查看: 4796|回复: 17
[每日一码] 如何把UCS对齐于弧或圆
发表于 2016-8-1 18:24:57 | 显示全部楼层 |阅读模式
问题:
我需要把UCS对齐于弧线实体,我试了用UCS命令跟着E选项,但是我不能控制X、Y的旋转角,我要如何做才能把UCS对齐于弧线呢?
I need to align the UCS with an arc entity in my drawing. I tried using UCS
command with the Entity (E)option, but I have no control over the rotation of
the X and Y axes. How can I set my UCS to correspond with the geometry of my
arc?
回答:
You can use ActiveX from within AutoLISP to create your own UCS based upon the
geometry of your arc entity.  Using ActiveX, you can obtain the arc's normal and
create a vector between the center and the startpoint, then calculate the third
axis from the cross product of the two. Use the Add method of the AcadUCSs
object to create a custom UCS based on the origin of the arc and points along
the X and Y axes, then make the new custom UCS current. The result will change
the UCS to make the origin correspond with the Arc's center, the Y axis will
point to the Startpoint ,the Z Axis will correspond with the arc's normal and
the X Axis will be calculated to be orthogonal to both according to the
right-hand rule. The same solution can be used with circle entities as well with
only slight modifications.
The following example is written n in Visual LISP that performs the operation:
  1. (defun C:UcsArc ()
  2. (vl-load-com)
  3. (setq acadObject (vlax-get-acad-object))
  4. (setq acadDoc (vla-Get-ActiveDocument acadObject))
  5. (setq anEnt (entsel "Select an Arc: "))
  6. (if anEnt
  7.    (progn
  8.      (setq entLst (entget (car anEnt) '("*")))
  9.      (if (equal (cdr (assoc '0 entLst)) "ARC")
  10.             (progn
  11.               (setq arcObj (vlax-ename->vla-object (car anEnt)))
  12.               (setq strtPt (vla-Get-StartPoint arcObj))
  13.               (setq strtPtLst (vlax-safearray->list (vlax-variant-value strtPt)))
  14.               (setq ctrPt (vla-Get-Center arcObj))
  15.               (setq ctrPtLst (vlax-safearray->list (vlax-variant-value ctrPt)))
  16.               (setq Norm (vla-Get-Normal arcObj))
  17.               (setq NormLst (vlax-safearray->list (vlax-variant-value Norm)))
  18.               (setq startVector (doListMinus strtPtLst ctrPtLst))
  19.               (setq r1Vector (doCrossProduct NormLst startVector))
  20.               (setq XAxis (doListMinus ctrPtLst r1Vector))
  21.               (setq UCScollection (vla-Get-UserCoordinateSystems acadDoc))
  22.               (setq ucsOrigin (vlax-3d-Point ctrPtLst) XAxisPoint (vlax-3d-Point
  23. XAxis) YAxisPoint (vlax-3d-Point strtPtLst))
  24.               (if (setq newUCS (vla-Add UCScollection ucsOrigin XAxisPoint
  25. YAxisPoint "ArcUcs"))
  26.                 (princ "Created UCS Definition: ArcUcs"))
  27.               (vla-put-ActiveUCS acadDoc newUCS)
  28.               (if(not(vlax-object-released-p arcObj))
  29.                 (vlax-release-object arcObj))
  30.               (if(not(vlax-object-released-p UCScollection))
  31.                 (vlax-release-object UCScollection))
  32.               )
  33.             )
  34.      )
  35.    )
  36. (if(not(vlax-object-released-p acadObject))
  37.   (vlax-release-object acadObject))
  38. (if(not(vlax-object-released-p acadDoc))
  39.   (vlax-release-object acadDoc))
  40. (princ)
  41. )
  42. ; (setq FstLst strtPtLst S**Lst ctr)
  43. (defun doListMinus (FstLst S**Lst)
  44. (setq X (- (car FstLst) (car S**Lst)))
  45. (setq Y (- (cadr FstLst) (cadr S**Lst)))
  46. (setq Z (- (caddr FstLst) (caddr S**Lst)))
  47. (list X Y Z)
  48. )
求叉积的函数:
游客,如果您要查看本帖隐藏内容请回复
已领礼包: 5800个
发表于 2016-8-2 07:42:55 | 显示全部楼层
谢谢版主的源码,回复,向版主学习
已领礼包: 5800个
发表于 2016-8-2 07:46:06 | 显示全部楼层
谢谢版主的源码,回复,向版主学习
已领礼包: 859个
发表于 2016-8-2 10:16:23 | 显示全部楼层
有点 和 firstderiv  就有了 原点、X 轴 和 xy 平面上点,使用 UCS 命令 也可以
已领礼包: 2965个
财富等级: 家财万贯
发表于 2016-8-2 12:20:24 | 显示全部楼层
good good.
已领礼包: 126个
发表于 2016-8-2 12:52:59 | 显示全部楼层
向版主学习
已领礼包: 2476个
发表于 2016-8-2 17:34:47 | 显示全部楼层
对齐于圆弧怎么讲...
已领礼包: 568个
发表于 2016-9-4 20:49:36 | 显示全部楼层
我也正在学习ucs命令
已领礼包: 6056个
发表于 2016-11-20 19:13:22 | 显示全部楼层
 精彩好文。
已领礼包: 1337个
发表于 2017-7-21 13:01:07 | 显示全部楼层
回复学习下!多谢分享!
已领礼包: 216个
发表于 2020-1-17 14:05:12 | 显示全部楼层
顶一顶顶一顶
发表于 2020-2-3 00:18:21 | 显示全部楼层
回复学习下!多谢分享!
已领礼包: 9341个
发表于 2020-2-3 18:14:51 | 显示全部楼层
回复学习!谢谢分享!
已领礼包: 7214个
发表于 2020-2-5 15:15:47 | 显示全部楼层
多谢分享!
已领礼包: 6881个
发表于 2022-12-28 12:24:43 | 显示全部楼层
谢谢版主的分享
GMT+8, 2026-11-2 23:55 , Processed in 0.527641 second(s), 60 queries , Gzip On.
