查看: 1193|回复: 0
[每日一码] 改变RasterImage 名字
已领礼包: 6个
发表于 2016-8-29 13:31:44 | 显示全部楼层 |阅读模式
  1. Document doc = Application.DocumentManager.MdiActiveDocument;
  2. Editor ed = doc.Editor;
  3. Database db = doc.Database;
  4. PromptStringOptions pso1
  5.         = new PromptStringOptions("\nEnter old image name : ");
  6. pso1.AllowSpaces = true;
  7. PromptResult pr1 = ed.GetString(pso1);
  8. if (pr1.Status != PromptStatus.OK)
  9.     return;
  10. String oldImageName = pr1.StringResult;
  11. PromptStringOptions pso2
  12.         = new PromptStringOptions("\nEnter new image name : ");
  13. pso2.AllowSpaces = true;
  14. PromptResult pr2 = ed.GetString(pso2);
  15. if (pr2.Status != PromptStatus.OK)
  16.     return;
  17. String newImageName = pr2.StringResult;
  18. ObjectId oldridId = ObjectId.Null;
  19. ObjectId newridId = ObjectId.Null;
  20. using (Transaction tr = db.TransactionManager.StartTransaction())
  21. {
  22.     ObjectId dictId = RasterImageDef.GetImageDictionary(db);
  23.     if (! dictId.IsNull)
  24.     {
  25.         DBDictionary dict = tr.GetObject(
  26.                                             dictId,
  27.                                             OpenMode.ForRead
  28.                                         ) as DBDictionary;
  29.         if (dict.Contains(oldImageName))
  30.         {
  31.             // Step 1: Create a new RasterImageDef based on
  32.             // the old RasterImageDef
  33.             oldridId = dict.GetAt(oldImageName);
  34.             RasterImageDef oldrid = tr.GetObject(
  35.                                                     oldridId,
  36.                                                     OpenMode.ForWrite
  37.                                                 ) as RasterImageDef;
  38.             RasterImageDef newrid = new RasterImageDef();
  39.             newrid.SourceFileName = oldrid.SourceFileName;
  40.             newrid.ActiveFileName = oldrid.ActiveFileName;
  41.             newrid.Load();
  42.             dict.UpgradeOpen();
  43.             newridId = dict.SetAt(newImageName, newrid);
  44.             tr.AddNewlyCreatedDBObject(newrid, true);
  45.             // Step 2: Associate the existing raster images
  46.             // with the newly created RasterImageDef
  47.             RasterImage.EnableReactors(true);
  48.             BlockTable bt = tr.GetObject(
  49.                                             db.BlockTableId,
  50.                                             OpenMode.ForRead
  51.                                         ) as BlockTable;
  52.             foreach (ObjectId btrId in bt)
  53.             {
  54.                 BlockTableRecord btr = tr.GetObject
  55.                                         (
  56.                                             btrId,
  57.                                             OpenMode.ForRead
  58.                                         ) as BlockTableRecord;
  59.                 foreach (ObjectId id in btr)
  60.                 {
  61.                     if (id.ObjectClass.IsDerivedFrom(
  62.                         RXClass.GetClass(typeof(RasterImage))))
  63.                     {
  64.                         RasterImage ri = tr.GetObject
  65.                                             (
  66.                                                 id,
  67.                                                 OpenMode.ForRead
  68.                                             ) as RasterImage;
  69.                         if (ri.ImageDefId.Equals(oldridId))
  70.                         {
  71.                             ri.UpgradeOpen();
  72.                             ri.AssociateRasterDef(newrid);
  73.                             ri.ImageDefId = newridId;
  74.                         }
  75.                     }
  76.                 }
  77.             }
  78.             // Step 3 : Detach and erase the old RasterImageDef
  79.             RasterImage.EnableReactors(false);
  80.             oldrid.Unload(true);
  81.             oldrid.Erase();
  82.         }
  83.     }
  84.     tr.Commit();
  85. }
  86. // Resolve Xrefs
  87. db.ResolveXrefs(false, false);
GMT+8, 2026-11-3 07:28 , Processed in 0.530998 second(s), 28 queries , Gzip On.
