查看: 2481|回复: 2
[每日一码] 打开一个DWG文件并加载到自己命名的LAYOUT中
发表于 2016-8-5 21:08:39 | 显示全部楼层 |阅读模式
  1. (defun C:LayoutImport()
  2.   ;; Select a DWG file to import a Layout
  3.         (setq myFile (getfiled "Select your DWG File:" " " "dwg" 8))
  4.         (command"layout" "t" myFile "ABC")
  5.         (alert "New Layout is inserted!")
  6.         (princ)
  7. )
已领礼包: 1094个
发表于 2021-9-8 06:15:09 | 显示全部楼层
感谢楼主分享 打开一个DWG文件并加载到自己命名的LAYOUT中
GMT+8, 2026-11-3 07:42 , Processed in 0.483871 second(s), 34 queries , Gzip On.
