查看: 1135|回复: 0
[每日一码] 如何封闭SPLINE?
已领礼包: 13个
发表于 2016-8-15 15:00:01 | 显示全部楼层 |阅读模式
How to close an AcDbSpline?
By Augusto Goncalves
There is no specific isClosed() method defined for AcDbSpline as there is for
AcDbPolyline. However, in many cases, an AcDbSpline can be closed. Here is a
simple solution to implement a setClosed function for splines. It uses the
getNurbsData() and setNurbsData() AcDbSpline methods. getNurbsData will gather
the information about the spline, including a Boolean closed that indicates if
the spline is closed or not. setNurbsData() takes the same arguments as
getNurbsData(), so only the closed argument will be changed to Adesk::kTrue to
obtain the desired result.
And the same idea can be applied to the .NET Spline.NurbData property.
  1. void setClosed(AcDbSpline *pSpline)
  2. {
  3.     int          degree;
  4.     Adesk::Boolean    rational;
  5.     Adesk::Boolean    closed;
  6.     Adesk::Boolean    periodic;
  7.     AcGePoint3dArray  controlPoints;
  8.     AcGeDoubleArray    knots;
  9.     AcGeDoubleArray    weights;
  10.     double        controlPtTol;
  11.     double        knotTol;
  12.   // get data from the spline
  13.     pSpline->getNurbsData(degree, rational, closed, periodic,
  14.                  controlPoints, knots, weights,
  15.                  controlPtTol, knotTol);
  16.   if(closed == Adesk::kTrue)
  17.         return;
  18.   // set as closed
  19.   closed = Adesk::kTrue;
  20.   // apply data back
  21.     pSpline->setNurbsData(degree, rational, closed, periodic,
  22.                  controlPoints, knots, weights,
  23.                  controlPtTol, knotTol);
  24. }
GMT+8, 2026-11-3 06:09 , Processed in 0.379437 second(s), 28 queries , Gzip On.
