查看: 1937|回复: 0
[分享] Non-COM property with list of possible values
已领礼包: 859个
发表于 2015-7-22 18:58:05 | 显示全部楼层 |阅读模式
Non-COM property with list of possible valuesBy Adam Nagy
In the Property palette you can find properties which only accept values that are listed for the property. If you want to create such a property then you could do that by creating a new enum type and use that to create a new AcRxValueType that implements IAcRxEnumeration
Header file
// MyEnumType ///////////////////////////////////////////////////////
typedef enum {} MyEnum;
template<typename ValueType>
class MyValueTypeTemplate : public AcRxValueType
public:
  MyValueTypeTemplate(const ACHAR* name,
    const IAcRxEnumeration& pEnum,
    AcRxMemberCollectionConstructorPtr memberConstruct,
    void* userData = NULL):
  AcRxValueType(name,pEnum, sizeof(ValueType),
    memberConstruct, userData) {}
  virtual int subToString(const void* instance, ACHAR* buffer,
    size_t sizeInACHARs, AcRxValueType::StringFormat format)
    const ADESK_OVERRIDE;
  virtual bool subEqualTo(const void* a, const void* b)
class MyEnumTypeTemplate :
  public MyValueTypeTemplate<ValueType>, public IAcRxEnumeration
  AcArray<const AcRxEnumTag*> m_tags;
public:
  MyEnumTypeTemplate(const ACHAR* name,
  MyValueTypeTemplate<ValueType>(
    name,*this, memberConstruct, userData) {}
  ~MyEnumTypeTemplate()
    for (int i=m_tags.length()-1;i>=0;i--)
      AcRxMember::deleteMember(m_tags);
  virtual int count() const ADESK_OVERRIDE
    return m_tags.length();
  virtual const AcRxEnumTag& getAt(int i) const ADESK_OVERRIDE
    return *m_tags;
  void append(AcRxEnumTag& tag)
    m_tags.append(&tag);
    void acdbImpSetOwnerForEnumTag(
      const AcRxClass*, AcRxEnumTag*);
    acdbImpSetOwnerForEnumTag(this, &tag);
// MyListProperty ///////////////////////////////////////////////////
class MyListProperty : public AcRxProperty
public:
  static AcRxObject * makeMyListProperty();
  static const ACHAR * kCategoryName;
  static AcRxCategory * category;
  MyListProperty();
  virtual ~MyListProperty();
  virtual Acad::ErrorStatus subGetValue(
    const AcRxObject* pO, AcRxValue& value) const;
  virtual Acad::ErrorStatus subSetValue(
    AcRxObject* pO, const AcRxValue& value) const;
C++ file
void makeMyEnumTypeTemplateProperties(
  class AcRxMemberCollectionBuilder & collectionBuilder, void*);
template<>
int MyEnumTypeTemplate<MyEnum>::subToString(
  const void *instance, ACHAR *buffer, size_t sizeInACHARs,
  AcRxValueType::StringFormat format) const
  const ACHAR* formatString = L"%d";
  MyEnum & value = *(MyEnum*)instance;
  if (buffer==NULL)
    return _scwprintf(formatString,value);
  return swprintf_s(buffer,sizeInACHARs,formatString,value);
template<>
bool MyEnumTypeTemplate<MyEnum>::subEqualTo(
  const void *a, const void* b) const
  MyEnum & v1 = *(MyEnum*)a;
  MyEnum & v2 = *(MyEnum*)b;
  return v1==v2;
template<>
struct AcRxValueType::Desc< MyEnum >
  __declspec(dllexport) static const AcRxValueType& value() throw();
  static void del();
MyEnumTypeTemplate<MyEnum>* s_pMyEnumTypeTemplate = NULL;
const AcRxValueType& AcRxValueType::Desc< MyEnum >::value() throw()
  if (s_pMyEnumTypeTemplate==NULL)
    s_pMyEnumTypeTemplate = new MyEnumTypeTemplate<MyEnum>(
      L"MyEnumProperties",&makeMyEnumTypeTemplateProperties);
    AcRxEnumTag* pTag;
    pTag = new  AcRxEnumTag  (L"One", (int)0);
    s_pMyEnumTypeTemplate->append(*pTag);
    pTag = new  AcRxEnumTag  (L"Two", (int)1);
    pTag = new  AcRxEnumTag  (L"Three", (int)2);
    pTag = new  AcRxEnumTag  (L"Four", (int)3);
  return *s_pMyEnumTypeTemplate;
// This should be called when the value type is not needed anymore
// Best call it when the module gets unloaded (On_kUnloadAppMsg)
void AcRxValueType::Desc< MyEnum >::del()
  if (s_pMyEnumTypeTemplate)
    const ACHAR * name = s_pMyEnumTypeTemplate->name();
    if (acrxSysRegistry())
      acrxClassDictionary->remove(s_pMyEnumTypeTemplate->name());
const ACHAR * MyListProperty::kCategoryName = _T("My Category");
AcRxCategory * MyListProperty::category = NULL;
MyListProperty::MyListProperty() :
AcRxProperty(_T("My List Property"),
  AcRxValueType::Desc< MyEnum >::value())
  if (category == NULL)
    AcRxCategory * parent =  AcRxCategory::rootCategory();
    category = parent->findDescendant(kCategoryName);
      category = new AcRxCategory(kCategoryName, parent);
  // OPM = Object Property Manager / Property Palette
  // Add the Placement attribute to set under which category in
  // the OPM the property will be shown
  attributes().add(new AcRxUiPlacementAttribute(kCategoryName, 0));
  // Add this attribute so that AutoCAD will automatically create
  // the COM wrapper for this property, i.e. it will be visible
  // in OPM
  attributes().add(new AcRxGenerateDynamicPropertiesAttribute());
MyListProperty::~MyListProperty()
/// <summary>
/// This is called by the system to get the property value for
/// a specific object
/// </summary>
Acad::ErrorStatus MyListProperty::subGetValue(
  AcDbEntity * ent = AcDbEntity::cast(pO);
  if (ent == NULL)
    return Acad::eNotThatKindOfClass;
  // Get the value from the custom entity
  // or wherever we stored the value
  AEN1MyCircle * pMyCircle = AEN1MyCircle::cast(pO);
  value = AcRxValue(static_cast<MyEnum>(pMyCircle->m_myEnum));
  return Acad::eOk;
/// <summary>
/// This is called by the system to retrieve the property value for
/// </summary>
Acad::ErrorStatus MyListProperty::subSetValue(
  if (ent == NULL)
  const MyEnum * val = rxvalue_cast<MyEnum>(&value);
  if (val == NULL)
    return Acad::eInvalidInput;
  // Set the property of the custom entity
  // or store it wherever we want to
  pMyCircle->m_myEnum = *val;
  return Acad::eOk;
/// <summary>
/// This is called to create an instance of our class
/// </summary>
AcRxObject * MyListProperty::makeMyListProperty()
  return new MyListProperty();
GMT+8, 2026-11-3 01:47 , Processed in 0.458003 second(s), 28 queries , Gzip On.
