查看: 1783|回复: 2
[每日一码] (C#)Ge实体转换DB实体的示例代码
已领礼包: 6个
发表于 2016-7-15 13:25:05 | 显示全部楼层 |阅读模式
  1. [CommandMethod("ge2dbnet")]public void Ge2DbMethod()
  2. {
  3.      EllipticalArc3d arc1 =
  4.          new EllipticalArc3d(Point3d.Origin,
  5.      Vector3d.XAxis,
  6.      Vector3d.YAxis,
  7.      2.0, 0.5);
  8.     GetCurveObjectId(arc1);
  9. }
  10. static ObjectId GetCurveObjectId(Curve3d geCurve3d)
  11. {
  12.     Document doc  = Application.DocumentManager.MdiActiveDocument;
  13.     Editor ed = doc.Editor;
  14.     Database db = doc.Database;
  15.     ObjectId oid = ObjectId.Null;
  16.     try
  17.     {
  18.         Curve dbCurve = Curve.CreateFromGeCurve(geCurve3d);
  19.         if (dbCurve != null)
  20.         {
  21.             using (Transaction tr =
  22.                 db.TransactionManager.StartTransaction())
  23.                 {
  24.                     BlockTable bt = tr.GetObject(db.BlockTableId,
  25.                         OpenMode.ForRead) as BlockTable;
  26.                 BlockTableRecord btr =
  27.                     tr.GetObject(db.CurrentSpaceId,
  28.                     OpenMode.ForWrite) as BlockTableRecord;
  29.                 btr.AppendEntity(dbCurve);
  30.                 tr.AddNewlyCreatedDBObject(dbCurve, true);
  31.                 tr.Commit();
  32.                 }
  33.          }
  34.     }
  35.     catch (System.Exception ex)
  36.     {
  37.         ed.WriteMessage(ex.Message);
  38.     }
  39.     return oid;
  40. }
已领礼包: 6个
 楼主| 发表于 2016-7-15 13:26:25 | 显示全部楼层
对应的ARX GE转换DB的代码:
  1. // This sample uses "acdbConvertGelibCurveToAcDbCurve"
  2. // Other methods that you might be interested in :
  3. // AcDbCurve::getAcGeCurve()
  4. // AcDbCurve::setFromAcGeCurve()
  5. static void AdskMyTest1_Ge2Db(void)
  6. {
  7.     AcGeEllipArc3d ellipticArc(AcGePoint3d::kOrigin,
  8.         AcGeVector3d::kXAxis,
  9.         AcGeVector3d::kYAxis,
  10.         2.0,
  11.         0.5);
  12.     GetCurveObjectId(ellipticArc);
  13. }
  14. static AcDbObjectId GetCurveObjectId(AcGeCurve3d &geCurve3d)
  15. {
  16.     AcDbObjectId oid = AcDbObjectId::kNull;
  17.     Acad::ErrorStatus es = Acad::eOk;
  18.     AcDbCurve *pDbCurve = NULL;
  19.     es = acdbConvertGelibCurveToAcDbCurve(geCurve3d, pDbCurve);
  20.     if(es == Acad::eOk)
  21.     {
  22.     postToDb(pDbCurve, oid);
  23.     }
  24.     return oid;
  25. }
  26. static Acad::ErrorStatus postToDb(
  27. AcDbEntity* pEnt, AcDbObjectId &oid)
  28. {
  29.     AcDbBlockTable* pBlockTable;
  30.     AcDbDatabase *pDb
  31.     = acdbHostApplicationServices()->workingDatabase();
  32.     pDb = ->getBlockTable(pBlockTable, AcDb::kForRead);
  33.     AcDbBlockTableRecord* pModelSpaceBTR = NULL;
  34.     pBlockTable->getAt(ACDB_MODEL_SPACE,
  35.     pModelSpaceBTR,
  36.     AcDb::kForWrite);
  37.     Acad::ErrorStatus es;
  38.     es = pModelSpaceBTR->appendAcDbEntity(oid, pEnt);
  39.     pEnt->close();
  40.     pModelSpaceBTR->close();
  41.     pBlockTable->close();
  42.     return es;
  43. }
发表于 2016-7-30 08:01:44 | 显示全部楼层
非常好,找了很久,谢谢楼主!
GMT+8, 2026-11-3 15:32 , Processed in 0.421824 second(s), 32 queries , Gzip On.
