查看: 1513|回复: 0
[每日一码] 使用ARX创建线型(AcDbLinetypeTableRecord)
已领礼包: 13个
发表于 2016-8-15 09:30:05 | 显示全部楼层 |阅读模式
Creating a linetype using ARX
Question
How can I create a linetype using ARX?
Answer
The sample code below creates a linetype using ARX:
  1. #include "dbmain.h"
  2. #include "dbsymtb.h"
  3. void utilsarxtest ()     {
  4.     AcDbLinetypeTable *pLtypeTable =NULL ;
  5.     // get the linetype table from the drawing
  6.     if ( acdbHostApplicationServices()->workingDatabase()->getLinetypeTable (pLtypeTable, AcDb::kForWrite) ==
  7. Acad::eOk ) {
  8.         AcDbLinetypeTableRecord *pLtypeTableRecord =new
  9. AcDbLinetypeTableRecord ;
  10.         // set all of the properties of the linetype table record.
  11.         pLtypeTableRecord->setAsciiDescription ("T E S T -") ;
  12.         pLtypeTableRecord->setPatternLength (0.75) ;
  13.         pLtypeTableRecord->setNumDashes (2) ;
  14.         pLtypeTableRecord->setDashLengthAt (0, 0.5) ;
  15.         pLtypeTableRecord->setDashLengthAt (1,-0.25) ;
  16.         pLtypeTableRecord->setName ("ASTESTER") ;
  17.         AcDbObjectId tmpId ;
  18.         // add the pLtypeTableRecord to the linetype table
  19.         if (pLtypeTable->add (tmpId, pLtypeTableRecord)==Acad::eOk){
  20.             pLtypeTableRecord->close () ;
  21.         } else {
  22.             delete pLtypeTableRecord ;
  23.         }
  24.         // close everything up
  25.         pLtypeTable->close () ;
  26.     }
  27. }
GMT+8, 2026-11-3 03:11 , Processed in 0.473876 second(s), 28 queries , Gzip On.
