查看: 1515|回复: 3
[分享] Managed I/O - Streams, Readers, and Writers
已领礼包: 859个
发表于 2015-10-7 08:16:46 | 显示全部楼层 |阅读模式
C++ CryptoStream Example
Create a new CLR console application project and you might want  to use CryptoStreamSampleCP as the project and solution names.
Add the following code.
//  CryptoStreamSampleCP.cpp : main project file.
// < summary>
//  This sample is designed to show how to use the composable stream  CryptoStream
//  to read and write encrypted data to a file. The sample uses the  DES encryption
//  standard to encrypt data.
// < /summary>
#include "stdafx.h"
using namespace System;
using namespace System::IO;
using namespace System::Security::Cryptography;
// < summary>
//  The main entry point for the application.
// < /summary>
[STAThread]
int main(array<System::String  ^> ^args)
    // Let's create a  private key that will be used to encrypt and decrypt the data stored  in the file hantu.dat.
    array< Byte >^ DESKey = gcnew array< Byte >{200, 5, 78, 232, 9, 6, 0, 4};
    array< Byte >^ DESInitializationVector = gcnew array< Byte >{0, 1, 2, 3,  4, 5, 6, 7, 8, 9};
     String^ FileName = "C:\\temp\\hantu.dat";
     CryptoStream^ MyStreamEncrypter = nullptr;
    try
        // Let's create a  file named hantu.dat in the current C:\Temp directory
         FileStream^ MyFileStream = nullptr;
        try
              MyFileStream = gcnew FileStream(FileName, FileMode::Create, FileAccess::Write);
              Console::WriteLine("{0}  file created/opened successfully", FileName);
        catch (Exception^ e)
            throw gcnew Exception("Failed  to create/open filestream with error: " + e->Message);
        // Let's create a  Symmetric crypto stream using the DES algorithm to encode all the  bytes written to the file hantu.
        try
             Console::WriteLine("Instantiate  DESCryptoServiceProvider & CryptoStream, encrypting {0}...",  FileName);
             DES^ DESAlgorithm = gcnew DESCryptoServiceProvider();
             MyStreamEncrypter = gcnew CryptoStream(MyFileStream, DESAlgorithm->CreateEncryptor(DESKey,  DESInitializationVector), CryptoStreamMode::Write);
             MyFileStream->Close();
            throw gcnew Exception("Failed  to create DES Symmetric CryptoStream with error: " + e->Message);
        // Let's write 10  bytes to our crypto stream. For simplicity
        // we will write an  array of 10 bytes where each byte contains a numeric value 0 - 9.
        array< Byte >^ MyByteArray = gcnew array< Byte >(10);
          Console::WriteLine("Writing...");
         for (short i = 0; i < MyByteArray->Length; i++)
             MyByteArray = (Byte)i;
             Console::Write("{0},  ", MyByteArray);
              Console::WriteLine();
        try
               MyStreamEncrypter->Write(MyByteArray, 0, MyByteArray->Length);
               Console::WriteLine("Writing  10 bytes to the crypto stream...");
            throw gcnew Exception("Write  failed with error: " + e->Message);
         Console::WriteLine(e->Message);
        return 0;
    finally
        // Let's close the  crypto stream now that we are finished writing data.
         Console::WriteLine("Closing  the encrypter stream...");
         MyStreamEncrypter->Close();
    // Now let's open  the encrypted file Jim.dat and decrypt the contents.
     Console::WriteLine("Opening  the encrypted {0} file and decrypting it...", FileName);
     CryptoStream^ MyStreamDecrypter = nullptr;
    try
        try
              MyFileStream = gcnew FileStream(FileName, FileMode::Open, FileAccess::Read);
              Console::WriteLine("Decrypted  {0} file opened successfully", FileName);
            throw gcnew Exception("Failed  to open filestream with error: " + e->Message);
        try
             Console::WriteLine("Instantiate  DESCryptoServiceProvider & CryptoStream, decrypting {0}...",  FileName);
             MyStreamDecrypter = gcnew CryptoStream(MyFileStream, DESAlgorithm->CreateDecryptor(DESKey,  DESInitializationVector), CryptoStreamMode::Read);
        array< Byte >^ MyReadBuffer = gcnew array< Byte >(1);
         Console::WriteLine("Reading  the decrypted {0} file content...", FileName);
        while (true)
            int BytesRead;
            try
                 BytesRead = MyStreamDecrypter->Read(MyReadBuffer, 0, MyReadBuffer->Length);
                throw gcnew Exception("Read  failed with error: " + e->Message);
            if (BytesRead  == 0)
                 Console::WriteLine("No  more bytes to read...");
                break;
             Console::WriteLine("Read  byte -> " + MyReadBuffer[0].ToString());
    finally
        // We are finished  performing IO on the file. We need to close the file to release  operating system resources related to the file.
         Console::WriteLine("Closing  the decrypter stream...");
         MyStreamDecrypter->Close();
    return 0;
Build and run the project. The following is an output example.
已领礼包: 859个
 楼主| 发表于 2015-10-7 15:25:56 | 显示全部楼层
  1. #include "stdafx.h"
  2. using namespace System;
  3. using namespace System::Text;
  4. using namespace System::Security::Cryptography;
  5. using namespace System::IO;
  6. int main(array<System::String ^> ^args)
  7. {
  8.         MemoryStream^ mStream = gcnew MemoryStream();
  9.         array< Byte >^ DESKey = gcnew array< Byte >{200, 5, 78, 232, 9, 6, 0, 4};
  10.     array< Byte >^ DESInitializationVector = gcnew array< Byte >{0, 1, 2, 3,  4, 5, 6, 7};
  11.         String^ unicodeString = L"This unicode string contains two characters with codes outside an 8-bit";
  12.         UTF8Encoding^ utf8 = gcnew UTF8Encoding;
  13.         array<Byte>^ data=utf8->GetBytes(unicodeString);
  14.         DES^ DESAlgorithm =  gcnew DESCryptoServiceProvider();
  15.         CryptoStream^ cStream = gcnew CryptoStream(mStream,
  16.                 DESAlgorithm->CreateEncryptor(DESKey, DESInitializationVector),
  17.                 CryptoStreamMode::Write);
  18.         cStream->Write(data, 0, data->Length);
  19.         cStream->FlushFinalBlock();
  20.         array<Byte>^ ret = mStream->ToArray();
  21.         Convert^ cvt;
  22.         String^ retstr=cvt->ToBase64String(ret);
  23.         cStream->Close();
  24.         mStream->Close();
  25.         Console::WriteLine(retstr );
  26.         System::Console::ReadLine();
  27.     return 0;
  28. }
FWj4VvUHOr6Yp6ZgwKPid7C9uacUdychc5DXigKnZ8JtKAJNB7G9PzWBi++z+Z92GR5YFDnpwkc8tY0M7bnIzGG8hYLPLiP7
GMT+8, 2026-11-3 15:14 , Processed in 0.568541 second(s), 32 queries , Gzip On.
