查看: 1783|回复: 1
[每日一码] 字符串函数名转换成函数调用
发表于 2016-8-15 09:00:03 | 显示全部楼层 |阅读模式
Calling an AutoLISP function if the function name is a string?
Question
How can to call an AutoLISP function if the function name is available as a string?
Answer
This can be achieved by using (eval (read "string")).
  1. (defun adcg_function ()
  2.    (princ "\nDeveloper Consulting Group")
  3. )
  4. (defun c:test ()
  5.    (setq fname "adcg_function")
  6.    (eval (read fname))
  7. )
  8. (prompt "\nCommand : test defined")
  9. (princ)
已领礼包: 1094个
发表于 2021-9-16 00:05:19 | 显示全部楼层
感谢分享字符串函数名转换成函数调用
GMT+8, 2026-11-3 07:38 , Processed in 0.419878 second(s), 30 queries , Gzip On.
