查看: 3060|回复: 16
[每日一码] 修改层名的几种方法
发表于 2016-9-8 08:05:00 | 显示全部楼层 |阅读模式
;;VLISP方法[it618postdisplay>0]
  1. ;;VLISP方法
  2. (defun c:tt (/ lay layn layname)
  3.   (if (and
  4.         (setq e (car (entsel "\nSelect an object to change the LayerName: ")))
  5.         (setq layname (cdr (assoc 8 (entget e))))
  6.         (/= (setq newlayname (getstring "\n新的层名<退出>"))
  7.             ""
  8.         )
  9.       )
  10.     (progn
  11.       (vlax-for lay (vla-get-layers (vla-get-activedocument
  12.                                                             (vlax-get-acad-object)
  13.                                     )
  14.                     ) (setq layn (vla-get-name lay))
  15.                 (if (and
  16.                       (wcmatch layn layname)
  17.                       (/= layn "0")
  18.                       (/= layn "Defpoints")
  19.                     )                       ; and
  20.                   (vla-put-name lay newlayname)
  21.                 )                       ; if
  22.       )                                       ; vlax-for
  23.     )                                       ; progn
  24.   )                                       ; if
  25.   (princ)
  26. )
[/it618postdisplay]
  1. ;;; test
  2. ;;命令方法
  3. (defun c:tt (/ layname)
  4.   (if (and
  5.         (setq e (car (entsel "\nSelect an object to change the LayerName: ")))
  6.         (setq layname (cdr (assoc 8 (entget e))))
  7.         (/= layname "0")
  8.         (/= layname "Defpoints")
  9.         (/= (setq newlayname (getstring "\n新的层名<退出>"))
  10.             ""
  11.         )
  12.       )                                       ; and
  13.     (command "._rename" "_Layer" layname newlayname)
  14.   )                                       ; if
  15.   (princ)
  16. )
  17. ;;; test
  18. ;;AUTOLISP 方法
  19. (defun c:tt (/ layname)
  20.   (if (and
  21.         (setq e (car (entsel "\nSelect an object to change the LayerName: ")))
  22.         (setq layname (cdr (assoc 8 (entget e))))
  23.         (/= layname "0")
  24.         (/= layname "Defpoints")
  25.         (/= (setq newlayname (getstring "\n新的层名<退出>"))
  26.             ""
  27.         )
  28.       )                                       ; and
  29.     (progn
  30.       (setq obj (tblobjname "layer" layname)
  31.             ed (entget obj)
  32.       )
  33.       (entmod (subst
  34.                 (cons 2 newlayname)
  35.                 (assoc 2 ed)
  36.                 ed
  37.               )
  38.       )
  39.     )
  40.   )                                       ; if
  41.   (princ)
  42. )
  43. ;;; test
  44. ;;;ARX 方法
  45. (defun c:tt (/ layname)
  46.   (if (and
  47.         (setq e (car (entsel "\nSelect an object to change the LayerName: ")))
  48.         (setq layname (car (xdrx_getpropertyvalue e "layer")))
  49.         (/= layname "0")
  50.         (/= layname "Defpoints")
  51.         (/= (setq newlayname (getstring "\n新的层名<退出>"))
  52.             ""
  53.         )
  54.       )                                       ; and
  55.     (progn
  56.       (xdrx_setpropertyvalue e "layer" newlayname)
  57.     )
  58.   )                                       ; if
  59.   (princ)
  60. )
  61. ;;;ADS 方法
  62. (defun c:tt (/ layname)
  63.   (if (and
  64.         (setq e (car (entsel "\nSelect an object to change the LayerName: ")))
  65.         (setq layname (xdrx_getpropertyvalue e "layer"))
  66.         (/= (car layname) "0")
  67.         (/= (car layname) "Defpoints")
  68.         (/= (setq newlayname (getstring "\n新的层名<退出>"))
  69.             ""
  70.         )
  71.       )                                       ; and
  72.     (progn
  73.       (xdrx_setenttodb (cadr layname))
  74.       (xdrx_modent 2 newlayname)
  75.     )
  76.   )                                       ; if
  77.   (princ)
  78. )
已领礼包: 2965个
财富等级: 家财万贯
发表于 2016-9-8 10:08:07 | 显示全部楼层
回复又学习
发表于 2016-10-10 17:22:05 | 显示全部楼层
回复又学习
已领礼包: 6468个
发表于 2016-10-10 20:46:00 | 显示全部楼层
学习了。
发表于 2016-10-24 23:26:31 | 显示全部楼层
正需要这段代码
已领礼包: 9341个
发表于 2016-10-25 07:46:30 | 显示全部楼层
回帖学习程序。
已领礼包: 290个
发表于 2016-10-25 07:57:39 | 显示全部楼层
学习了!!
已领礼包: 183个
发表于 2016-11-19 13:42:34 | 显示全部楼层
有时候用得到,谢谢
已领礼包: 2671个
财富等级: 家财万贯
发表于 2016-11-19 13:58:52 | 显示全部楼层
nice tool .....
已领礼包: 234个
发表于 2017-3-19 20:15:42 | 显示全部楼层
回帖学习程序
已领礼包: 25个
发表于 2017-3-25 14:59:27 | 显示全部楼层
楼主的贴本人实在受益匪浅啊
发表于 2017-5-15 14:06:00 | 显示全部楼层
回帖学习程序
已领礼包: 216个
发表于 2018-2-8 09:39:47 | 显示全部楼层
必须顶一下
已领礼包: 333个
发表于 2018-2-8 10:38:59 | 显示全部楼层
看看都是怎么做
已领礼包: 138个
发表于 2020-5-4 08:25:10 | 显示全部楼层
修改层名的几种方法
GMT+8, 2026-11-4 03:01 , Processed in 1.151335 second(s), 56 queries , Gzip On.
