortunately, this does not work when used in the script file along with AccoreConsole. A ** way to workaround this and display the entity properties in AccoreConsole, is to create a CRX plugin that uses the Non-COM property system to display the entity properties.
If you are new to the Non-COM property system, please refer to this blog post : DevTV : Non-COM Property System
The code in this blog post uses portions of the code from that DevTV in a CRX application. Here is the relevant code and the complete sample project can be downloaded here :
Download EntProps_CRX
static  void  ListEntityProperties(void ) {         TCHAR entityHandle[133];         if  (acedGetString(                 Adesk::kFalse,                  _T("\\nEnter entity handle : " ),                 entityHandle) != RTNORM)         {                 acutPrintf(ACRX_T("\\nInvalid entity handle." ));                 return ;         }         CUtils::DisplayProperties(entityHandle); }  void  initApp() {      acedRegCmds->addCommand(ACRX_T("MY_COMMANDS" ),                              ACRX_T("EntProps" ),                              ACRX_T("EntProps" ),                              ACRX_CMD_TRANSPARENT,                              ListEntityProperties);  }   #include  "rxmember.h" #include  "rxvaluetype.h" #include  "rxattrib.h" #include  "rxprop.h" #include  "dbobjptr.h"   // Utils.cpp void  CUtils::DisplayProperties(LPCTSTR handleStr) {         Acad::ErrorStatus es;         AcApDocument *pActiveDoc                  = acDocManager->mdiActiveDocument();         AcDbDatabase *pDB = pActiveDoc->database();          AcDbObjectId id = AcDbObjectId::kNull;         AcDbHandle objHandle(handleStr);     es = pDB->getAcDbObjectId(id, false , objHandle);     if  (es != Acad::eOk)         {         acutPrintf(                 _T("\\nCould not translate handle to objectId" ));     }          AcDbObjectPointer<AcDbEntity> entity(id, AcDb::kForRead);          AcRxMemberIterator * iter =                  AcRxMemberQueryEngine::theEngine()->newMemberIterator                 (entity);             for  (; !iter->done(); iter->next())         {                 printValues(entity, iter->current());         } }  void  CUtils::getAttInfo(         const  AcRxAttribute * att,         const  AcRxObject * member,         AcString & attInfo) {         if  (att->isA() == AcRxCOMAttribute::desc())         {                 AcRxCOMAttribute * a = AcRxCOMAttribute::cast(att);                 attInfo.format(_T("\\n%s - %s" ),                         att->isA()->name(), a->name());          }         else  if  (att->isA() == AcRxUiPlacementAttribute::desc())         {                 AcRxUiPlacementAttribute * a                          = AcRxUiPlacementAttribute::cast(att);                 attInfo.format(                 _T("\\n%s - %s - %f" ),                 att->isA()->name(),                  a->getCategory(member),                 a->getWeight(member));          }         else         {                 attInfo.format(_T("\\n%s" ), att->isA()->name());         } }  void  CUtils::printValues(         AcRxObject * entity,          const  AcRxMember * member) {         Acad::ErrorStatus err = Acad::eOk;          AcString strValue;         AcRxProperty * prop = AcRxProperty::cast(member);         if  (prop != NULL)         {                 AcRxValue value;                  if  ((err = prop->getValue(entity, value))                         == Acad::eOk)                  {                         ACHAR * szValue = NULL;                          int  buffSize = value.toString(NULL, 0);                         if  (buffSize > 0)                         {                                 buffSize++;                                 szValue = new  ACHAR[buffSize];                                 value.toString(szValue, buffSize);                         }                          strValue.format(                                 _T("%s = %s" ),                                 value.type().name(),                                  (szValue == NULL) ? _T("none" ) : szValue);                            if  (szValue)                                 delete  szValue;                 }                 else                 {                         strValue.format(_T("Error Code = %d" ), err);                 }         }          AcString str;         str.format(_T("\\n%s - %s [%s]" ), member->isA()->name(),                 member->name(), strValue.kACharPtr());         acutPrintf(str);          const  AcRxAttributeCollection & atts                 = member->attributes();                          for  (int  i = 0; i < atts.count(); i++)         {                 const  AcRxAttribute * att = atts.getAt(i);                   AcString attInfo;                 getAttInfo(att, member, attInfo);                  acutPrintf(attInfo);         }          if  (member->children() != NULL)         {                 for  (int  i = 0;                         i < member->children()->length(); i++)                 {                         const  AcRxMember * subMember                                 = member->children()->at(i);                         printValues(entity, subMember);                   }         } }
The CRX plugin exposes the "EntProps" command which requires handle of the entity for which the properties are to be retrieved as its input.
Here is a sample script file to load the crx and invoke "EntProps" command.
(arxload "D:\\Temp\\CrxTest1.crx")
EntProps
4C4   ;; Handle of the entity for which properties are to be displayed
GMT+8, 2026-11-3 00:55 , Processed in 0.654863 second(s), 34 queries , Gzip On.
