查看: 2258|回复: 5
[求助] 交点打断
发表于 2016-3-10 17:10:21 | 显示全部楼层 |阅读模式
AppendLine(AcDbCurve *pInsertCurve)
        std::list<std::pair<double,AcGePoint3d> > instrectPts;
        if (pInsertCurve==NULL)
                return;
        int nLines=m_curveSegments.length();
        if (nLines<1)
                m_curveSegments.append(pInsertCurve);
        else{
                int i=0;
                for(i=nLines-1; i>=0; i--)
                        AcDbCurve *pCurCurve=AcDbCurve::cast((AcRxObject*)m_curveSegments);
                        std::list<std::pair<double,AcGePoint3d> > jds;
                        GetCurveInstrectPts(pInsertCurve,pCurCurve,jds,instrectPts);
                        //对交点排序.
                        jds.sort( );
                        if(jds.size() > 0){
                                AcGePoint3dArray pts;
                                std::list<std::pair<double,AcGePoint3d> >::iterator iter;
                                for(iter=jds.begin();iter!=jds.end();iter++){
                                        std::pair<double,AcGePoint3d> item=*iter;
                                        pts.append(item.second);
                                BreakCurve(pts,pCurCurve,/*curvePtrArr*/m_curveSegments);
                                if (pCurCurve!=NULL){
                                        m_curveSegments.removeAt(i);
                                        delete pCurCurve;
                                        pCurCurve=NULL;
                instrectPts.sort();
                AcGePoint3dArray ptArr;
                for(iter=instrectPts.begin();iter!=instrectPts.end();iter++)
                        ptArr.append(item.second);
                BreakCurve(ptArr,pInsertCurve,m_curveSegments);
                if (pInsertCurve!=NULL){
                        delete pInsertCurve;
                        pInsertCurve=NULL;
交点打断,但是在点排序这里编译不过,求高手指点!
发表于 2016-3-10 17:29:27 | 显示全部楼层
自己定义 compare 函数
 楼主| 发表于 2016-3-10 19:08:22 | 显示全部楼层
多谢,能大概说说吗?我还是不太明白
bool compare (const pair &t1,const pair &t2) { return t1.first < t2.first; } jds.sort(compare);  详情 回复 发表于 2016-3-11 10:32
发表于 2016-3-11 10:32:28 | 显示全部楼层
llq_78 发表于 2016-3-10 19:08
多谢,能大概说说吗?我还是不太明白
bool compare (const pair<double,AcGePoint3d> &t1,const pair<double,AcGePoint3d>  &t2)
jds.sort(compare);
 楼主| 发表于 2016-3-11 15:53:11 | 显示全部楼层
:)多谢!我试试
发表于 2016-10-3 15:03:42 | 显示全部楼层
您好!对于一个AcGePoint3dArray ptarry数组,如何按X从小到大进行排序,当X相等时,按Y从小到大排序?能帮助写一个这样的一个完整吗?
如AcGePoint3d为
(1.0,2.0,0.0)
(5.0,0.0,0.0)
(3.0,1.0,0.0)
(7.0,2.0,0.0)
(5.0,-2.0,0.0)
(3.0,2.0,0.0)
按X升序Y升序后的排序结果为:
(1.0,2.0,0.0)
(3.0,1.0,0.0)
(3.0,2.0,0.0)
(5.0,-2.0,0.0)
(5.0,0.0,0.0)
(7.0,2.0,0.0)
请问如何实现?
GMT+8, 2026-11-22 11:51 , Processed in 0.133389 second(s), 18 queries , Gzip On, File On.
