查看: 1075|回复: 2
[求助] 为什么命令运行两次以上才正确
已领礼包: 161个
发表于 2016-7-14 20:04:20 | 显示全部楼层 |阅读模式
(princ "\n------------------------------------------\n[[[[[[[[[[[[[[zlj画左路基线]]]]]]]]]]]]]]] \n[[[[[[[[[[[[[[zbp画左边坡线]]]]]]]]]]]]]]] \n[[[[[[[[[[[[[[ylj画右路基线]]]]]]]]]]]]]]] \n[[[[[[[[[[[[[[ybp画右边坡线]]]]]]]]]]]]]]]\n------------------------------------------\n" )
(defun c:ybp (/ f q sj sjb pt);;画右边坡
    (setq f (getfiled "请选择一个文件" "c:/" "txt" 8)) ;选择一个文件,将文件路径储存到变量f
    (setq q (open f "r"))  ;根据文件路径打开文件,将文件指针存储到变量q;多段线命令的变化格式(command "pline")(command pt1)(command pt2)(command "")
    (read-line q)
    (read-line q)
    (command "pline")
    (while
       (setq sj (read-line q));读取文本中一行数据
       (setq sjb (read (strcat"("sj")")));将字符串数据等转换为表
       (setq pt (list (nth 0 sjb) (nth 11 sjb)));获取路基桩号左缘高
       (command pt)
    (command "")
    (close q)
);end defun
(defun c:ylj (/ f q sj sjb pt);;画右路基
    (read-line q)
    (read-line q)
    (command "pline")
    (while
       (setq pt (list (nth 0 sjb) (nth 7 sjb)));获取路基桩号左缘高
       (command pt)
    (command "")
    (close q)
);end defun
(defun c:zbp (/ f q sj sjb pt);;画左边坡
    (read-line q)
    (read-line q)
    (command "pline")
    (while
       (setq pt (list (nth 0 sjb) (nth 10 sjb)));获取路基桩号左缘高
       (command pt)
    (command "")
    (close q)
);end defun
(defun c:zlj (/ f q sj sjb pt);;画左路基
    (read-line q)
    (read-line q)
    (command "pline")
    (while
       (setq pt (list (nth 0 sjb) (nth 6 sjb)));获取路基桩号左缘高
       (command pt)
    );;;end while
    (command "")
    (close q)
);end defun
这个是根据纬地的TF文件数据来画边坡立面,但是我在使用的时候,调用画路基的命令后,在调用画边坡线,第一次画出来的边坡线总是错的,要运行两次以上,边坡线才正确,这是怎么回事?
已领礼包: 859个
发表于 2016-7-14 23:27:20 来自手机 | 显示全部楼层
command绘制首先要关闭捕捉
哦哦,原来如此,谢谢大牛啦  详情 回复 发表于 2016-7-15 09:21
已领礼包: 161个
 楼主| 发表于 2016-7-15 09:21:38 | 显示全部楼层
csharp 发表于 2016-7-14 23:27
command绘制首先要关闭捕捉
哦哦,原来如此,谢谢大牛啦
GMT+8, 2026-11-6 00:12 , Processed in 0.397697 second(s), 34 queries , Gzip On.
