查看: 1166|回复: 0
[他山之石] 连续测量线长的代码
发表于 2016-4-13 12:46:57 | 显示全部楼层 |阅读模式
  1. (defun c:test (/ pt pts dis p1)
  2.   (while (setq pt (getpoint "\nPoint: "))
  3.     (if (not p1)
  4.       (setq p1 pt)
  5.     )
  6.     (setq pts (cons pt pts))
  7.     (if (>= (length pts) 2)
  8.       (grdraw pt p1 1)
  9.     )
  10.     (setq p1 pt)
  11.   )
  12.   (setq dis 0.)
  13.   (if pts
  14.     (mapcar
  15.       '(lambda (x y)
  16.          (setq dis (+ dis (distance x y)))
  17.        )
  18.       (reverse (cdr (reverse pts)))
  19.       (cdr pts)
  20.     )
  21.   )                                       ; (apply 'command (cons ".pline"
  22.                                        ; pts))
  23.                                        ; (command)
  24.   (if (not (zerop dis))
  25.     (princ (strcat "\nDistance = " (rtos dis 2 4)))
  26.   )
  27.   (princ)
  28. )
GMT+8, 2026-11-6 00:15 , Processed in 0.373791 second(s), 29 queries , Gzip On.
