查看: 1538|回复: 0
[每日一码] 如何通过程序创建一个多线样式(AcDbMlineStyle)
已领礼包: 13个
发表于 2016-8-13 14:59:29 | 显示全部楼层 |阅读模式
见下面代码:
  1. // minimal error checking for code brevity
  2. void createMlineStyle()
  3. {
  4.     AcDbLinetypeTable* pTable = NULL;
  5. AcDbObjectId id;
  6. AcDbDatabase* pDb = curDoc()->database();
  7. // open ByLayer linetypetablerecord for use in MLineStyle later
  8. pDb->getLinetypeTable(pTable, AcDb::kForRead);
  9. if((pTable->getAt(L"ByLayer", id)) != Acad::eOk)
  10. {
  11.     acutPrintf(L"\nlinetype ByLayer not found.");
  12.     return;
  13. }
  14. pTable->close();
  15.     AcDbDictionary* pDict = NULL;
  16. // open MLStyleDictionary (its sored in the NOD)
  17. Acad::ErrorStatus es = pDb->getMLStyleDictionary(pDict, AcDb::kForRead);
  18. if(es != Acad::eOk)
  19. {
  20.   acutPrintf(L"\nCan't open mline style dictionary for read.");
  21.   return;
  22. }
  23. const ACHAR mlineStyleName[] = L"test";
  24. AcDbMlineStyle* ps = NULL;
  25. // does MLStyle "test" already exist?
  26. es = pDict->getAt(mlineStyleName, (AcDbObject*&)ps, AcDb::kForWrite);
  27. // If it doesn't exist, create it
  28. if(es != Acad::eOk)
  29. {
  30.   ps = new AcDbMlineStyle;
  31.   AcDbObjectId mId;
  32.   ps->initMlineStyle();
  33.   pDict->upgradeOpen();
  34.   pDict->setAt(mlineStyleName, ps, mId);
  35. }
  36. pDict->close();
  37.     // set MLStyle attributes and elements
  38. es = ps->setName(mlineStyleName);
  39. AcCmColor cm;     cm.setColorIndex(256);
  40.     int a=0, b=0;
  41. es = ps->addElement(a, -0.25, cm, id);
  42. assert(es == Acad::eOk);
  43. es = ps->addElement(b, 0.25, cm, id);
  44.     assert(es == Acad::eOk);
  45. ps->close();
  46. acutPrintf(L"\nMline style: %s created.", mlineStyleName);
  47. }
GMT+8, 2026-11-3 06:08 , Processed in 0.419422 second(s), 28 queries , Gzip On.
