查看: 1758|回复: 3
[研讨] 获取 AcDbTable 合并单元格地址的方法
已领礼包: 1268个
发表于 2016-7-23 14:35:07 | 显示全部楼层 |阅读模式
查手册可能用到的方法
1 IsMergedCell
2 GetCellExtents
3 Hittest
4 selectsubregion
发表于 2016-7-23 16:43:52 | 显示全部楼层
查的什么手册,能让我们看看不?
ARX使用手册  详情 回复 发表于 2016-7-23 17:09
已领礼包: 51个
发表于 2016-7-23 17:09:39 | 显示全部楼层
WhoCanSay 发表于 2016-7-23 16:43
查的什么手册,能让我们看看不?
ARX使用手册
已领礼包: 1268个
 楼主| 发表于 2016-7-23 17:54:52 | 显示全部楼层
hittest 方法 Example
http://hyperpics.blogs.com/beyon ... sp-and-activex.html
(vl-load-com)
;; Example adds a table to model space that is 5 rows by 3 columns
;; with a row height of 10 units and column width of 30 units
(defun c:AddTable( / acadObj curDoc insPt mSpaceObj tableObj)
    (setq acadObj (vlax-get-acad-object))
    (setq curDoc (vla-get-ActiveDocument acadObj))
    (setq insPt (vlax-3d-point 0 0 0))
    (setq mSpaceObj (vla-get-ModelSpace curDoc))
    (setq tableObj (vla-Addtable mSpaceObj insPt 5 3 10 30))
    (vla-put-StyleName tableObj "MyTableStyle")
;; Example shows how to pick a single table cell on screen and change its value.
;; This example demonstrates the ActiveX properties/methods HitTest,
;; GetCellType, GetText and SetText.
(defun c:SelectTableCell ( / pick vHeight vWidth lwrLeft uprRight vector
                                           SS_TABLES cnt eMax tableObj row col cellValueOrg)
  ;; Ask the user for a point on screen
  (if (/= (setq pick (vlax-3d-point (getpoint "\nSelect Cell to edit: "))) nil)
    (progn
      ;; Get the corners of the screen display to build our selection set
      (setq vHeight (getvar "viewsize"))
      (setq vWidth (* (/ (nth 0 (getvar "screensize")) (nth 1 (getvar "screensize"))) vHeight))
      (setq lwrLeft (list (- (nth 0 (getvar "viewctr")) (/ vWidth 2)) (- (nth 1 (getvar "viewctr")) (/ vHeight  2)) 0))
      (setq uprRight (list (+ (nth 0 (getvar "viewctr")) (/ vWidth 2)) (+ (nth 1 (getvar "viewctr")) (/ vHeight  2)) 0))
      ;; Get the current display orientation
      (setq vector (vlax-make-safearray vlax-vbDouble '(0 . 2)))
      (vlax-safearray-fill vector '(1 1 1))
      (setq vector (vlax-make-variant vector))
      ;; Select all the table objects visible on screen
      (if (setq SS_TABLES (ssget "C" lwrleft uprright (list (cons 0 "ACAD_TABLE"))))
        (progn
          (setq cnt 0
                eMax (sslength SS_TABLES)
          ;; Step through all the items in the selection set
          (while (> eMax cnt)
            ;; Geta table object from the selection set
            (setq tableObj (vlax-ename->vla-object (ssname SS_TABLES cnt)))
            ;; Return values for what cell was picked in
            (setq row 0
                  col 0)
            ;; Below is also a sample to see if a valid cell is picked
            ;; (vla-select table pick vector vector 5 5 :vlax-false 'row 'col)
            ;; Check to see if a valid cell was picked
            (if (= (vla-hittest tableObj pick vector 'row 'col) :vlax-true)
              (progn
                ;; Get out of the loop
                (setq cnt (1+ eMax))
                ;; Check to see what the Cell Type is (Text or Block)
                (if (= (vla-GetCellType tableObj row col) acTextCell)
                  (progn
                    ;; Let's get the value out
                    (setq cellValueOrg (vla-GetText tableObj row col))
                    ;; Change the current value
                    (vla-SetText tableObj row col "Revised Text")
                    (vla-Update tableObj)
                    (alert "Cell text was changed.")
                    ;; Restore the original value
                    (vla-SetText tableObj row col cellValueOrg)
                    (alert "Cell text was changed back to the original value.")
                    (setq cnt eMax)
            (setq cnt (1+ cnt))
(princ)
GMT+8, 2026-11-6 00:13 , Processed in 0.430632 second(s), 35 queries , Gzip On.
