楼主: pxt2014
[求助] 如何选择多个文件,返回文件名表?
发表于 2019-7-14 12:29:53 | 显示全部楼层
;;------------------------=={ Get Files Dialog }==----------------------;;
;;  An analog of the 'getfiled' function for multiple file selection.   ;;
;;  Author:  Lee Mac, Copyright ?2012  -                ;;
;;  Arguments:                                                          ;;
;;  msg - [str/nil] Dialog box label; 'Select Files' if nil or "".      ;;
;;  def - [str/nil] Default directory; dwgprefix if nil or "".          ;;
;;  ext - [str/nil] File extension filter (e.g. "dwg;lsp"); "*" if nil  ;;
;;  Returns:  List of selected files, else nil                          ;;
;;  Version 1.6    -    2016-03-21                                      ;;
(defun LM:getfiles ( msg def ext / *error* dch dcl des dir dirdata lst rtn )
        (defun *error* ( msg )
                (if (= 'file (type des))
                        (close des)
                (if (and (= 'int (type dch)) (< 0 dch))
                        (unload_dialog dch)
                (if (and (= 'str (type dcl)) (findfile dcl))
                        (vl-file-delete dcl)
                (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
                        (princ (strcat "\nError: " msg))
                (princ)
        (if
                (and
                        (setq dcl (vl-filename-mktemp nil nil ".dcl"))
                        (setq des (open dcl "w"))
                        (progn
                                (foreach x
                                                 "lst : list_box"
                                                 "    width = 40.0;"
                                                 "    height = 20.0;"
                                                 "    fixed_width = true;"
                                                 "    fixed_height = true;"
                                                 "    alignment = centered;"
                                                 "    multiple_select = true;"
                                                 "but : button"
                                                 "    width = 20.0;"
                                                 "    height = 1.8;"
                                                 "getfiles : dialog"
                                                 "    key = \"title\"; spacer;"
                                                 "    : row"
                                                 "        : edit_box { key = \"dir\"; label = \"Folder:\"; }"
                                                 "        : button"
                                                 "            key = \"brw\";"
                                                 "            label = \"Browse\";"
                                                 "    spacer;"
                                                 "    : row"
                                                 "        : column"
                                                 "            : lst { key = \"box1\"; }"
                                                 "            : but { key = \"add\" ; label = \"Add Files\"; }"
                                                 "        : column {"
                                                 "            : lst { key = \"box2\"; }"
                                                 "            : but { key = \"del\" ; label = \"Remove Files\"; }"
                                                 "    spacer; ok_cancel;"
                                        (write-line x des)
                                (setq des (close des))
                                (< 0 (setq dch (load_dialog dcl)))
                        (new_dialog "getfiles" dch)
                (progn
                        (setq ext (if (= 'str (type ext)) (LM:getfiles:str->lst (strcase ext) ";") '("*")))
                        (set_tile "title" (if (member msg '(nil "")) "Select Files" msg))
                        (set_tile "dir"
                                (setq dir
                                        (LM:getfiles:fixdir
                                                (if (or (member def '(nil "")) (not (vl-file-directory-p (LM:getfiles:fixdir def))))
                                                        (getvar 'dwgprefix)
                                                        def
                        (setq lst (LM:getfiles:updatefilelist dir ext nil))
                        (mode_tile "add" 1)
                        (mode_tile "del" 1)
                        (action_tile "brw"
                                (vl-prin1-to-string
                                        '(if (setq tmp (LM:getfiles:browseforfolder "" nil 512))
                                                 (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir tmp)) ext rtn)
                                                         rtn (LM:getfiles:updateselected dir rtn)
                        (action_tile "dir"
                                (vl-prin1-to-string
                                        '(if (= 1 $reason)
                                                 (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:fixdir $value))) ext rtn)
                        (action_tile "box1"
                                (vl-prin1-to-string
                                                 (lambda ( / itm tmp )
                                                         (if (setq itm (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" $value ")"))))
        (if (= 4 $reason)
        (cond
        (   (equal '("..") itm)
        (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:updir dir))) ext rtn)
        (   (vl-file-directory-p (setq tmp (LM:getfiles:checkredirect (strcat dir "\\" (car itm)))))
        (   (setq rtn (LM:getfiles:sort (append rtn (mapcar '(lambda ( x ) (strcat dir "\\" x)) itm)))
        lst (LM:getfiles:updatefilelist dir ext rtn)
        (if (vl-every '(lambda ( x ) (vl-file-directory-p (strcat dir "\\" x))) itm)
        (mode_tile "add" 1)
        (mode_tile "add" 0)
                        (action_tile "box2"
                                (vl-prin1-to-string
                                                 (lambda ( / itm )
                                                         (if (setq itm (mapcar '(lambda ( n ) (nth n rtn)) (read (strcat "(" $value ")"))))
        (if (= 4 $reason)
        (setq rtn (LM:getfiles:updateselected dir (vl-remove (car itm) rtn))
        (mode_tile "del" 0)
                        (action_tile "add"
                                (vl-prin1-to-string
                                                 (lambda ( / itm )
                                                         (if
        (setq itm
        (vl-remove-if 'vl-file-directory-p
        (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" (get_tile "box1") ")")))
                                                         (mode_tile "add" 1)
                                                         (mode_tile "del" 1)
                        (action_tile "del"
                                (vl-prin1-to-string
                                                 (lambda ( / itm )
                                                         (if (setq itm (read (strcat "(" (get_tile "box2") ")")))
        (setq rtn (LM:getfiles:updateselected dir (LM:getfiles:removeitems itm rtn))
                                                         (mode_tile "add" 1)
                                                         (mode_tile "del" 1)
                        (if (zerop (start_dialog))
                                (setq rtn nil)
        (setq *error* nil);;修正
        rtn
(defun LM:getfiles:listbox ( key lst )
        (start_list key)
        (foreach x lst (add_list x))
        (end_list)
        lst
(defun LM:getfiles:listfiles ( dir ext lst )
        (vl-remove-if '(lambda ( x ) (member (strcat dir "\\" x) lst))
                (cond
                        (   (cdr (assoc dir dirdata)))
                        (   (cdar
                                                (setq dirdata
                                                        (cons
        (cons dir
        (append
        (LM:getfiles:sortlist (vl-remove "." (vl-directory-files dir nil -1)))
        (LM:getfiles:sort
        (if (member ext '(("") ("*")))
        (vl-directory-files dir nil 1)
        (vl-remove-if-not
        (function
        (lambda ( x / e )
        (and
        (setq e (vl-filename-extension x))
        (setq e (strcase (substr e 2)))
        (vl-some '(lambda ( w ) (wcmatch e w)) ext)
        dirdata
(defun LM:getfiles:checkredirect ( dir / itm pos )
        (cond
                (   (vl-directory-files dir) dir)
                (   (and
                                        (=  (strcase (getenv "UserProfile"))
                                                (strcase (substr dir 1 (setq pos (vl-string-position 92 dir nil t))))
                                        (setq itm
                                                (cdr
                                                        (assoc (substr (strcase dir t) (+ pos 2))
        ("my documents" . "Documents")
        ("my pictures"  . "Pictures")
        ("my videos"    . "Videos")
        ("my music"     . "Music")
                                        (vl-file-directory-p (setq itm (strcat (substr dir 1 pos) "\\" itm)))
                        itm
                (   dir   )
(defun LM:getfiles:sort ( lst )
        (apply 'append
                (mapcar 'LM:getfiles:sortlist
                        (vl-sort
                                (LM:getfiles:groupbyfunction lst
                                        (lambda ( a b / x y )
                                                (and
                                                        (setq x (vl-filename-extension a))
                                                        (setq y (vl-filename-extension b))
                                                        (= (strcase x) (strcase y))
                                (function
                                                (and
                                                        (setq x (vl-filename-extension (car a)))
                                                        (setq y (vl-filename-extension (car b)))
                                                        (< (strcase x) (strcase y))
(defun LM:getfiles:sortlist ( lst )
        (mapcar (function (lambda ( n ) (nth n lst)))
                (vl-sort-i (mapcar 'LM:getfiles:splitstring lst)
                        (function
                                        (while
                                                (and
                                                        (setq x (car a))
                                                        (setq y (car b))
                                                        (= x y)
                                                (setq a (cdr a)
                                                        b (cdr b)
                                        (cond
                                                (   (null x) b)
                                                (   (null y) nil)
                                                (   (and (numberp x) (numberp y)) (< x y))
                                                (   (numberp x))
                                                (   (numberp y) nil)
                                                (   (< x y))
(defun LM:getfiles:groupbyfunction ( lst fun / tmp1 tmp2 x1 )
        (if (setq x1 (car lst))
                (progn
                        (foreach x2 (cdr lst)
                                (if (fun x1 x2)
                                        (setq tmp1 (cons x2 tmp1))
                                        (setq tmp2 (cons x2 tmp2))
                        (cons (cons x1 (reverse tmp1)) (LM:getfiles:groupbyfunction (reverse tmp2) fun))
(defun LM:getfiles:splitstring ( str )
                (lambda ( l )
                        (read
                                (strcat "("
                                        (vl-list->string
                                                (apply 'append
                                                        (mapcar
        (function
        (lambda ( a b c )
        (cond
        (   (member b '(45 46 92))
        (list 32)
        (   (< 47 b 58)
        (list b)
        (   (list 32 34 b 34 32))
        (cons nil l) l (append (cdr l) '(( )))
                (vl-string->list (strcase str))
(defun LM:getfiles:browseforfolder ( msg dir flg / err fld pth shl slf )
        (setq err
                (vl-catch-all-apply
                        (function
                                (lambda ( / app hwd )
                                        (if (setq app (vlax-get-acad-object)
        shl (vla-getinterfaceobject app "shell.application")
        hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
        fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg flg dir)
                                                (setq slf (vlax-get-property fld 'self)
                                                        pth (LM:getfiles:fixdir (vlax-get-property slf 'path))
        (if slf (vlax-release-object slf))
        (if fld (vlax-release-object fld))
        (if shl (vlax-release-object shl))
        (if (vl-catch-all-error-p err)
                (prompt (vl-catch-all-error-message err))
                pth
(defun LM:getfiles:full->relative ( dir path / p q )
        (setq dir (vl-string-right-trim "\\" dir))
        (cond
                (   (and
                                        (setq p (vl-string-position 58  dir))
                                        (setq q (vl-string-position 58 path))
                                        (/= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
                        path
                (   (and
                                        (setq p (vl-string-position 92  dir))
                                        (setq q (vl-string-position 92 path))
                                        (= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
                        (LM:getfiles:full->relative (substr dir (+ 2 p)) (substr path (+ 2 q)))
                (   (and
                                        (= (strcase dir) (strcase (substr path 1 q)))
                        (strcat ".\\" (substr path (+ 2 q)))
                (   (= "" dir)
                        path
                (   (setq p (vl-string-position 92 dir))
                        (LM:getfiles:full->relative (substr dir (+ 2 p)) (strcat "..\\" path))
                (   (LM:getfiles:full->relative "" (strcat "..\\" path)))
(defun LM:getfiles:str->lst ( str del / pos )
        (if (setq pos (vl-string-search del str))
                (cons (substr str 1 pos) (LM:getfiles:str->lst (substr str (+ pos 1 (strlen del))) del))
                (list str)
(defun LM:getfiles:updatefilelist ( dir ext lst )
        (LM:getfiles:listbox "box1" (LM:getfiles:listfiles dir ext lst))
(defun LM:getfiles:updateselected ( dir lst )
        (LM:getfiles:listbox "box2" (mapcar '(lambda ( x ) (LM:getfiles:full->relative dir x)) lst))
        lst
(defun LM:getfiles:updir ( dir )
        (substr dir 1 (vl-string-position 92 dir nil t))
(defun LM:getfiles:fixdir ( dir )
        (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir))
(defun LM:getfiles:removeitems ( itm lst / idx )
        (setq idx -1)
        (vl-remove-if '(lambda ( x ) (member (setq idx (1+ idx)) itm)) lst)
(vl-load-com)
(defun c:tt ()
        (mapcar 'princ (LM:getfiles "Select Drawings" "" "dwg"))
        (princ)
已领礼包: 299个
发表于 2019-7-15 06:28:14 | 显示全部楼层
感谢分享,感觉打开了一扇大门
已领礼包: 2个
发表于 2019-7-16 16:34:41 | 显示全部楼层
这个好,感觉一下明朗了。
GMT+8, 2026-11-4 08:15 , Processed in 0.498822 second(s), 31 queries , Gzip On.
