查看: 1492|回复: 2
[他山之石] Order Entities
已领礼包: 3199个
发表于 2015-11-30 14:05:12 |阅读模式
;; OE (Order Entities)  -  Lee Mac
(defun LEEoe ( ent / cnt  enx new sbx sub )
    (setq cnt 1)
    ;(while
        (progn
                (setvar 'errno 0)
                ;(setq ent (car (entsel (strcat "\nSelect object " (itoa cnt) " <done>: "))))
                (cond
                        (   (= 7 (getvar 'errno))
                                (princ "\**sed, try again.")
                        (   (null ent)
                                nil
                        (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 (setq enx (entget ent)))))))))
                                (princ "\nSelected object is on a locked layer.")
                        (   (and
                                (setq new (entmakex enx))
                                (or (/= 1 (cdr (assoc 66 enx)))
                                        (progn
                                                (setq sub (entnext ent)
                                                        sbx (entget  sub)
                                                (while (/= "SEQEND" (cdr (assoc 0 sbx)))
                                                        (entmake sbx)
                                                        (setq sub (entnext sub)
        sbx (entget  sub)
                                                (entmake sbx)
                        (entdel ent)
                        (redraw new 3)
                        (setq   cnt (1+ cnt))
                        (   (princ "\nUnable to reorder selected object."))
        ;    ) ; while
    (princ)
; pline co-ords example
; By Alan H
(defun getcoords (ent)
        (vlax-safearray->list
                (vlax-variant-value
                        (vlax-get-property
                                (vlax-ename->vla-object ent)
                                "Coordinates"
(defun co-ords2xy ()
        ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
        (setq len (length co-ords))
        (setq numb (/ len 2)) ; even and odd check required
        (setq I 0)
        (repeat numb
                (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
                ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
                (setq co-ordsxy (cons xy co-ordsxy))
                (setq I (+ I 2))
; program starts here
(defun c:OE( / ss x)
        (command "_pline")
        (while (= (getvar "cmdactive") 1 ) (command pause)
        (setq co-ords (getcoords (entlast)))
        (co-ords2xy) ; list of 2d points ** pline
        (entdel (entlast))
        (setq ss (ssget "F" co-ordsxy))
        (setq x (sslength ss))
        (repeat (sslength ss)
                (setq ent (ssname ss (setq x ( - x 1))))
                (if (= (vla-get-ObjectName (setq obj (vlax-ename->vla-object ent))) "AcDbCircle")
                        (progn
                                (setq pt (vlax-safearray->list (vlax-variant-value (vla-get-center obj))) )
                                (setq ts (cdr (assoc 40 (tblsearch "STYLE" (getvar "TEXTSTYLE")))))
                                (if (zerop ts)
                                        (command "TEXT" pt "3.5" "0" (rtos x 2 0))
                                        (command "TEXT" pt "0" (rtos x 2 0))
                        ) ; progn
                ) ; if
                (LEEoe ent)
                (princ "\n")
        (command "_.regen")
已领礼包: 264个
发表于 2015-11-30 15:56:16 来自手机 | 显示全部楼层
没看出来这个是调的什么顺序
发表于 2015-11-30 22:40:39 | 显示全部楼层
能解释一下吗?
GMT+8, 2026-11-6 05:13 , Processed in 0.503559 second(s), 32 queries , Gzip On.
