查看: 2016|回复: 3
[每日一码] 选择非同心圆、弧
已领礼包: 604个
发表于 2016-7-18 14:56:16 | 显示全部楼层 |阅读模式
;;选择非同心圆、弧
(defun W1 (ss fuzz / E I L L1 L2 P X)
  (repeat (setq i (sslength SS))
    (setq e (ssname ss (setq i (1- i))))
    (setq P (cdr (assoc 10 (entget e))))
    (setq L (cons (cons e p) L))
  (while (setq L1 (car L)
               L  (cdr L)
    (setq L2 (VL-REMOVE-IF-NOT '(lambda (x) (equal (cdr L1) (cdr x) fuzz)) L))
    (cond (L2
           (ssdel (car L1) ss))
           (mapcar '(lambda (x) (ssdel (car x) ss)) L2)
           (foreach x L2 (setq L (vl-remove x L)))
  ss
;;测试
(defun C:w1 (/ ss)
  (if (setq ss (ssget '((0 . "CIRCLE,arc"))))
    (SSLENGTH (w1 ss 0.01))
已领礼包: 1268个
发表于 2016-7-18 16:47:12 | 显示全部楼层
((ptcenter1 r1 e1) (ptcenter2 r2  e2) ...)
(xd::list:groupbyindex lst  1.0)
已领礼包: 1094个
发表于 2021-9-6 00:06:16 | 显示全部楼层
感谢楼主分享选择非同心圆、弧
GMT+8, 2026-11-3 07:36 , Processed in 0.473020 second(s), 36 queries , Gzip On.
