查看: 1769|回复: 0
[尺寸] (XD::DIM:Init)尺寸标注初始化设置
发表于 2016-6-10 23:07:09 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::DIM:Init
调用格式: (XD::DIM:Init)
参数说明: 无
返回值: (样式名 样式实体名)
函数简介: 尺寸标注初始化设置,根据绘图单位生成两个样式之一
XD-DS-M-1000 (米绘图)或 XD-DS-MM-100(毫米绘图)
函数来源: 原创
函数作者: Lispboy
适用版本: XDRX API
最后更新时间: 2016-06-10
备注: -
演示图片: -
  1. (defun XD::DIM:Init ( / _dimblk na o o1 p scl u va x x1 x2)
  2.   (setq u (XD::Var:GetDrawingUnit))
  3.   (if (= u 0)
  4.     (setq p "M-1000"
  5.           scl 1
  6.     )
  7.     (setq p "MM-100"
  8.           scl 100
  9.     )
  10.   )
  11.   (if (not (xdrx_object_get "style" "XD-DimFont"))
  12.      (progn
  13.         (setq txt (xdrx_textstyle_make "XD-DimFont" "" "" 0.0 0.8))
  14.         (xdrx_textstyle_setfont txt "宋体" nil nil 134 2)
  15.      )
  16.   )
  17.   (if (not (setq o (xdrx_object_get "dimstyle" (setq na (strcat "XD-DS-" p)))))
  18.     (progn
  19.       (or
  20.         (setq o1 (xdrx_object_get "dimstyle" "standard"))
  21.         (setq o1 (xdrx_object_get "dimstyle" "ISO-25"))
  22.       )
  23.       (setq o1 (xdrx_object_clone o1))
  24.       (xdrx_setpropertyvalue o1 "name" na)
  25.       (setq _dimblk (xdrx_document_makeablock "_XDIMBLK"))
  26.       (setq va '(("DIMADEC" 0) ("DIMALT" nil)
  27.              ("DIMALTD" 3)
  28.              ("DIMALTF" 0.0393701)
  29.              ("DIMALTRND" 0.0)
  30.              ("DIMALTTD" 3)
  31.              ("DIMALTTZ" 0)
  32.              ("DIMALTU" 2)
  33.              ("DIMALTZ" 0)
  34.              ("DIMBLK" "_XDIMBLK")
  35.              ("DIMAPOST" "")
  36.              ("DIMARCSYM" 0)
  37.              ("DIMASZ" 1.0)
  38.              ("DIMATFIT" 3)
  39.              ("DIMAUNIT" 0)
  40.              ("DIMAZIN" 2)
  41.              ("DIMCEN" 2.5)
  42.              ("DIMCLRD" 0)
  43.              ("DIMCLRE" 0)
  44.              ("DIMCLRT" 0)
  45.              ("DIMDEC" 1)
  46.              ("DIMDLE" 0.0)
  47.              ("DIMDLI" 8.0)
  48.              ("DIMDSEP" ".")
  49.              ("DIMEXE" 1.25)
  50.              ("DIMEXO" 1.0)
  51.              ("DIMFIT" 5)
  52.              ("DIMFRAC" 0)
  53.              ("DIMGAP" 1.0)
  54.              ("DIMJOGANG" 0.785398)
  55.              ("DIMJUST" 0)
  56.              ("DIMLFAC" 1)
  57.              ("DIMLIM" nil)
  58.              ("DIMLUNIT" 2)
  59.              ("DIMLWD" -2)
  60.              ("DIMLWE" -2)
  61.              ("DIMPOST" "")
  62.              ("DIMRND" 0.0)
  63.              ("DIMSAH" nil)
  64.              ("DIMSCALE" 1)
  65.              ("DIMSD1" nil)
  66.              ("DIMSD2" nil)
  67.              ("DIMSE1" nil)
  68.              ("DIMSE2" nil)
  69.              ("DIMSOXD" nil)
  70.              ("DIMTAD" 1)
  71.              ("DIMTDEC" 1)
  72.              ("DIMTFAC" 1)
  73.              ("DIMTFILL" 0)
  74.              ("DIMTFILLCLR" 0)
  75.              ("DIMTIH" nil)
  76.              ("DIMTIX" nil)
  77.              ("DIMTM" 0.0)
  78.              ("DIMTMOVE" 2)
  79.              ("DIMTOFL" T)
  80.              ("DIMTOH" T)
  81.              ("DIMTOL" nil)
  82.              ("DIMTOLJ" 0)
  83.              ("DIMTP" 0.0)
  84.              ("DIMTSZ" 0.0)
  85.              ("DIMTXSTY" "xd-dimfont")
  86.              ("DIMTVP" 0.0)
  87.              ("DIMTXT" 3.0)
  88.              ("DIMTZIN" 8)
  89.              ("DIMUNIT" 2)
  90.              ("DIMUPT" nil)
  91.              ("DIMZIN" 8)
  92.             )
  93.       )
  94.       (mapcar
  95.         '(lambda (x)
  96.            (setq x1 (car x)
  97.                  x2 (cadr x)
  98.            )
  99.            (if (= (type x2) 'REAL)
  100.              (setq x2 (* scl x2))
  101.            )
  102.            (apply
  103.              'xdrx_setpropertyvalue
  104.              (cons o1 (list x1 x2))
  105.            )
  106.          )
  107.         va
  108.       )
  109.       (if (= u 1)
  110.         (xdrx_setpropertyvalue o1 "dimdec" 0 "dimtdec" 0)
  111.         (xdrx_setpropertyvalue o1 "dimdec" 1 "dimtdec" 1)
  112.       )
  113.     )
  114.   )
  115.   (xd::doc:command (list ".dimstyle" "r" na))
  116.   (list na o1)
  117. )
GMT+8, 2026-11-22 08:58 , Processed in 0.326334 second(s), 10 queries , Gzip On, File On.
