查看: 3309|回复: 1
[每日一码] 用VLISP存取动态块的属性
发表于 2016-5-17 09:30:14 | 显示全部楼层 |阅读模式
问题:
Is there an example showing how to access dynamic block properties?
解决方案:
Here is a Visual Lisp example that iterates through dynamic properties of a selected block reference. If the property name is "Bolt Length" the value is printed on the command line. This shows the general approach to using ActiveX from Visual Lisp to access dynamic properties.
  1. (defun c:test (/ appAcad docCurrent utilObj oBkRef pt oProps i obj oPVar
  2.                  oPValue str
  3.               )
  4.   (vl-load-com)
  5.   (setq appAcad (vlax-get-acad-object)
  6.         docCurrent (vla-get-ActiveDocument appAcad)
  7.         utilObj (vla-get-utility docCurrent)
  8.   )
  9.   (vla-getentity utilObj 'oBkRef pt "Select a dynamic block reference")
  10.   (setq oProps (vlax-variant-value (vla-GetDynamicBlockProperties oBkRef)))
  11.   (setq i (vlax-safearray-get-l-bound oProps 1))
  12.   (while (<= i (vlax-safearray-get-u-bound oProps 1))
  13.     (progn
  14.       (setq obj (vlax-safearray-get-element oProps i)) ; (princ obj)
  15.       (princ "\n")
  16.       (princ (vla-get-PropertyName obj))
  17.       (princ "\n")
  18.       (if (= (vla-get-PropertyName obj) "Bolt Length")
  19.         (progn
  20.           (setq oPVar (vla-get-value obj))
  21.           (setq oPValue (vlax-variant-value oPVar))
  22.           (setq str (vla-get-propertyname obj))
  23.           (setq str (strcat str " = "))
  24.           (setq str (strcat str (rtos oPValue)))
  25.           (princ str)
  26.           (princ "\n")
  27.         )                               ; progn
  28.       )                                       ; if
  29.       (setq i (1+ i))
  30.     )                                       ; progn
  31.   )                                       ; while
  32.   (princ)
  33. )
已领礼包: 2个
发表于 2019-3-25 17:11:24 | 显示全部楼层
咋用
GMT+8, 2026-11-4 22:49 , Processed in 0.385168 second(s), 31 queries , Gzip On.
