查看: 3669|回复: 4
[每日一码] 用LISP跟踪命令的使用
发表于 2016-5-17 09:23:53 | 显示全部楼层 |阅读模式
问题:
I'm programming in LISP and now would like to track how many commands are being used within an AutoCAD session. How could I do it?
解决:
You can find samples about reactors in the LISP Help file, but here is the exact code you would need.
In this case we'll only track commands that actually ended, not including commands that got started and then cancelled - i.e. editor reactor’s commandEnded
When the document is closed we pop up a dialog showing how many commands were used in it since it got opened.
You would need to set up acaddoc.lsp so that it runs the following code for each opened document:
(defun editor-beginClose (reactor-object parameter-list /)
; instead of an alert box write the data somewhere
(alert (strcat "Command count is " (itoa g-command-count)))
(defun editor-commandEnded (reactor-object parameter-list /)
(setq g-command-count (1+ g-command-count))
(defun StartWatching (/)
; we need the ActiveX system for this
(vl-load-com)
; set the counter
(setq g-command-count 0)
; start the event watcher
(vlr-editor-reactor nil '((:vlr-beginClose . editor-beginClose)(:vlr-commandEnded . editor-commandEnded)))
; don't print anything to the screen
(princ)
; this should be started for each opened drawing
(StartWatching)
已领礼包: 604个
发表于 2016-5-17 10:42:06 | 显示全部楼层
g-command-count这个数计来有什么用处?
 楼主| 发表于 2016-9-22 23:47:51 | 显示全部楼层
全局变量,用来记录文档关闭前运行过的命令的个数。贴中例子,关闭文档的时候,弹出对话框告知。
已领礼包: 9341个
发表于 2016-9-23 07:21:02 | 显示全部楼层
谢谢 N版分享学习了!
已领礼包: 1094个
发表于 2021-10-6 04:32:54 | 显示全部楼层
感谢分享用LISP跟踪命令的使用
GMT+8, 2026-11-3 06:26 , Processed in 0.513352 second(s), 37 queries , Gzip On.
