查看: 1882|回复: 1
[表格] (XD::Table:Make)绘制一个表格(ACAD表格,XTable表格)
已领礼包: 51个
发表于 2016-7-19 00:52:16 | 显示全部楼层 |阅读模式
函数发布
函数名称: XD::Table:Make
调用格式: (XD::Table:Make pt rows rowheight cols colwidth)
参数说明: pt ---- 表格插入点(左上角 WCS)
返回值: 表格实体名
函数简介: 绘制一个表格(ACAD表格,XTable表格)
根据(xd::table:settype ...)设置的表格类型绘制
类型“X”--生成XTable表格
类型“A”--生成AUTOCAD标准表格
函数来源: 原创
函数作者: Lispboy
适用版本: XDRX API
最后更新时间: 2016-07-19
备注: -
演示图片: -
  1. (defun XD::Table:Make (pt rows rowheight cols colwidth / blk cdata cel e el height i j p1 p2 p3 p4 pj pj1 pnt typ width xdir ydir)
  2.   (defun _drawrec (pnt width height)
  3.     (setq xdir (getvar "ucsxdir")
  4.           ydir (getvar "ucsydir")
  5.           p1 pnt
  6.           p2 (mapcar
  7.                '-
  8.                p1
  9.                (xdrx_vector_product ydir rowHeight)
  10.              )
  11.           p3 (mapcar
  12.                '+
  13.                p2
  14.                (xdrx_vector_product xdir colwidth)
  15.              )
  16.           p4 (mapcar
  17.                '+
  18.                p1
  19.                (xdrx_vector_product xdir colwidth)
  20.              )
  21.     )
  22.     (xdrx_polyline_make p1 p2 p3 p4 t)
  23.   )
  24.   (if (not (setq typ (xd::symbol:get '#xd-var-global-table-type)))
  25.     (progn
  26.       (XD::Table:SetType "X")
  27.       (setq typ "X")
  28.     )
  29.   )
  30.   (if (= typ "X")
  31.     (progn
  32.       (setq pj pt)
  33.       (setq el nil)
  34.       (setq i 0)
  35.       (xdrx_setmark)
  36.       (repeat rows
  37.         (setq pj (mapcar
  38.                    '-
  39.                    pt
  40.                    (list 0 (* i rowheight) 0)
  41.                  )
  42.         )
  43.         (setq j 0)
  44.         (setq cel nil)
  45.         (repeat cols
  46.           (setq pj1 (mapcar
  47.                       '+
  48.                       pj
  49.                       (list (* j colwidth) 0 0)
  50.                     )
  51.           )
  52.           (setq e (_drawrec pj1 colwidth rowHeight))
  53.           (xdrx_object_setXrecord e "no" (list (itoa i) (itoa j)))
  54.           (xdrx_object_setXrecord e "MergeCell" 0)
  55.           (setq el (cons e el))
  56.           (setq j (1+ j))
  57.           (setq cel (cons e cel))
  58.         )
  59.         (setq cdata (list i cel))
  60.         (setq i (1+ i))
  61.       )
  62.       (setq blk (xdrx_block_make (XD::Table:GetUniqueName)
  63.                                  (xdrx_getss) pt t
  64.                 )
  65.       )
  66.       (setq margin (XD::Table:GetVertCellMargin))
  67.       (xdrx_object_setxrecord blk "NumRows" rows)
  68.       (xdrx_object_setxrecord blk "NumColumns" cols)
  69.       (xdrx_object_setxrecord blk "CellMargin" margin)
  70.       (xdrx_xdata_setDirection blk "direction" xdir)
  71.     )
  72.     (progn
  73.       (setq blk (xdrx_table_make pt rows rowheight cols colwidth))
  74.     )
  75.   )
  76.   blk
  77. )
已领礼包: 51个
 楼主| 发表于 2016-7-19 01:18:35 | 显示全部楼层
测试:
下面代码根据选项绘制 XTable和AUTOCAD TABLE,并把首行单元格合并。
为什么要有XTable(INSERT表格)支持,因为:
1、INSERT实体,对比TABLE显示更快
2、对不支持TABLE版本的CAD是个补充。
XD LISP函数库提供完备的操作XTABLE对象的API接口,和ACAD对TABLE实体提供的强大的API功能一样。
  1. (defun c:tt()
  2.    (xdrx_begin)
  3.    (xdrx_initget "A X")
  4.    (initget "A X")
  5.    (if (and (setq tf (getkword "\n表格类型[ACAD(A)/XTable(X)]<X>:"))
  6.             (setq p (getpoint "\n表格插入点<退出>:"))
  7.        )
  8.      (progn
  9.         (xd::table:settype tf)
  10.         (xd::table:make p 5 100 3 400)
  11.         (xd::table:setmerge (entlast) 0 0 0 2)
  12.      )
  13.    )
  14.    (xdrx_end)
  15.    (princ)
  16. )
GMT+8, 2026-11-3 01:52 , Processed in 0.459683 second(s), 35 queries , Gzip On.
