查看: 6621|回复: 15
[每日一码] Inserting RasterImage using image buffer
发表于 2016-9-6 08:30:00 | 显示全部楼层 |阅读模式
如果你不需要保存插入的光栅图像的路径的话,可以使用AcDbRasterImageDef::setImage方法。AcDbRasterImageDef::setImage需要一个指向ATIL图像对象的指针,在下面的示例代码红,图像缓冲器从图像和ATIL图像读取信息,使用ATIL图像的指针作为使用AcDbRasterImageDef::setImage 的定义。
为了使用下面的代码,你需要从ObjectARX SDK folder under "\utils\Atil"目录INCLUE和LIB需要的文件。
The AcDbRasterImageDef::setImage can be used, if you do not want to include the image file path while inserting a raster image. This can be considered another approach to accomplish what is explained in this blog post. The AcDbRasterImageDef::setImage method requires a pointer to an ATIL image. In this sample code, the image buffer is read from the image and is used to create an ATIL image. The ATIL image pointer is used with the AcDbRasterImageDef::setImage to create a raster image definition. To build this sample code, you will need the include and library files from the ObjectARX SDK folder under "\utils\Atil".
  1. static void AdskInsertImage(void)
  2. {
  3.     // Image path to use for the RasterImageDef
  4.     AcString imagePath(ACRX_T("C:\\Temp\\Test.png"));
  5.     // Load the image to get access to its image buffer
  6.     AcTcImage tc;
  7.     tc.Load(imagePath);
  8.     HBITMAP bmp=0;
  9.     tc.GetHBITMAP(RGB(0xff,0xff,0xff),bmp);
  10.     if (bmp == NULL)
  11.         return;
  12.     BITMAP _bmp={0};
  13.     GetObject(bmp,sizeof BITMAP,&_bmp);
  14.     HDC hdcScr=GetDC(NULL);
  15.     HDC    hdcMem=CreateCompatibleDC(hdcScr);
  16.     SelectObject(hdcMem,bmp);
  17.     // Create an Atil::Image.
  18.     // The AcDbRasterImageDef::setImage requires it
  19.     Atil::ImagePixel initialImage;
  20.     initialImage.setToZero();
  21.     initialImage.type = Atil::DataModelAttributes::kRgba;
  22.     initialImage.value.rgba = 0xff000000;
  23.     Atil::Size size(_bmp.bmWidth, _bmp.bmHeight);
  24.     const Atil::RgbModel *pDm = new Atil::RgbModel(
  25.         Atil::RgbModelAttributes::k4Channels,
  26.         Atil::DataModelAttributes::kBlueGreenRedAlpha);
  27.     Atil::Image *pAtilImage = new Atil::Image(
  28.                                      size, pDm, initialImage);
  29.     // Write the image data on to the Atil image
  30.     // using an Image Context
  31.     Atil::Offset upperLeft(0,0);
  32.     Atil::ImageContext *pImgContext
  33.         = pAtilImage->createContext(
  34.                                     Atil::ImageContext::kWrite,
  35.                                     size,
  36.                                     upperLeft
  37.                                     );
  38.     if (pImgContext != NULL)
  39.     {
  40.         for (int xf=0;xf<_bmp.bmWidth;xf++)
  41.         {
  42.             for (int yf=0;yf<_bmp.bmHeight;yf++)
  43.             {
  44.                 BYTE alpha=0x0;
  45.                 COLORREF pix=GetPixel(hdcMem,xf,yf);
  46.                 BYTE rr = (pix&0xff);
  47.                 BYTE gg = (pix>>8)&0xff;
  48.                 BYTE bb = (pix>>16)&0xff;
  49.                 // Alpha channel to account for transparency
  50.                 if ((rr!=0xff) || (gg!=0xff) || (bb!=0xff))
  51.                     alpha=0xff;
  52.                 Atil::RgbColor p;
  53.                 p.set(rr, gg, bb, alpha);
  54.                 pImgContext->put32(xf, yf, p);
  55.             }
  56.         }
  57.     }
  58.     pImgContext->flush();
  59.     delete pImgContext;
  60.     bool isImageValid = pAtilImage->isValid();
  61.     ASSERT(isImageValid);
  62.     // Create a RasterImageDef and set the image
  63.     // from the Atil image
  64.     AcDbRasterImageDef *pImageDef = new AcDbRasterImageDef();
  65.     Acad::ErrorStatus es = pImageDef->setImage(
  66.                                             pAtilImage, NULL);
  67.     // Insert the RasterImageDef and create a RasterImage
  68.     // using it
  69.     es = InsertImageInDwg(pImageDef);
  70.     if(es != Acad::eOk)
  71.     {
  72.         delete pImageDef;
  73.         return;
  74.     }
  75.     // Cleanup
  76.     DeleteDC(hdcMem);
  77.     ReleaseDC(NULL,hdcScr);
  78.     DeleteObject( bmp);
  79. }
[it618postdisplay>0]
  1. static Acad::ErrorStatus InsertImageInDwg(
  2.                                 AcDbRasterImageDef *pImageDef)
  3. {
  4.     Acad::ErrorStatus es;
  5.     if(! pImageDef->isLoaded())
  6.     {
  7.         es = pImageDef->load();
  8.         if(es != Acad::eOk)
  9.             return es;
  10.     }
  11.     AcApDocument *pActiveDoc = acDocManager->mdiActiveDocument();
  12.     AcDbDatabase *pDB = pActiveDoc->database();
  13.     // Get the image dictionary
  14.     // Create it if not available already
  15.     AcDbObjectId dictID
  16.                     = AcDbRasterImageDef::imageDictionary(pDB);
  17.     if(dictID == AcDbObjectId::kNull)
  18.     {
  19.         es = AcDbRasterImageDef::createImageDictionary(
  20.                                                   pDB, dictID);
  21.         if(es != Acad::eOk)
  22.             return es;
  23.     }
  24.     AcDbDictionary* pDict;
  25.     es = acdbOpenObject(pDict, dictID, AcDb::kForWrite);
  26.     if(es != Acad::eOk)
  27.             return es;
  28.     ACHAR *DICT_NAME = ACRX_T("ISM_RASTER_IMAGE_DICT_VIEW");
  29.     BOOL bExist = pDict->has(DICT_NAME);
  30.     AcDbObjectId objID = AcDbObjectId::kNull;
  31.     if (!bExist)
  32.     {
  33.         es = pDict->setAt(DICT_NAME, pImageDef, objID);
  34.         if(es != Acad::eOk)
  35.             return es;
  36.     }
  37.     else
  38.     {
  39.         pDict->getAt(DICT_NAME,
  40.                     (AcDbObject*&)pImageDef,
  41.                     AcDb::kForWrite);
  42.         objID = pImageDef->objectId();
  43.     }
  44.     // close Dictionary and Definition.
  45.     pDict->close();
  46.     pImageDef->close();
  47.     // Create a raster image using the RasterImage Def
  48.     AcDbRasterImage* pImage = new AcDbRasterImage;
  49.     es = pImage->setImageDefId(objID);
  50.     if (es != Acad::eOk)
  51.     {
  52.         delete pImage;
  53.         return es;
  54.     }
  55.     // Add the raster image to the model space
  56.     AcDbBlockTable* pBlockTable;
  57.     AcDbBlockTableRecord* pBTRecord;
  58.     es = acdbCurDwg()->getBlockTable(pBlockTable,
  59.                                      AcDb::kForRead);
  60.     assert(es == Acad::eOk);
  61.     es = pBlockTable->getAt(ACDB_MODEL_SPACE,
  62.                             pBTRecord,
  63.                             AcDb::kForWrite);
  64.     assert(es == Acad::eOk);
  65.     es = pBTRecord->appendAcDbEntity(pImage);
  66.     assert(es == Acad::eOk);
  67.     pBTRecord->close();
  68.     pBlockTable->close();
  69.     AcDbObjectId entID = pImage->objectId();
  70.     // Set the transparency options
  71.     pImage->setDisplayOpt(    AcDbRasterImage::kTransparent,
  72.                             Adesk::kTrue);
  73.     pImage->setImageTransparency(true);
  74.     pImage->setDisplayOpt(AcDbRasterImage::kShow, Adesk::kTrue);
  75.     AcDbObjectPointer<AcDbRasterImageDefReactor>
  76.                                         rasterImageDefReactor;
  77.     rasterImageDefReactor.create();
  78.     es = rasterImageDefReactor->setOwnerId(pImage->objectId());
  79.     if (es == Acad::eOk)
  80.     {
  81.         AcDbObjectId defReactorId;
  82.         es = curDoc()->database()->addAcDbObject(
  83.                             defReactorId,
  84.                             rasterImageDefReactor.object());
  85.         if (es == Acad::eOk)
  86.         {
  87.             pImage->setReactorId(defReactorId);
  88.             AcDbObjectPointer<AcDbRasterImageDef> rasterImagedef
  89.                       (pImage->imageDefId(), AcDb::kForWrite);
  90.             if (rasterImagedef.openStatus() == Acad::eOk)
  91.             {
  92.                 rasterImagedef->addPersistentReactor
  93.                                                (defReactorId);
  94.             }
  95.         }
  96.     }
  97.     pImageDef->close();
  98.     pImage->close();
  99. }
[/it618postdisplay]
发表于 2016-9-6 13:51:49 | 显示全部楼层
回复学习
发表于 2016-9-6 17:34:31 | 显示全部楼层
回复学习学习
发表于 2016-9-21 18:11:15 | 显示全部楼层
我出来学习学习,提高水平
发表于 2016-9-21 20:29:01 | 显示全部楼层
谢谢楼主分享
发表于 2016-9-22 16:01:48 | 显示全部楼层
我要学习学习。。。
发表于 2018-2-16 14:01:23 | 显示全部楼层
感谢大佬分享
发表于 2020-2-8 16:03:48 | 显示全部楼层
正好需要看看与c#有何不同
发表于 2020-2-8 19:13:42 | 显示全部楼层
阿里巴巴爸爸妈妈的吻你
发表于 2020-6-15 19:56:44 | 显示全部楼层
学习学习,感谢大神分享
发表于 2020-8-17 11:24:15 | 显示全部楼层
为啥CAD一直不解决这个问题啊
发表于 2020-9-21 23:50:02 | 显示全部楼层
THANK YOU CODE
发表于 2020-12-5 16:44:25 | 显示全部楼层
回复学习
回复学习
发表于 2021-1-4 17:25:07 | 显示全部楼层
谢谢楼主分享
GMT+8, 2026-11-22 09:56 , Processed in 0.392240 second(s), 34 queries , Gzip On, File On.
