查看: 1409|回复: 0
[每日一码] 使用Editor.SelectAll()时候,如果过滤掉冻结层的实体
已领礼包: 6个
发表于 2016-8-18 19:26:35 | 显示全部楼层 |阅读模式
When using Editor.SelectAll(), how can I filter entities on frozen layers out? (.NET)
Issue
If I call Editor.SelectAll(), will it return only entities currently visible on the screen?
Solution
No, Editor.SelectAll() returns also entities, which are placed on frozen layers. In our program we need to check whether an entity's layer is frozen. Here is a sample:
  1.     [CommandMethod("SANF")]
  2.     public static void SelectAllExceptFrozenLayers()
  3.     {
  4.       Document doc = Application.DocumentManager.MdiActiveDocument;
  5.       Editor ed = doc.Editor;
  6.       PromptSelectionResult selection = ed.SelectAll();
  7.       if (selection.Status == PromptStatus.OK)
  8.       {
  9.         using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
  10.         {
  11.           foreach (ObjectId id in selection.Value.GetObjectIds())
  12.           {
  13.             Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
  14.             LayerTableRecord layer = (LayerTableRecord)tr.GetObject(ent.LayerId, OpenMode.ForRead);
  15.             if( ! layer.IsFrozen )
  16.               ed.WriteMessage("\n{0}", ent.ToString());
  17.           }
  18.           tr.Commit();
  19.         } // using
  20.       } // if
  21.     } // SelectAllExceptFrozenLayers()
GMT+8, 2026-11-3 07:32 , Processed in 0.379119 second(s), 28 queries , Gzip On.
