查看: 24122|回复: 149
[每日一码] LISP找离散点边界
 火.. [复制链接]
发表于 2016-8-29 23:25:37 | 显示全部楼层 |阅读模式
[it618postdisplay>0]
  1. (defun c:getarea (/)
  2.   (defun min-of-list (mylist /)
  3.     (setq mymidList nil)
  4.     (setq L (length mylist))
  5.     (setq j 1)
  6.     (setq ax (nth 0 mylist))
  7.     (repeat (- L 1)
  8.       (setq bx (nth j mylist))
  9.       (if (< bx ax)
  10.         (setq ax bx)
  11.       )
  12.       (setq j (1+ j))
  13.     )
  14.     (setq ax ax)
  15.   )                                       ; 自定义函数求表中最小值
  16.   (defun max-of-list (mylist /)
  17.     (setq mymidList nil)
  18.     (setq L (length mylist))
  19.     (setq j 1)
  20.     (setq ax (nth 0 mylist))
  21.     (repeat (- L 1)
  22.       (setq bx (nth j mylist))
  23.       (if (> bx ax)
  24.         (setq ax bx)
  25.       )
  26.       (setq j (1+ j))
  27.     )
  28.     (setq ax ax)
  29.   )                                       ; 自定义函数求表中最大值
  30.   (defun deleteList (myList coord /)
  31.     (setq mymidList nil)
  32.     (setq len (length myList))
  33.     (setq nnn 0)
  34.     (while (< nnn len)
  35.       (if (/= nnn coord)
  36.         (setq mymidList (cons (nth nnn myList) mymidList))
  37.       )
  38.       (setq nnn (1+ nnn))
  39.     )
  40.     (setq re (reverse mymidList))
  41.   )                                       ; 自定义删除表元素
  42.   ;; (setq k (getint  "局部扫描区域半边长,取水平方向最近点距离的1.7倍"))
  43.   (setq ss (ssget))
  44.   (setq n (sslength ss))
  45.   (setq list_pt nil)
  46.   (setq i 0)
  47.   (repeat n
  48.     (setq spt (ssname ss i))
  49.     (setq ept (entget spt))
  50.     (setq l (length ept))
  51.     (setq xyz (cdr (assoc 10 ept)))
  52.     (setq list_pt (cons xyz list_pt))
  53.     (setq i (1+ i))
  54.   )                                       ; 将全部点制表
  55.   (setq n0 (sslength ss))
  56.   (setq listofAx nil)
  57.   (setq i 0)
  58.   (repeat n0
  59.     (setq Ax (car (nth i list_pt)))
  60.     (setq listofAx (cons Ax listofAx))
  61.     (setq i (1+ i))
  62.   )
  63.   (setq Ax1 (min-of-list listofAx))    ; 找到最小x坐标
  64.   (setq Ax2 (max-of-list listofAx))    ; 找到最大x坐标
  65.   (setq j 0)
  66.   (repeat l
  67.     (setq Rx (car (nth j list_pt)))    ; 取表中任意一点
  68.     (if (equal Rx Ax1)
  69.       (progn
  70.         (setq Ay1 (car (cdr (nth j list_pt))))
  71.         (setq Az1 (car (cdr (cdr (nth j list_pt)))))
  72.       )
  73.     )
  74.     (if (equal Rx Ax2)
  75.       (progn
  76.         (setq Ay2 (car (cdr (nth j list_pt))))
  77.         (setq Az2 (car (cdr (cdr (nth j list_pt)))))
  78.       )
  79.     )
  80.     (setq j (1+ j))
  81.   )
  82.   (setq pstart (list Ax1 Ay1 Az1))     ; 找到起始点坐标
  83.   (setq pstart0 pstart)
  84.   (setq Ax0 Ax1)
  85.   (setq Ay0 Ay1)
  86.   (setq Az0 Az1)
  87.   (setq pstart0 (list Ax0 Ay0 Az0))    ; 将起始点赋给pstart0,方便以后循环调
  88.                                        ; 用
  89.   (setq pend (list Ax2 Ay2 Az2))       ; 找到终点坐标
  90.   (setq n1 1)
  91.   (while (> n1 0)                       ; 第一个大循环开始
  92.     (setq rx (+ Ax1 6))
  93.     (setq lx (- Ax1 6))
  94.     (setq uy (+ Ay1 6))
  95.     (setq ly (- Ay1 6))                       ; 确定局部扫描范围
  96.     (setq list_new nil)
  97.     (setq j 0)
  98.     (setq l (length list_pt))
  99.     (repeat l
  100.       (setq pt (nth j list_pt))
  101.       (setq ptx (car pt))
  102.       (setq pty (car (cdr pt)))
  103.       (if (and
  104.             (and
  105.               (< ptx rx)
  106.               (> ptx lx)
  107.             )
  108.             (and
  109.               (< pty uy)
  110.               (> pty ly)
  111.             )
  112.           )
  113.         (setq list_new (cons pt list_new))
  114.       )
  115.       (setq j (1+ j))
  116.     )                                       ; 找到小范围内点
  117.     (setq l (length list_new))
  118.     (setq list_ne nil)
  119.     (setq n 0)
  120.     (repeat l
  121.       (if (equal (nth n list_new) pstart)
  122.         (setq temp n)
  123.       )
  124.       (setq n (1+ n))
  125.     )
  126.     (setq list_new (deletelist list_new temp)) ; 删除倒序排列表中与pstart相?
  127.                                        ; ??
  128.     (setq list_ne list_new)               ; 点倒序排列的表
  129.     (setq list_new (reverse list_new))
  130.     (setq l (length list_new))
  131.     (setq angleAjlist nil)
  132.     (setq angleBjlist nil)
  133.     (setq n 0)
  134.     (repeat l
  135.       (setq A1 (nth n list_new))
  136.       (setq angleBj (angle pstart A1))
  137.       (setq angleBjlist (cons angleBj angleBjlist)) ; B角是倒序的(与对应点?
  138.                                        ; 喾矗?
  139.       (if (> angleBj 1.58)
  140.         (setq angleAj (- 7.85 angleBj))
  141.         (setq angleAj (- 1.57 angleBj))
  142.       )
  143.       (setq angleAjlist (cons angleAj angleAjlist)) ; A角是顺序的(同对应点?
  144.                                        ; ?
  145.       (setq n (1+ n))
  146.     )
  147.     (setq minangleAj (min-of-list angleAjlist))        ; 调用自定义函数求表中最小元
  148.                                        ; 素
  149.     (setq l (length angleAjlist))
  150.     (setq n 0)
  151.     (repeat l
  152.       (setq na (nth n angleAjlist))
  153.       (if (= minangleAj na)
  154.         (setq temp n)
  155.       )
  156.       (setq n (1+ n))
  157.     )
  158.     (setq pa (nth temp list_ne))       ; 找到最小角对应点
  159.     (progn
  160.       (command "line" pstart pa "")
  161.       (setq pstart pa)
  162.       (setq Ax1 (car pstart))
  163.       (setq Ay1 (car (cdr pstart)))    ; (setq pstart(list 100 200 300))
  164.       (setq Az1 (car (cdr (cdr pstart))))
  165.     )
  166.     (if (equal pstart pend)
  167.       (setq n1 -1)
  168.     )
  169.   )                                       ; 第一大循环结束
  170.   (setq pstart pstart0)
  171.   (setq Ax1 Ax0)
  172.   (setq Ay1 Ay0)
  173.   (setq Az1 Az0)
  174.   (setq pend (list Ax2 Ay2 Az2))
  175.   (setq jbmaxangleAj (* 1 pi))
  176.   (setq n2 1)
  177.   (while (> n2 0)                       ; 第二大循环开始
  178.     (setq rx (+ Ax1 6))
  179.     (setq lx (- Ax1 6))
  180.     (setq uy (+ Ay1 6))
  181.     (setq ly (- Ay1 6))                       ; 确定局部扫描范围
  182.     (setq list_new nil)
  183.     (setq j 0)
  184.     (setq l (length list_pt))
  185.     (repeat l
  186.       (setq npt (nth j list_pt))
  187.       (setq nptx (car npt))
  188.       (setq npty (car (cdr npt)))
  189.       (if (and
  190.             (and
  191.               (< nptx rx)
  192.               (> nptx lx)
  193.             )
  194.             (and
  195.               (< npty uy)
  196.               (> npty ly)
  197.             )
  198.           )
  199.         (setq list_new (cons npt list_new))
  200.       )
  201.       (setq j (1+ j))
  202.     )                                       ; 找到小范围内点
  203.     (setq l (length list_new))
  204.     (setq list_ne nil)
  205.     (setq n 0)
  206.     (repeat l
  207.       (if (equal (nth n list_new) pstart)
  208.         (setq temp n)
  209.       )
  210.       (setq n (1+ n))
  211.     )
  212.     (setq list_new (deletelist list_new temp)) ; 删除倒序排列表中与pstart相?
  213.                                        ; ??
  214.     (setq list_ne list_new)               ; 点倒序排列的表
  215.     (setq list_new (reverse list_new))
  216.     (setq l (length list_new))
  217.     (setq angleAjlist nil)
  218.     (setq angleBjlist nil)
  219.     (setq n 0)
  220.     (repeat l
  221.       (setq A1 (nth n list_new))
  222.       (setq angleBj (angle pstart A1))
  223.       (setq angleBjlist (cons angleBj angleBjlist)) ; B角是倒序的(与对应点?
  224.                                        ; 喾矗?
  225.       (if (> angleBj 1.58)
  226.         (setq angleAj (- 7.85 angleBj))
  227.         (setq angleAj (- 1.57 angleBj))
  228.       )
  229.       (setq angleAjlist (cons angleAj angleAjlist)) ; A角是反序的(同对应点?
  230.                                        ; ?
  231.       (setq n (1+ n))
  232.     )
  233.     (setq jbangleAjlist nil)
  234.     (setq l (length list_new))
  235.     (setq n 0)
  236.     (repeat l
  237.       (setq angleAj (nth n angleAjlist))
  238.       (if (and
  239.             (> angleAj (- jbmaxangleAj 1.2))
  240.             (< angleAj (+ jbmaxangleAj 2))
  241.           )
  242.         (setq jbangleAjlist (cons angleAj jbangleAjlist))
  243.       )
  244.       (setq n (1+ n))
  245.     )
  246.     (setq jbmaxangleAj (max-of-list jbangleAjlist)) ; 调用自定义函数求表中最
  247.                                        ; 大元素
  248.     (setq bb jbmaxangleAj)
  249.     ;; (setq maxangleAj(max-of-list
  250.     ;; angleAjlist));;;;;;;;;;;;;;;;;;;;调用自定义函数求表中最大元素
  251.     (setq l (length angleAjlist))
  252.     (setq n 0)
  253.     (repeat l
  254.       (setq na (nth n angleAjlist))
  255.       (if (= jbmaxangleAj na)
  256.         (setq temp n)
  257.       )
  258.       (setq n (1+ n))
  259.     )
  260.     (setq pa (nth temp list_ne))       ; 找到最大角对应点
  261.     (progn
  262.       (command "line" pstart pa "")
  263.       (setq pstart pa)
  264.       (setq Ax1 (car pstart))
  265.       (setq Ay1 (car (cdr pstart)))
  266.       (setq Az1 (car (cdr (cdr pstart))))
  267.     )
  268.     ;; (setq list_pused(cons list_new list_pused))
  269.     (if (equal pstart pend)
  270.       (setq n2 -1)
  271.     )
  272.     (setq jbmaxangleAj bb)
  273.   )                                       ; 第二大循环结束
  274. )
[/it618postdisplay]
已领礼包: 4044个
发表于 2016-8-30 08:07:06 | 显示全部楼层
回复学习学习!
已领礼包: 5800个
发表于 2016-8-30 08:25:12 | 显示全部楼层
回复,见习一下程序
已领礼包: 2965个
财富等级: 家财万贯
发表于 2016-8-30 08:39:36 | 显示全部楼层
回复学习好习惯
已领礼包: 3777个
发表于 2016-8-30 11:03:16 | 显示全部楼层
见习一下程序
已领礼包: 3777个
发表于 2016-8-30 11:09:22 | 显示全部楼层
没有搞明白这个插件的作用,也没有看见返回的东西
发表于 2016-8-30 11:11:30 | 显示全部楼层
是不是凸包边外轮廓?
已领礼包: 1229个
发表于 2016-8-30 14:42:17 | 显示全部楼层
看看插件!
已领礼包: 720个
发表于 2016-8-30 20:19:57 | 显示全部楼层
             经典
发表于 2016-8-31 00:57:51 | 显示全部楼层
看一下是什么东西
发表于 2016-8-31 06:54:09 | 显示全部楼层
学习》》》》》》》》》》》》
已领礼包: 4个
发表于 2016-8-31 10:42:44 | 显示全部楼层
kankankankan
已领礼包: 2476个
发表于 2016-8-31 16:50:22 | 显示全部楼层
ms不止一个解哟...看看..
已领礼包: 2226个
发表于 2016-8-31 17:04:12 | 显示全部楼层
回复,见习一下程序
已领礼包: 194个
发表于 2016-9-1 09:20:11 | 显示全部楼层
感谢分享!!!!
GMT+8, 2026-11-3 17:05 , Processed in 0.554499 second(s), 60 queries , Gzip On.
