查看: 2006|回复: 2
[求助] [求助]:用LISP怎样修改标注的文字高度?
发表于 2003-7-4 15:40:13 | 显示全部楼层 |阅读模式
用LISP怎样修改标注的文字高度?
谢谢
发表于 2003-7-4 16:30:21 | 显示全部楼层
(defun c:chdimh ()
  (vl-load-com)
  (setq k 0)
  (initget 7)
  (setq newh (getdist "\n请输入新字高:"))
  (setq alldims (ssget  "X" '((0 . "DIMENSION"))))
  (while (< k (sslength alldims))
           (setq dimvla (vlax-ename->vla-object (ssname alldims k)))
           (vla-put-TextHeight dimvla newh)
          (setq k (1+ k))
  (princ)
已领礼包: 488个
发表于 2003-7-5 18:05:49 | 显示全部楼层
建议不要改标注本身,不是好习惯.
改dimstyle比较好.
GMT+8, 2026-11-3 21:14 , Processed in 0.651528 second(s), 36 queries , Gzip On.
