查看: 1328|回复: 0
[每日一码] .NET存取组
已领礼包: 6个
发表于 2016-8-1 08:49:23 | 显示全部楼层 |阅读模式
How to access AutoCAD Group subsystem via .NET
Issue
I want to extract the ObjectIds that make up a particular Group, how can it be done?
Solution
Here's some sample code written in VB.NET to show how to do what you want.
' Define command 'getGroupIds' - by Fenton Webb, DevTech, Autodesk 12/09/2006
<CommandMethod("getGroupIds")> _
Public Sub getGroupIds()
' input the group name we want to list
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim groupName As PromptResult = ed.GetString("Enter Group name to list : ")
' get the working database
Dim db As Database = Autodesk.AutoCAD.DatabaseServices.HostApplicationServices.WorkingDatabase
' start a transaction
Dim trans As Transaction = db.TransactionManager.StartTransaction()
' now try the read
Try
' get the named objects dictionary
Dim nod As DBDictionary = trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead)
' now get the ACAD_GROUP dictionary entry, this contains all of the Groups defined in the drawing
Dim acadGroup As DBDictionary = trans.GetObject(nod("ACAD_GROUP"), OpenMode.ForRead)
' next, find the group name that was entered above
Dim groupRequired As Group = trans.GetObject(acadGroup(groupName.StringResult), OpenMode.ForRead)
' we now have the group required, lets find out what's inside
Dim entityIds As ObjectId() = groupRequired.GetAllEntityIds()
Dim id As ObjectId
For Each id In entityIds
' open the entity for read
Dim ent As Entity = trans.GetObject(id, OpenMode.ForRead)
' create the highlight path
Dim path As FullSubentityPath = New FullSubentityPath(New ObjectId(0) {id}, New SubentityId(SubentityType.Null, 0))
' now highlight it
ent.Highlight(path, True)
Next
trans.Commit()
Catch ex As Exception
MsgBox(ex.Message)
trans.Dispose()
Finally
End Try
End Sub
GMT+8, 2026-11-3 15:13 , Processed in 0.488574 second(s), 28 queries , Gzip On.
