查看: 1468|回复: 0
[分享] How to turn an ARX Application into a Managed C++ Application?
已领礼包: 859个
发表于 2015-10-8 07:50:59 | 显示全部楼层 |阅读模式
How to turn an ARX Application into a Managed C++ Application?By Philippe Leefsma
You can directly create a mixed manage project using ObjectARX wizard. The steps below apply to projects which are being migrating from old releases or converting a unmanaged ObjectARX project to a mixed managed.
The first thing to do is to turn on the /CLR compiler setting to compile as managed.
In the project properties window, under the Property Pages for the project, make the following modifications:
C++ :  General:
    Compile As Managed
     To: Assembly Support (/clr)
    Debug Information Format: (Debug only)
    To: Program Database (/Zi)
Code Generation (Debug only):
    Basic runtime checks
     To: default
Precompiled Header:
    Create/Use Precompiled Header
     To: Create Precompiled Header (/Yc)
Code Generation:
    Enable Minimal Rebuild
     To: No
Link with the /NOENTRY flag
In stdafx.h add:
#using <mscorlib.dll>
#using <System.dll>
#using <System.Drawing.dll>
#using <system.windows.forms.dll>
In the CPP file where you're going to use managed code, add the following after the compiler references through to stdafx.h
using namespace System;
using namespace System::Reflection;
using namespace System::Collections;
using namespace System::ComponentModel;
using namespace System::Drawing;
using namespace System::Windows::Forms;
using namespace System::Security::Policy;
using namespace System::Runtime::InteropServices;
See attached sample for more details.
ArxDotNetSample.zip
更多图片 小图 大图
组图打开中,请稍候......
GMT+8, 2026-11-3 15:09 , Processed in 0.381141 second(s), 31 queries , Gzip On.
