查看: 2440|回复: 0
[每日一码] 打印AcDbLineTypeTableRecord线型定义引用的SHX文件名
已领礼包: 13个
发表于 2016-8-12 19:03:38 | 显示全部楼层 |阅读模式
问题:
I need to find a compiled shape file (shx) used by an AcDbLinetypeTableRecord class. How can I determine what shape a linetype uses?
解决方案:
If a line type uses a shx file it will reference an AcDbTextStyleTableRecord. Here is an example that prints the names of the shx file used by the ZIGZAG linetype in acad.lin.
  1. static void ASDKwbTEST(void)
  2. {
  3.    AcDbDatabase* pDb = curDoc()->database();
  4.   assert(pDb);
  5.   //get line type table
  6.   AcDbLinetypeTable *pLTTable ;
  7.   acdbOpenObject(pLTTable,pDb->linetypeTableId(),AcDb::kForRead);
  8.   AcDbLinetypeTableRecord *pLTRecord = NULL ;
  9.   AcDbObjectId objLTId ;
  10.   //pLTTable->getAt(_T("TRACKS"), objLTId) ;
  11.   pLTTable->getAt(_T("ZIGZAG"), objLTId) ;
  12.   pLTTable->close();
  13.   Acad::ErrorStatus es = acdbOpenObject((AcDbObject *&)pLTRecord, objLTId, AcDb::kForRead) ;
  14.   if(es != Acad::eOk)
  15.   {
  16.    acutPrintf(_T("ZIGZAG linetype not loaded"));
  17.         return;
  18.   }
  19.            //iterate through the linetype
  20.   int dashes = pLTRecord->numDashes();
  21.   for(int c = 0; c < dashes; c++)
  22.   {
  23.    int shpnum = pLTRecord->shapeNumberAt(c) ;
  24.    if(shpnum != 0)
  25.    {
  26.    AcDbTextStyleTableRecord *pTSRecord = NULL ;
  27.    AcDbObjectId objTSId = pLTRecord->shapeStyleAt(c);
  28.    pLTRecord->close();
  29.    acdbOpenObject((AcDbObject*&)pTSRecord,objTSId,AcDb::kForRead);
  30.    assert(pTSRecord);
  31.    const ACHAR *pName ;
  32.    Acad::ErrorStatus es = pTSRecord->fileName(pName);
  33.    pTSRecord->close();
  34.    acutPrintf(_T("\nName of shape file = %s"),pName);
  35.    }
  36.   }
  37. }
下面是.net实现代码:
Here is a VB.NET example:
  1. <CommandMethod("getShpName")> _
  2.     Public Sub GetShapeName()
  3.         Dim LtypeNames As New ArrayList()
  4.         Dim TextStyleNames As New ArrayList()
  5.         Dim db As Database = HostApplicationServices.WorkingDatabase()
  6.         Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
  7.         Dim tm As Transaction = db.TransactionManager.StartTransaction()
  8.         Try
  9.             Dim lineTypTbl As LinetypeTable = tm.GetObject(db.LinetypeTableId, OpenMode.ForRead)
  10.             Dim ltTblRec As LinetypeTableRecord
  11.             Dim txtStyleTblRec As TextStyleTableRecord
  12.             ltTblRec = tm.GetObject(lineTypTbl("ZigZag"), OpenMode.ForRead)
  13.             'iterate through the linetype
  14.             Dim intDashes As Integer = ltTblRec.NumDashes
  15.             Dim i As Integer
  16.             Dim iShpNum As Integer
  17.             For i = 0 To intDashes - 1
  18.                 iShpNum = ltTblRec.ShapeNumberAt(i)
  19.                 If iShpNum <> 0 Then
  20.                     Dim txtStylTblRecObjId As ObjectId = ltTblRec.ShapeStyleAt(i)
  21.                     txtStyleTblRec = tm.GetObject(txtStylTblRecObjId, OpenMode.ForRead)
  22.                     ed.WriteMessage("Name of  " & txtStyleTblRec.FileName.ToString() & vbCrLf)
  23.                 End If
  24.             Next
  25.             tm.Commit()
  26.         Catch ex As System.Exception
  27.             ed.WriteMessage(ex.ToString())
  28.         Finally
  29.             tm.Dispose()
  30.         End Try
  31.     End Sub
GMT+8, 2026-11-3 06:19 , Processed in 0.404545 second(s), 28 queries , Gzip On.
