查看: 1395|回复: 1
[PDF] Tipard PDF Converter Platinum 3.2.10 Multilingual PDF转换软件
已领礼包: 20个
发表于 2016-3-26 15:08:32 | 显示全部楼层 |阅读模式
Tipard PDF Converter Platinum是一款专业的PDF转换软件,可以将PDF文件转换成Word, TXT和图片文件,支持转换PDF特定页面,支持多种语言的PDF文件(英语,土耳其语,泰国语,拉丁语,韩文,希腊文,西里尔文,阿拉伯文,日文和中文),对中文支持良好.
功能:
转换PDF为TXT
转换PDF为WORD
转换PDF为图片
支持输入文件格式:PDF
支持输出文件格式:TXT, Word, RTF, JPEG, PNG, GIF, BMP, PCX, TGA, TIFF
Tipard PDF Converter Platinum 3.x Multilingual | 338.5 MB
Tipard PDF converter Platinum is advanced and comprehensive PDF converter software which has the ability of converting PDF files to Microsoft Word (.doc), text (.txt) or multiple image formats freely. You have the right of defining conversion pages and previewing the conversion effect. Meanwhile, it supports more than ten language types, giving you professional service.
Convert PDF to Word/Text
Tipard PDF converter Platinum is capable of converting almost any PDF file to many other formats, including Microsoft Word (.doc) and text (.txt). The converted Word file is compatible with Microsoft Office 2010, 2007, and 2003. If PDF file is not supported by your PC or portable devices, you may choose to make conversion with this PDF converter Platinum. The converter has blazing conversion speed without losing any information of the original file. So don't worry about the conversion quality.
Convert PDF to Image
Tipard PDF converter Platinum can also convert PDF file to all popular image formats, like .jpeg, .jpg, .gif, .bmp etc. All the information of the original file, including the text, images and watermarks will be all kept. And when you convert PDF to image formats, you are allowed to adjust the output color and resolution as well. If it happens to be the .jpeg format, you may set the JPEG quality from 1% to 100% as you like.
Multiple Supported Language Types
More than ten language types can be recognized and supported by this PDF Converter Platinum: English, Turkish, Thai, Latin, Korean, Greek, Slavonic, Arabic, Japanese, and Chinese, covering all common languages. Therefore, almost any PDF document from all over the world can be converted through it.
Define and Preview
When using this converter to do some conversion, you are allowed to choose the part that need to be converted according to your own wish. You may choose "All page" or "Current page" or you could directly enter the page number and/or page ranges in Arabic numbers. Before you perform the conversion, you could preview the conversion result in the top right of the window to make sure that you will be satisfied with the output effect.
Home Page - http://www.tipard.com/pdf-converter-platinum
下载地址:
链接: http://pan.baidu.com/s/1pLcijDD 密码: cw8b
已领礼包: 8个
发表于 2016-5-27 11:09:30 来自手机 | 显示全部楼层
谢谢楼主分享!赞一个!
GMT+8, 2026-11-5 01:18 , Processed in 0.620690 second(s), 33 queries , Gzip On.
