查看: 2598|回复: 3
[每日一码] LISP坐标标注程序
发表于 2016-8-14 17:47:22 | 显示全部楼层 |阅读模式
  1. (defun c:dx (/ os or pt1 ptx1 ptx2 ptx pty ptz lx ly lz l1 l2 pt2 h1 h a a2
  2.                b c d pt3 pt4 pt5 pt6
  3.             )
  4.   (setq os (getvar "osmode"))
  5.   (setvar "osmode" 45)
  6.   (setq pt1 (getpoint "\n请点选要标注坐标的点:"))
  7.   (setq ptx (rtos (car pt1) 2 2))
  8.   (setq pty (rtos (cadr pt1) 2 2))
  9.   (setq ptz (rtos (caddr pt1) 2 2))
  10.   (setq lx (strlen ptx)
  11.         ly (strlen pty)
  12.         lz (strlen ptz)
  13.   )
  14.   (if (> lx ly)
  15.     (setq l1 (+ lx 2))
  16.     (setq l1 (+ ly 2))
  17.   )
  18.   (setq l2 (1+ lz))
  19.   (setvar "osmode" 0)
  20.   (setq pt2 (getpoint pt1 "\n请点选坐标放置的位置:"))
  21.   (setq ptx1 (car pt1)
  22.         ptx2 (car pt2)
  23.   )
  24.   (setq h1 (getvar "TEXTSIZE"))
  25.   (setq h (getreal (strcat "\n请键入文字高度<" (rtos h1 2 2) ">:")))
  26.   (if (null h)
  27.     (setq h h1)
  28.   )
  29.   (setq a (* l1 h 0.7)
  30.         a2 (* l2 h 0.7)
  31.         b (sqrt (* (* 0.5 h 0.7) (* 0.5 h 0.7) 2))
  32.         c (* 1.6 h)
  33.         d (sqrt (+ (* (* 0.5 h 0.7) (* 0.5 h 0.7)) (* a a2)))
  34.   )
  35.   (if (> ptx2 ptx1)
  36.     (setq pt3 (polar pt2 0 a)
  37.           pt4 (polar pt2 (/ pi 4) b)
  38.           pt5 (polar pt4 (* 1.5 pi) c)
  39.           pt6 (polar pt3 (/ (* 7 pi) 4) b)
  40.     )
  41.     (setq pt3 (polar pt2 pi a)
  42.           pt4 (polar pt3 (/ pi 4) b)
  43.           pt5 (polar pt4 (* 1.5 pi) c)
  44.           pt6 (polar pt3 (+ pi (atan 1 (* 2 12))) d)
  45.     )
  46.   )                                       ;  (setq or (getvar "clayer"))
  47.                                        ;  (command "layer" "m" "坐标-引线"
  48.                                        ; "co" "5" "" "s" or "")
  49.                                        ;  (command "LINE" pt1 pt2 ""
  50.                                        ;  "change" "l" "" "P" "la"
  51.                                        ; "坐标-引线" ""
  52.                                        ;  "LINE" pt2 pt3 ""
  53.                                        ;  "change" "l" "" "P" "la"
  54.                                        ; "坐标-引线" "")
  55.                                        ;  (command "layer" "m" "坐标-文字"
  56.                                        ; "co" "6" "" "s" or "")
  57.                                        ;  (command "TEXT" pt4 h 0 (princ
  58.                                        ; (strcat "X=" pty)) ""
  59.                                        ;  "change" "l" "" "P" "la"
  60.                                        ; "坐标-文字" ""
  61.                                        ;  "TEXT" pt5 h 0 (princ (strcat
  62.                                        ; "Y=" ptx)) ""
  63.                                        ;  "change" "l" "" "P" "la"
  64.                                        ; "坐标-文字" ""
  65.                                        ;  "redraw"
  66.                                        ;  "osmode" os
  67.   (command "LINE" pt1 pt2 pt3 "")
  68.   (command "TEXT" pt4 h 0 (princ (strcat "X=" ptx)) "TEXT" pt5 h 0
  69.            (princ (strcat "Y=" pty)) "osmode" os
  70.   )
  71.   (princ)
  72. )
已领礼包: 1094个
发表于 2021-9-14 07:34:21 | 显示全部楼层
感谢楼主分享LISP坐标标注程序
发表于 2021-10-10 22:00:09 | 显示全部楼层
感谢楼主分享LISP坐标标注程序
已领礼包: 5个
发表于 2024-6-24 21:06:37 | 显示全部楼层
这个可以批量标注XYZ吗
GMT+8, 2026-11-3 07:41 , Processed in 0.476186 second(s), 35 queries , Gzip On.
