楼主: aimisiyou
[原创] 二维下料
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2016-12-11 11:37:07 | 显示全部楼层
给出(29,26)、(53,24)、(53,22)的分解图。
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-2-7 21:27:21 | 显示全部楼层
分解图有点小问题,(57,6)=(19,2)=(10,1)+(9,1)
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-2-17 20:25:16 | 显示全部楼层
;;;注意满足a>b>0!!!(n,m)为任意自然数。
(defun c:tt()
;;;(t 1)横上;(t -1)横下;(nil 1)竖上;(nil -1)竖下;
(defun f(pt n a b flag tfx)
  (if (= n 1)
      (if flag
         (entmake
          (list
            '(0 . "LWPOLYLINE")
             '(100 . "AcDbEntity")
             '(100 . "AcDbPolyline")
             '(90 . 4)
             '(70 . 1)
             (cons 10 (list (car pt) (cadr pt)))
             (cons 10 (list (+ (car pt) a) (cadr pt)))
             (cons 10 (list (+ (car pt) a) (+ (cadr pt) (* b tfx))))
             (cons 10 (list (car pt) (+ (cadr pt) (* b tfx))))
         (entmake
             (list
                 '(0 . "LWPOLYLINE")
                 '(90 . 4)
                 '(70 . 1)
                 (cons 10 (list (+ (car pt) b) (cadr pt)))
                 (cons 10 (list (+ (car pt) b) (+ (cadr pt) (* a tfx))))
                 (cons 10 (list (car pt) (+ (cadr pt) (* a tfx))))
      (progn
          (f pt 1 a b flag tfx)
          (setq i 1)
          (while (< i n)
             (setq pt1 (list (car pt) (+ (cadr pt) (* tfx (+ (if flag b a) (* (if flag a b) -1) (* (if flag a b) i))))))
             (setq pt2 (list (+ (car pt) (- (if flag a b) (if flag b a)) (* i (if flag b a))) (cadr pt)))
             (f pt1 1 a b (not flag) tfx)
             (f pt2 1 a b (not flag) tfx)
             (setq i (+ i 1))
          (f (list (+ (car pt) (if flag b a)) (+ (cadr pt) (* (if flag a b) tfx))) (- n 1) a b flag tfx)
(defun vfun (tmin)
  (setq i 0 vlst nil)
  (while (< i tmin)
     (repeat tmin (setq vlst (cons i vlst)))
     (setq i (+ i 1))
  vlst
(defun hfun (tmin)
   (setq j 0 llst nil hlst nil)
   (while (< j tmin)
          (setq llst (cons j llst))
          (setq j (+ j 1))
   (repeat tmin (setq hlst (append llst hlst)))
   hlst
(defun clfun1 (pt n m a b lst)
(if (< n m)
    (clfun1 pt m n b a lst)
(if (= m 1)
  (if (= (car lst) 0)
      (f pt (+ n 1) a b t 1)
      (if (= (car (cdr lst)) '(1 0))
          (f (list (car pt) (+ (cadr pt) (+ (* n a) b))) (+ n 1) a b t -1)
  (if (> (gcd n m) 1)
      (mapcar '(lambda (i j) (clfun1 (list (+ (car pt)(* i (+ (* a (/ m (gcd n m))) (* b (/ n (gcd n m)))))) (+ (cadr pt) (* j (+ (* a (/ n (gcd n m))) (* b (/ m (gcd n m)))))))(/ n (gcd n m)) (/ m (gcd n m)) a b lst)) (vfun (gcd n m)) (hfun (gcd n m)))
      (if (equal (cdr lst) (list nil))
              (if (and (= (rem n 2) 1) (= (rem m 2) 0))
        (progn
          (clfun1 pt (/ n 2) (/ m 2) a b (cons 0 (list nil)))
          (clfun1 (polar pt 0 (+ (* a (/ m 2)) (* b (/ n 2)))) (/ (+ n 1) 2) (/ (+ m 1) 2) a b (cons 1 (list '(1 0))))
          (clfun1 (polar pt (/ pi 2) (+ (* a (/ n 2)) (* b (/ m 2)))) (/ (+ n 1) 2) (/ (+ m 1) 2) a b (cons 1 (list '(1 0))))
          (clfun1 (list (+ (car pt) (+ (* a (/ (+ m 1) 2)) (* b (/ (+ n 1) 2))))(+ (cadr pt)(+ (* a (/ (+ n 1) 2)) (* b (/ (+ m 1) 2))))) (/ n 2) (/ m 2) a b (cons 0 (list nil)))
        (progn
          (clfun1 pt (/ (+ n 1) 2) (/ (+ m 1) 2) a b (cons 0 (list (list (- (/ (+ n 1) 2) (/ n 2)) (- (/ (+ m 1) 2) (/ m 2))))))
          (clfun1 (polar pt 0 (+ (* a (/ (+ m 1) 2)) (* b (/ (+ n 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list nil)))
          (clfun1 (polar pt (/ pi 2) (+ (* a (/ (+ n 1) 2)) (* b (/ (+ m 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list nil)))
          (clfun1 (list (+ (car pt) (+ (* a (/ m 2)) (* b (/ n 2))))(+ (cadr pt)(+ (* a (/ n 2)) (* b (/ m 2))))) (/ (+ n 1) 2) (/ (+ m 1) 2) a b (cons 0 (list (list (- (/ (+ n 1) 2) (/ n 2)) (- (/ (+ m 1) 2) (/ m 2))))))
        (progn
        (progn
          (clfun1 (polar pt 0 (+ (* a (/ (+ m 1) 2)) (* b (/ (+ n 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list '(1 0))))
          (clfun1 (polar pt (/ pi 2) (+ (* a (/ (+ n 1) 2)) (* b (/ (+ m 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list '(1 0))))
        (progn
                  (clfun1 pt (/ n 2) (/ m 2) a b (cons 0 (cdr lst)))
          (clfun1 (list (+ (car pt) (+ (* a (/ (+ m 1) 2)) (* b (/ (+ n 1) 2))))(+ (cadr pt)(+ (* a (/ (+ n 1) 2)) (* b (/ (+ m 1) 2))))) (/ n 2) (/ m 2) a b (cons 0 (cdr lst)))
        (progn
(setq ppt (getpoint "\n插入点位置:"))
(setq nn (getint "\nn=:") mm (getint "\nm=:") aa (getint "\na=:") bb (getint "\nb=:"))
(clfun1 ppt nn mm aa bb (list 0 nil))
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-2-17 23:19:30 | 显示全部楼层
(defun fl (DA DB a b)
   (setq n1 (/ DA a) det (- a b) n2 (rem DA a) n3 (/ (- a n2) det) let1 (rem (- a n2) det))
   (if (= let1 0)
       (setq va (list (- n1 n3 -1) n3 0))
       (setq va (list (- n1 n3) (+ n3 1) (- a b let1)))
   (setq nn1 (/ DB b) nn2 (/ (rem DB b) det) let2 (rem (rem DB b) det))
   (setq vb (list (- nn1 nn2) nn2 let2))
   (list va vb)
(fl 194 153 10 7)
((18 2 0) (19 2 0))
(fl 153 194 10 7)
((13 3 2) (26 1 2))
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-2-17 23:30:17 | 显示全部楼层
优先考虑第三位(即剩余边长度)越小越好,均为0最好。利用率100%的情况时((na 0 0)(nb 0 0)),再次是((na1 nb1 0)(nb2 na2 0)).若d=gcd(a,b),则有kb=b/d,ka=a/d,要求((na1,nb1,0)(nb2,na2,0))最优解,即转化为求(((rem na1 kb),nb1,0)((rem nb2 ka),na2,0))的最优解问题。
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-2-19 23:27:09 | 显示全部楼层
;;;确保将长度L分解成a,b线性组合后的剩余长度最短且a的系数取到最大值
(defun ff (L a b)
  (setq flag t det (rem L (gcd a b)) x (/ (- L det) a) )
  (while (and (> x 0) flag)
         (setq k (- L det (* x a)))
         (if (= (rem k b) 0)
             (setq flag nil)
             (setq x (- x 1))
   (if (/= x 0)
       (setq va (list x (/ k b) det))
       (if (= (rem L b) 0)
           (setq va (list 0 (/ L b) 0))
           (progn
               (setq j 1)
               (while (/= (last (ff (- L j) a b)) 0)
                      (setq j (+ 1 j))
               (setq va (mapcar '+ (ff (- L j) a b) (list 0 0 j)))
(ff 33 10 7)
(1 3 2)
(ff 133 40 27)
(1 3 12)
已领礼包: 3256个
发表于 2017-5-26 12:46:10 | 显示全部楼层
楼主 真心厉害,这么持之以恒
已领礼包: 6881个
发表于 2017-8-16 16:45:57 | 显示全部楼层
楼主这个二维的
最终结果定型 了吗
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-8-16 17:17:50 | 显示全部楼层
这个仅仅是对单一矩形构件而言,现实中矩形构件多样,算法也就更复杂了。
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-12-15 23:31:18 | 显示全部楼层
搁浅了很久,一是由于觉得基本实现了半自动化(当然复杂的判断情形,人工处理更简单高效),二是完全实现自动化没有好的思路,对于追求完美的人来说,如鲠在喉。最近好像有些灵光一现的感觉,该好好整理思路了。
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-12-15 23:43:42 | 显示全部楼层
;;;运行结果可能不正确(运气好的情况除外),权当试验结果。
(defun c:tt()
  (if (= n 1)
      (if flag
         (entmake
          (list
            '(0 . "LWPOLYLINE")
             '(90 . 4)
             '(70 . 1)
         (entmake
             (list
                 '(0 . "LWPOLYLINE")
                 '(90 . 4)
                 '(70 . 1)
      (progn
          (setq i 1)
          (while (< i n)
             (setq i (+ i 1))
(defun drawone (pt a b)
    (f pt 1 a b t 1)
(defun drawmore (ppt n m a b)
       (setq i 0 j 0)
       (while (< i n)
              (while (< j m)
                     (drawone (list (+ (car ppt) (* i a)) (+ (cadr ppt) (* j b))) a b)
                     (setq j (+ j 1))
              (setq i (+ i 1) j 0)
(defun vfun (tmin)
  (setq i 0 vlst nil)
  (while (< i tmin)
     (setq i (+ i 1))
  vlst
(defun hfun (tmin)
   (while (< j tmin)
          (setq j (+ j 1))
   hlst
(defun ff (L a b flag)
    (setq i 0 flst nil)
    (while (<= (* a i) L)
           (setq flst (cons (list i (/ (- L (* i a)) b) (rem (- L (* i a)) b)) flst))
           (setq i (+ i 1))
   (setq lst (vl-sort flst '(lambda (x y)  (<= (caddr x) (caddr y)) ) ) )
   (setq nmin (caddr (car lst)))
   (if flag
       (progn
           (setq flst (vl-remove-if-not '(lambda (x) (= (caddr x) nmin)) lst) )
           (setq flst (vl-sort flst '(lambda (x y) (> (car x) (car y)) ) ) )
           (setq va (car flst))
           (if (= (car va) 0)
               (progn
                  (setq flst (vl-remove-if '(lambda (x) (= (caddr x) nmin)) lst))
                  (setq nmin (caddr (car flst)))
                  (setq flst (vl-remove-if-not '(lambda (x) (= (caddr x) nmin)) flst) )
                  (setq flst (vl-sort flst '(lambda (x y) (> (car x) (car y)) ) ))
       (progn
           (setq lst (vl-remove-if-not '(lambda (x) (= (caddr x) nmin)) lst) )
           (setq lst (vl-sort lst '(lambda (x y) (> (car x) (car y)) ) ) )
           (setq va (car lst))
     va
(defun frem (L a b)
    (setq sn (/ (* a b) (gcd a b)))
    (list (/ L sn) sn (rem L sn))
(defun clfun (pt n m a b lst)
(if (< n m)
    (clfun pt m n b a lst)
(if (= m 1)
  (if (= (car lst) 0)
  (if (> (gcd n m) 1)
      (mapcar '(lambda (i j) (clfun (list (+ (car pt)(* i (+ (* a (/ m (gcd n m))) (* b (/ n (gcd n m)))))) (+ (cadr pt) (* j (+
        (progn
          (clfun pt (/ n 2) (/ m 2) a b (cons 0 (list nil)))
          (clfun (polar pt 0 (+ (* a (/ m 2)) (* b (/ n 2)))) (/ (+ n 1) 2) (/ (+ m 1) 2) a b (cons 1 (list '(1 0))))
          (clfun (polar pt (/ pi 2) (+ (* a (/ n 2)) (* b (/ m 2)))) (/ (+ n 1) 2) (/ (+ m 1) 2) a b (cons 1 (list '(1 0))))
          (clfun (list (+ (car pt) (+ (* a (/ (+ m 1) 2)) (* b (/ (+ n 1) 2))))(+ (cadr pt)(+ (* a (/ (+ n 1) 2)) (* b (/ (+ m 1)
        (progn
          (clfun pt (/ (+ n 1) 2) (/ (+ m 1) 2) a b (cons 0 (list (list (- (/ (+ n 1) 2) (/ n 2)) (- (/ (+ m 1) 2) (/ m 2))))))
          (clfun (polar pt 0 (+ (* a (/ (+ m 1) 2)) (* b (/ (+ n 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list nil)))
          (clfun (polar pt (/ pi 2) (+ (* a (/ (+ n 1) 2)) (* b (/ (+ m 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list nil)))
          (clfun (list (+ (car pt) (+ (* a (/ m 2)) (* b (/ n 2))))(+ (cadr pt)(+ (* a (/ n 2)) (* b (/ m 2))))) (/ (+ n 1) 2) (/
        (progn
        (progn
          (clfun (polar pt 0 (+ (* a (/ (+ m 1) 2)) (* b (/ (+ n 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list '(1 0))))
          (clfun (polar pt (/ pi 2) (+ (* a (/ (+ n 1) 2)) (* b (/ (+ m 1) 2)))) (/ n 2) (/ m 2) a b (cons 1 (list '(1 0))))
        (progn
                  (clfun pt (/ n 2) (/ m 2) a b (cons 0 (cdr lst)))
        (progn
(defun frem (L a b)
    (setq i 0 flst nil)
           (setq i (+ i 1))
   (if flag
       (progn
           (if (= (car va) 0)
               (progn
       (progn
           (setq va (car lst))
     va
(defun fdiv (pt LA LB a b)
   (if (or (< (min LA LB) b) (< (max LA LB) a) (< (* LA LB) (* a b)))
        nil
       (if (>= LA LB)
           (cond
              ((< b LB (min a (* 2 b))) (drawmore pt (/ LA a) (/ LB b) a b))
              ((and (= (rem LA a) 0)(> (rem LA b) 0)(= (rem LB b) 0)(> (rem LB a) 0)) (drawmore pt (/ LA a) (/ LB b) a b))
              ((and (= (rem LA b) 0)(> (rem LA a) 0)(= (rem LB a) 0)(> (rem LB b) 0)) (drawmore pt (/ LA b) (/ LB a) b a))
              ((and (= (rem LA a) 0)(> (rem LA b) 0)(> (rem LB b) 0)(= (rem LB a) 0))
                    (progn
                        (setq dbat (ff LB b a t) cbat (ff LA b a t) dabt (ff LB a b t) )
                        (setq s1 (+ (* (/ LA a) (car dbat)) (* (cadr dbat) (car cbat)) (*
                                                (cadr cbat) (/ (- LB (* b (car dbat)))
b) )))
                        (setq s2 (+ (* (/ LB a) (car cbat)) (* (cadr cbat) (car dbat)) (* (cadr dbat) (/ (- LA (* b (car cbat)))
b) )))
                        (if (>= s1 s2)
                             (progn
                                    (setq ppt pt)
                                    (drawmore ppt (/ LA a) (car dbat) a b)
                                    (setq ppt (polar pt (/ pi 2) (* b (car dbat))))
                                    (drawmore ppt (car cbat) (cadr dbat) b a)
                                    (setq ppt (polar ppt 0 (* b (car cbat))))
                                    (drawmore ppt (cadr cbat) (/ (* a (cadr dbat)) b) a b)
                             (progn
                                    (setq ppt pt)
                                    (drawmore ppt (car cbat) (/ LB a)  b a)
                                    (drawmore ppt (cadr cbat) (car dbat)  a b)
                                    (setq ppt (polar ppt (/ pi 2) (* b (car dbat))))
                                    (drawmore ppt (cadr dbat) (/ (* a (cadr cbat)) b) b a)
              ((and (= (rem LA b) 0)(> (rem LA a) 0)(> (rem LB a) 0)(= (rem LB b) 0))
                    (progn
                        (setq dabt (ff LB a b t) cabt (ff LA a b t)  )
                        (setq s1 (+ (* (/ LA b) (car dabt)) (* (cadr dabt) (car cabt)) (* (cadr cabt) (/ (- LB (* a (car dabt)))
a) )))
                        (setq s2 (+ (* (/ LB b) (car cabt)) (* (cadr cabt) (car dabt)) (* (cadr dabt) (/ (- LA (* a (car cabt)))
a) )))
                        (if (>= s1 s2)
                             (progn
                                    (setq ppt pt)
                                    (drawmore ppt (/ LA b) (car dabt) b a)
                                    (setq ppt (polar pt (/ pi 2) (* a (car dabt))))
                                    (drawmore ppt (car cabt) (cadr dabt) a b )
                                    (setq ppt (polar ppt 0 (* a (car cabt))))
                                    (drawmore ppt (cadr cabt) (/ (* b (cadr dabt)) a) b a)
                             (progn
                                    (setq ppt pt)
                                    (drawmore ppt (car cabt) (/ LB b) a b )
                                    (drawmore ppt (cadr cabt) (car dabt) b a )
                                    (setq ppt (polar ppt (/ pi 2) (* a (car dabt))))
                                    (drawmore ppt (cadr dabt) (/ (* b (cadr cabt)) a) a b)
              ((and (= (rem LA b) 0)(> (rem LA a) 0)(> (rem LB a) 0)(> (rem LB b) 0))
                    (progn
                         (setq dabt (ff LB a b t) cabt (ff LA a b t))
                         (setq ppt pt)
              ((and (> (rem LA b) 0)(> (rem LA a) 0)(> (rem LB a) 0)(= (rem LB b) 0))
                    (progn
                         (setq ppt pt)
                         (drawmore ppt  (car cabt)(/ LB b) a b)
                         (drawmore ppt (cadr cabt) (car dabt) b a)
                         (drawmore ppt  (/ (* b (cadr cabt)) a) (cadr dabt) a b)
              ((and (> (rem LA b) 0)(= (rem LA a) 0)(> (rem LB a) 0)(> (rem LB b) 0))
                    (progn
                         (setq dbat (ff LB b a t) cbat (ff LA b a t))
                         (setq ppt pt)
                         (drawmore ppt (/ LA a) (car dbat) a b )
             ((and (> (rem LA b) 0)(> (rem LA a) 0)(> (rem LB a) 0)(> (rem LB b) 0))
                   (progn
                         (setq dabt (ff LB a b t) dLA (- LA (* b (car dabt)) (* a (cadr dabt))))
                         (clfun pt (car dabt) (cadr dabt) a b (list 0 nil))
                         (fdiv (polar pt 0 (+ (* b (car dabt)) (* a (cadr dabt)))) dLA LB a b)
            (cond
              ((< b LA (min a (* 2 b))) (drawmore pt (/ LA b) (/ LB a) b a))
                    (progn
                        (setq dbat (ff LB b a t) cbat (ff LA b a t)  )
                        (setq s1 (+ (* (/ LA a) (car dbat)) (* (cadr dbat) (car cbat)) (* (cadr cbat) (/ (- LB (* b (car dbat)))
b) )))
b) )))
                        (if (>= s1 s2)
                             (progn
                                    (setq ppt pt)
                             (progn
                                    (setq ppt pt)
                                    (drawmore ppt  (/ (* a (cadr cbat)) b) (cadr dbat) b a)
                    (progn
a) )))
a) )))
                        (if (>= s1 s2)
                             (progn
                                    (setq ppt pt)
                             (progn
                                    (setq ppt pt)
                    (progn
                         (setq ppt pt)
                    (progn
                         (setq ppt pt)
                    (progn
                         (setq ppt pt)
                   (progn
                         (setq cabt (ff LA a b t) dLB (- LB (* b (car cabt)) (* a (cadr cabt))))
                         (clfun pt (cadr cabt) (car cabt) a b (list 0 nil))
                         (fdiv (polar pt (/ pi 2) (+ (* b (car cabt)) (* a (cadr cabt)))) LA dLB a b)
     (setq pt (getpoint "\n插入点位置:"))
     (setq nn (getint "母材长边长度\nn=:")
           mm (getint "母材短边长度\nm=:")
           aa (getint "构件长边长度\na=:")
           bb (getint "构件短边长度\na=:")
     (drawone pt nn mm)
     (setq ppt pt cabt nil dabt nil)
     (setq vc (frem nn aa bb))
     (setq vd (frem mm aa bb))
     (drawmore ppt (/ (* (car vc) (cadr vc)) aa)  (/ (* (car vd) (cadr vd)) bb)  aa bb)
     (setq ppt (polar pt 0 (* (car vc) (cadr vc))))
     (setq cabt (ff (caddr vc) aa bb nil))
     (drawmore ppt (car cabt) (/ (* (car vd) (cadr vd)) bb)  aa bb)
     (setq ppt (polar ppt 0 (* (car cabt) aa)))
     (drawmore ppt (cadr cabt) (/ (* (car vd) (cadr vd)) aa)  bb aa)
     (setq dabt (ff (caddr vd) aa bb nil))
     (setq ppt (polar pt (/ pi 2) (* (car vd) (cadr vd))))
     (drawmore ppt (/ (* (car vc) (cadr vc)) bb) (car dabt) bb aa )
     (setq ppt (polar ppt (/ pi 2) (* (car dabt) aa)))
     (drawmore ppt (/ (* (car vc) (cadr vc)) aa) (cadr dabt) aa bb)
     (setq ppt (list (+ (car pt) (* (car vc) (cadr vc))) (+ (cadr pt) (* (car vd) (cadr vd))  ) ))
     (fdiv ppt (caddr vc) (caddr vd) aa bb)
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-12-17 12:29:45 | 显示全部楼层
没有经过证明的定性思维真的会欺骗你!!!前面86#的数据(124 104 10 7)真是有缘啊,冥冥中注定给我一个惊喜,今天验算时意外发现了以前错误的定性思维,即整体最优=局部最优+剩余部分最优!!!如图1,以前的思路是尽量把水平方向和竖直方向排紧凑,剩余右上角一个小矩形,然后递归运算。图2很好的否定了这一思维,同时也确定了矩形124*104中最多可以裁出184个10*7的小矩形,而不是以前坚信不疑的183个。有下料软件的朋友可以检验下,若得出的是183,那么你该重新审视你的软件了。
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-12-18 12:27:15 | 显示全部楼层
上面的方法(简称十字法)已经证实有误,那么如下图的环绕法能否得到最优解呢?最主要的是怎么证明一种算法对运算结果是没有问题的,而不是仅仅凭着感觉认为该算法是对的?如果环绕法也不行,那岂不“无从下手”了(因为从任何一个局部开始都会出错)?
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-12-18 22:39:03 | 显示全部楼层
环绕法也出现反例。如图(54,34,10, 7),上面用环绕法仅得到24个小矩形,但实际最多可以得到25个小矩形。
已领礼包: 1904个
财富等级: 堆金积玉
 楼主| 发表于 2017-12-18 23:23:29 | 显示全部楼层
按照图中算法写如下递推函数
(defun fnum (LA LB aa bb)
  (if (or (< (min LA LB) bb) (< (max LA LB) aa) (< (* LA LB) (* aa bb)))
      (setq va 0)
      (setq va (max
                  (+ (/ LA bb) (fnum LA (- LB aa) aa bb))
                  (+ (/ LB bb) (fnum (- LA aa) LB aa bb))
FNUM
_$ (fnum 54 34 10 7)
24
可见这个算法是有问题的!!!
GMT+8, 2026-10-14 01:43 , Processed in 0.536063 second(s), 57 queries , Gzip On.
