查看: 1569|回复: 0
[图形图像] Artlantis Studio 6.0.2.25 Multilingual
已领礼包: 145个
发表于 2016-3-26 15:21:31 | 显示全部楼层 |阅读模式
来自80个国家的超过85000位建筑师,设计师,空间规划师,室内规划师,城市规划师,景观设计师的肯定…
Artlantis Studio(高级版),是最快的单机3D渲染和动画应用软件,特别为建筑师和设计师而设计。它是光能传递或全球照明的领导者。Artlantis能够快速而简单地创建出理想的高分辨率3D透视图、QuickTime VR全景、QuickTime VR对象和动画。Artlantis渲染软件已是预览窗**术中的公认领导者,用户遍及80多个国家,包括建筑师、设计师和城市设计师等专业人员。
Artlantis界面直接与ArchiCAD、Revit、VectorWorks、SketchUp Pro和Arc+等软件相链接。另外,还有DWF、OBJ、FBX等导入格式,以及更新的DXF、DWG和3DS插件,Artlantis可以实现与所有领先的CAD软件的无缝连接。
Artlantis Studio 6.x Multilingual | 496MB
The new, physically correct Artlantis 6 rendering engine, with its legendary simplicity, allows you to create visualizations of an incomparable beauty and quality. To create stunning images, Artlantis 6 now includes its own built-in physical engine, emphasizing physical rendering quality, precision, material accuracy, and energy consumption.
White Balance
White Balance allows you to adjust the dominant color of a scene to the ambient lighting. Simply set this new parameter to automatic color mode or select a reference color, which will be recognized as white in the 3D scene.
Ambient occlusion
This new option in Artlantis allows users to display a global ambient occlusion to create virtual shadows in small areas where natural light doesn't go. It brings more depth and relief to both interior and exterior scenes.
White model
During calculation, white model rendering changes all su**ces to white except for those that are transparent. Lights maintain their color for sophisticated environments.
Pre-settings
Choose among many pre-set modes (indoor, outdoor, low light) and different definitions (speed, medium, quality), to quickly set the best results!
Exposure
Artlantis offers two illumination methods: Automatic Light Adjustment and ISO/Shutter. By choosing the Automatic Light Adjustment setting, the lights and neon power used in the scene are automatically adjusted to the sky and sun illumination
IES Lights
By default, Artlantis offers 8 IES pre-set profiles. Artlantis 6 now allows you to import downloaded IES profiles from manufacturers' websites. These files are used to simulate realistic illumination of your projects. For even greater flexibility, Artlantis 6 allows you to easily edit the brightness, color, direction and opening angle.
HDRI
Artlantis now fully compatible with HDRI files, for the background and for the global illumination. The "enhanced sky" function in the engine settings increases the photorealism of the images.
Neon shader
In addition, neon lights have been completely updated for this version with considerable gains in terms of quality and calculation speed.
Site insertion
When using the site insertion feature, Artlantis 6 offers a new and ** projection process with more accurate calculations. After aligning the XYZ axis in the 2D view and in the preview window, the model is easily positioned on the background image. A revolutionary integrated tool allows you to add transparency to a foreground image directly in Artlantis to enhance the quality of your projects.
Integrated Alpha Mask Editor
This revolutionary tool allows you to add transparency to a foreground image directly in Artlantis to enhance the quality of your projects.
Laser projection
With a ** click on the reference plane in the preview window, you set the position and orientation of the projection of the laser. A red line projected 360 in the model allows you to automatically position the objects or textures.
Catalog & Media
Accessing the Artlantis Media Store is now done with a single click. To customize your catalog, Artlantis 6 lets you freely create your own folders at level 2. New selection features allow you to view recently used media, shaders and objects already in the project or those added to the selection. Thanks to the "drop-drop" tool, you can insert random media from the selection into the project with every click of the mouse.''
下载地址:
链接: http://pan.baidu.com/s/1chswVW 密码: tamb
GMT+8, 2026-11-5 01:18 , Processed in 0.594231 second(s), 31 queries , Gzip On.
