查看: 1695|回复: 0
[分享] Tag name and value from a Non-COM Enum property
已领礼包: 859个
发表于 2015-7-22 19:02:27 | 显示全部楼层 |阅读模式
Tag name and value from a Non-COM Enum propertyBy Balaji Ramamoorthy
Here is a blog post by my colleague Adam on displaying a list of values for a property using the Non-COM Property system. When the user changes the property value in the combo-box, it might be required for the plug-in to know the tag name and value of the selected item in the combo-box. Here is a sample code that retrieves the "AcRxEnumTag" from the "AcRxValue" and displays this information.
void PrintPropertyValue(AcDbEntity *pEntity, ACHAR* pPropertyName)
    AcRxMemberIterator * iter
        = AcRxMemberQueryEngine::theEngine()->newMemberIterator(pEntity);
    if(iter == NULL)
        return;
    AcRxProperty * prop = AcRxProperty::cast(iter->find(pPropertyName));
    if (prop != NULL)
        Acad::ErrorStatus err = Acad::eOk;
        AcRxValue value;
        if ((err = prop->getValue(pEntity, value)) == Acad::eOk)
            // Value type name
            acutPrintf(
                        ACRX_T("\nValue Type Name : %s"),
                        value.type().name()
            // Value
            ACHAR * szValue = NULL;
            int buffSize = value.toString(NULL, 0);
            if (buffSize > 0)
                buffSize++;
                szValue = new ACHAR[buffSize];
                value.toString(szValue, buffSize);
            acutPrintf (
                        ACRX_T("\nValue : %s"),
                        (szValue == NULL) ? _T("none") : szValue
            if (szValue)
                delete szValue;
            // Enum Tag name (only for enum properties)
            const MyEnum *val = rxvalue_cast<MyEnum>(&value);
            if (val != NULL)
                const AcRxEnumTag *pEnumTag = value.getEnumTag();
                if(pEnumTag != NULL)
                    acutPrintf(
                                ACRX_T("\nTag : %s"),
                                pEnumTag->name()
                    // OR
                    /*acutPrintf(
                                pEnumTag->localName()
        else
            acutPrintf(ACRX_T("Error Code = %d"), err);
    delete iter;
GMT+8, 2026-11-3 02:13 , Processed in 0.386704 second(s), 28 queries , Gzip On.
