查看: 1477|回复: 0
[求助] 怎么在64位的cad2014里实现common dialog的功能
发表于 2016-7-29 11:20:21 | 显示全部楼层 |阅读模式
cad2014里不能引用原来vb6.0的common dialog的控件,我在网上,也查了用api的方法调用comdlg32.dll的方法,但是都不起作用,请各位大神帮忙看一下怎么解决!
  1. Public Declare PtrSafe Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOPENFILENAME As OPENFILENAME) As Long
  2. Public Declare PtrSafe Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (pOPENFILENAME As OPENFILENAME) As Long
  3. Type OPENFILENAME
  4.     lStructSize As Long
  5.     hwndOwner As Long
  6.     hInstance As Long
  7.     lpstrFilter As String
  8.     lpstrCustomFilter As String
  9.     nMaxCustFilter As Long
  10.     nFilterIndex As Long
  11.     lpstrFile As String
  12.     nMaxFile As Long
  13.     lpstrFileTitle As String
  14.     nMaxFileTitle As Long
  15.     lpstrInitialDir As String
  16.     lpstrTitle As String
  17.     flags As Long
  18.     nFileOffset As Integer
  19.     nFileExtension As Integer
  20.     lpstrDefExt As String
  21.     lCustData As Long
  22.     lpfnHook As Long
  23.     lpTemplateName As String
  24. End Type
  25. Public Const OFN_OVERWRITEPROMPT = &H2
  26. Public Const OFN_HIDEREADONLY = &H4
  27. Public Const OFN_PATHMUSTEXIST = &H800
  28. Public Const OFN_FILEMUSTEXIST = &H1000
  29. Public Function GetDialog(ByVal sMethod As String, ByVal sTitle As String, ByVal FileType As String, ByVal sFileName As String) As String
  30. 'Public Function GetDialog(ByVal sMethod As String, ByVal sTitle As String, ByVal sFileName As String) As String
  31.     Err.Clear
  32.     On Error GoTo myError
  33.     Dim rtn As Long, Pos As Integer
  34.     Dim file As OPENFILENAME
  35.     'file.lStructSize = Len(file)
  36.     'file.hInstance = ThisDrawing.Application.HWND32
  37.     file.hInstance = ThisDrawing.HWND32
  38.     file.lpstrFile = sFileName & VBA.String$(255 - VBA.Len(sFileName), 0)
  39.     file.nMaxFile = 255
  40.     file.lpstrFileTitle = VBA.String$(255, 0)
  41.     file.nMaxFileTitle = 255
  42.     file.lpstrInitialDir = ""
  43.     'file.lpstrFilter = "Excel文件" & vbNullChar & "*.xls"  '这个为xls文件
  44.     file.lpstrFilter = FileType & vbNullChar & FileType  '这个为xls文件"
  45.     file.lpstrTitle = sTitle
  46.     file.lStructSize = Len(file)
  47.     If VBA.UCase(sMethod) = "OPEN" Then
  48.         file.flags = OFN_HIDEREADONLY + OFN_PATHMUSTEXIST + OFN_FILEMUSTEXIST
  49.         rtn = GetOpenFileName(file)
  50.     Else
  51.         file.lpstrDefExt = "exe"
  52.         file.flags = OFN_HIDEREADONLY + OFN_PATHMUSTEXIST + OFN_OVERWRITEPROMPT
  53.         rtn = GetSaveFileName(file)
  54.     End If
  55.     If rtn > 0 Then
  56.         Pos = InStr(file.lpstrFile, VBA.Chr$(0))
  57.         If Pos > 0 Then
  58.             GetDialog = VBA.Left$(file.lpstrFile, Pos - 1)
  59.         End If
  60.     End If
  61.     Exit Function
  62. myError:
  63.     'Err.Raise
  64.     GetDialog = "FileName Error!"
  65. End Function
GMT+8, 2026-11-22 09:49 , Processed in 0.418667 second(s), 8 queries , Gzip On, File On.
