查看: 1711|回复: 0
[原创] 属性块之属性输出 XLS 文件
发表于 2016-5-8 08:07:06 | 显示全部楼层 |阅读模式
包括块的 Handle ,输出表格形式可以再外部批量修改,供后续更新
  1. (defun c:tt (/ getatts ss lst)
  2.   (defun getatts (ss / lst alst)
  3.     (setq lst  (mapcar '(lambda        (x)
  4.                           (cons        (xdrx_getpropertyvalue x "handle")
  5.                                 (mapcar        '(lambda (a) (xdrx_getpropertyvalue a "tag" "textstring"))
  6.                                         (xdrx_insert_getattribs x)
  7.                                 )
  8.                           )
  9.                         )
  10.                        (xdrx_pickset->ents ss)
  11.                )
  12.           alst (acad_strlsort
  13.                  (xd::list:removedup
  14.                    (mapcar 'strcase
  15.                            (apply 'append
  16.                                   (mapcar '(lambda (x) (mapcar 'car x)) (mapcar 'cdr lst))
  17.                            )
  18.                    )
  19.                  )
  20.                )
  21.     )
  22.     (cons (cons "" alst)
  23.           (mapcar '(lambda (x)
  24.                      (cons (car x)
  25.                            (mapcar '(lambda (a / l)
  26.                                       (if (setq l (assoc a (cdr x)))
  27.                                         (cadr l)
  28.                                         ""
  29.                                       )
  30.                                     )
  31.                                    alst
  32.                            )
  33.                      )
  34.                    )
  35.                   lst
  36.           )
  37.     )
  38.   )
  39.   (if (setq ss (ssget '((0 . "Insert") (66 . 1))))
  40.     (progn
  41.       (setq lst (getatts ss))
  42.       (xd::excel:createtofile
  43.         (strcat        (getvar "dwgprefix")
  44.                 (vl-filename-base (getvar "dwgname"))
  45.                 ".xls"
  46.         )
  47.         lst
  48.       )
  49.     )
  50.   )
  51.   (princ)
  52. )
GMT+8, 2026-11-22 11:12 , Processed in 0.344690 second(s), 10 queries , Gzip On, File On.
