查看: 7747|回复: 26
[每日一码] 提供三个纯LISP写的图像处理函数
发表于 2016-5-23 22:51:32 | 显示全部楼层 |阅读模式
三个函数: (imgunload <imgname>), (imgreload <imgname>), (imgdetach<imgname>)
卸载、重载、DETACH
问题:
How can I call the IMAGE command from Visual LISP using (command "-IMAGE") in
AutoCAD?
方案解决
To use the RELOAD, UNLOAD and DETACH options of the IMAGE command, it is not
possible to use the AutoCAD ActiveX inte**ce. Instead, you have to 'rebuild'
these options using AutoLISP and Visual LISP functions.
-IMAGE RELOAD:
This command options works on the raster image definition object that is stored
in the dictionary "ACAD_IMAGE_DICT". This object uses the DXFgroup code 280
as a 'loaded' flag. If the value of group code 280 is 1, the image file is currently
loaded; if the value is 0, the image file is unloaded.
In order to get the correct entry in the image dictionary (to get the right
image definition object) and set this flag to 1, use the IMAGERELOAD function
(see below).
-IMAGE UNLOAD:
This command options uses the flag previously mentioned. Set the value of group
code 280 to 0 to unload the image file. The function IMGUNLOAD does this.
-IMAGE DETACH:
This command options removes the specified image definition object and removes
every raster image entity from the current drawing that uses the (deleted) image
definition object. The IMGDETACH function does this.
You can use the following functions. They 'rebuild' the functionality of the
IMAGE command options.  The functions (imgreload), (imgunload) and (imgdetach)
need the image name as a parameter. For the image name, use the AutoCAD wildcard
mechanism.
(imgreload "image1")
(imgunload "i*")
(imgdetach "?abc?ef*")
  1. ;
  2. ;;; Use the function 'imgunload' instead of
  3. ;;; calling the command
  4. ;;; -IMAGE _Unload
  5. ;;;
  6. (defun imgunload (imgname)
  7.    (imgloadstat (strcase imgname) 0)
  8.    (princ)
  9. );;; Use the function 'imgreload' instead of
  10. ;;; calling the command
  11. ;;; -IMAGE _Reload
  12. ;;;
  13. (defun imgreload (imgname)
  14.    (imgloadstat (strcase imgname) 1)
  15.    (princ)
  16. );;; Use the function 'imgdetach' instead of
  17. ;;; calling the command
  18. ;;; -IMAGE _Detach
  19. ;;;
  20. (defun imgdetach (imgname / imgDict imgDictId dictLength counter
  21.                   dictName imgDefIds selSet imgDefId)   ;; Iterate all dictionary entries and remove
  22.    ;; the entries which matches 'imgname'.   (setq imgname (strcase imgname)
  23.          imgDict (dictsearch (namedobjdict) "ACAD_IMAGE_DICT")
  24.    )
  25.    (if (equal imgDict nil)
  26.       (princ "\nNo images loaded.")
  27.       (progn
  28.          ;; Image dictionary is available.
  29.          (setq imgDictId  (cdr (car imgDict))
  30.                dictLength (length imgdict)
  31.                counter   0
  32.          )
  33.          (while (< counter dictLength)
  34.             (if (equal (car (nth counter imgDict)) 3)
  35.                ;; Entry name found. Get it.
  36.                (progn
  37.                   (setq dictName (strcase (cdr (nth counter imgDict))))
  38.                   ;; Compare the entry name.
  39.                   (if (wcmatch dictName imgname)
  40.                      (progn
  41.                         ;; Remove the dictionary entry...
  42.                         (dictremove imgDictId dictName)
  43.                         ;; ...and store the entity name of
  44.                         ;; the raster image definition object.
  45.                         (setq imgDefIds
  46.                            (append imgDefIds
  47.                                    (list (cdr (nth (1+ counter) imgDict)))
  48.                            )
  49.                         )
  50.                      )
  51.                   )
  52.                )
  53.             )
  54.             (setq counter (1+ counter))
  55.          )
  56.          ;; Finished iterating the dictionary.
  57.          ;; Do we have to remove some raster image entities?
  58.          (if (/= (length imgDefIds) 0)
  59.             ;; Yes, we have to remove some raster image entities
  60.             ;; (because the related image definition objects
  61.             ;; have been removed).
  62.             (progn
  63.                ;; Select all image entities.
  64.                (setq selSet  (ssget "X" '((0 . "IMAGE")))
  65.                      counter 0
  66.                )
  67.                (if (/= selSet nil)
  68.                   (progn
  69.                      ;; Iterate all image entities
  70.                      (while (< counter (sslength selSet))
  71.                         ;; Get the entity name of the referenced
  72.                         ;; image definition object.
  73.                         (setq imgDefId
  74.                            (cdr (assoc 340 (entget (ssname selSet counter))))
  75.                         )
  76.                         ;; Is the referenced definition object gone?
  77.                         (if (member imgDefId imgDefIds)
  78.                            ;; The definition for this image entity
  79.                            ;; have been removed, so let us remove
  80.                            ;; the image entity, as well.
  81.                            (entdel (cdr (car (entget (ssname selSet counter)))))
  82.                         )
  83.                         (setq counter (1+ counter))
  84.                      )
  85.                      ;; Empty the selection set
  86.                      (setq selSet nil)
  87.                   )
  88.                )
  89.             )
  90.          )
  91.       )
  92.    )
  93.    (princ)
  94. );;; Internal function.
  95. ;;; This function is called by 'imgunload'
  96. ;;; and 'imgreload'.
  97. ;;;
  98. (defun imgloadstat (imgname status / imgDict imgDictId
  99.                     dictLength counter dictName dictEntry next)   ;; Get the image dictionary
  100.    (setq imgDict (dictsearch (namedobjdict) "ACAD_IMAGE_DICT"))
  101.    (if (equal imgDict nil)
  102.       (princ "\nNo images loaded.")
  103.       (progn
  104.          ;; Image dictionary is available.
  105.          (setq imgDictId  (cdr (car imgDict))
  106.                dictLength (length imgdict)
  107.                counter   0
  108.                next   T
  109.          )
  110.          (while (< counter dictLength)
  111.             (if (equal (car (nth counter imgDict)) 3)
  112.                ;; Entry name found. Get it.
  113.                (progn
  114.                   ;; Get dictionary entry name
  115.                   ;; and the dictionary entry
  116.                   (setq dictName (strcase (cdr (nth counter imgDict)))
  117.                         dictEntry (dictnext imgDictId next)
  118.                         next   nil
  119.                   )
  120.                   ;; Compare the entry name with the given name.
  121.                   (if (wcmatch dictName imgname)
  122.                      (progn
  123.                         ;; Entry found. Set the 'loaded' flag
  124.                         (setq dictEntry (subst (cons 280 status)
  125.                                                (assoc 280 dictEntry)
  126.                                                dictEntry
  127.                                         )
  128.                         )
  129.                         ;; There is a problem in AutoCAD which is fixed by 'fixlist'.
  130.                         ;; Some entities / objects should return on 'entget' 2D points,
  131.                         ;; but VisualLisp gets 3D points. The (wrong) z value of thereturned
  132.                         ;; point contains a random value which can break 'entmod'.
  133.                         ;; In case of an image definition object we have to remove the
  134.                         ;; z value of group code 10 and 11 before we can use 'entmod'.
  135.                         (entmod (fixlist dictEntry))
  136.                      )
  137.                   )
  138.                )
  139.             )
  140.             (setq counter (1+ counter))
  141.          )
  142.       )
  143.    )
  144. );
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 3199个
发表于 2016-5-23 23:15:09 | 显示全部楼层
谢谢N版分享
已领礼包: 5800个
发表于 2016-5-24 08:12:57 | 显示全部楼层
谢谢版主!跟着版主真心实意可以学到些东西!
已领礼包: 2965个
财富等级: 家财万贯
发表于 2016-5-24 09:08:29 | 显示全部楼层
good good.
已领礼包: 6881个
发表于 2016-5-24 10:44:47 | 显示全部楼层
谢谢版主
学习一下什么是图象处理
已领礼包: 604个
发表于 2016-5-24 11:46:57 | 显示全部楼层
用cad来处理图像,N版很有艺术细胞嘛
已领礼包: 13个
发表于 2016-5-24 18:23:14 | 显示全部楼层
很不错,值得学习
已领礼包: 20个
发表于 2016-5-25 00:25:28 来自手机 | 显示全部楼层
学学学习学习学习学习
已领礼包: 2759个
财富等级: 家财万贯
发表于 2016-6-3 09:33:51 | 显示全部楼层
xuexi !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
已领礼包: 620个
发表于 2016-6-27 13:49:09 | 显示全部楼层
谢谢分享!!!!!
已领礼包: 2670个
财富等级: 家财万贯
发表于 2016-6-29 19:07:39 | 显示全部楼层
dear sir nice
已领礼包: 3720个
发表于 2016-7-1 19:59:30 | 显示全部楼层
看看是否用得着该函数。
已领礼包: 6468个
发表于 2016-7-1 23:29:36 | 显示全部楼层
版主E文水平可真不是盖的,我都看不懂。
发表于 2016-7-4 16:58:26 | 显示全部楼层
学习学习。。顶
已领礼包: 432个
发表于 2017-7-20 15:58:36 | 显示全部楼层
我来测试一下,行不行
GMT+8, 2026-11-3 00:34 , Processed in 1.353882 second(s), 57 queries , Gzip On.
