查看: 4041|回复: 15
[每日一码] Create Paper Space Viewports
发表于 2016-9-8 08:25:00 | 显示全部楼层 |阅读模式
问题:
如何在图纸空间创建一个新的视口并激活它?我希望用户指定一个矩形(就像MVIEW命令那样)和一个已知的VIEW名字,然后创建一个新的视口。
回答:
要在图纸空间创建一个新的视口,要完成几个步骤:
1、创建一个AcDbViewPort 类对象
2、设置VIEW的坐标(使用 setWidth(), setHeight() and setCenterPoint())
3、把新的视口添加到图纸空间
4、获得用户指定的VIEW(AcDbViewTableRecord对象)
5、使用acdbSetCurrentView() 设置这个AcDbViewTableRecord 对象到新的视口
6、使用AcDbViewport::setOn() 设置为活动视口。
注意:AcDbViewport::setOn() 方法只有在命令注册标记不为ACRX_CMD_TRANSPARENT时候才能使用。如果标记设置了,AcDbViewport::setOn() 返回eCommandWasInProgress,并且直到tilemode系统变量设置到0时候才能激活视口。
Question
How can I create a new viewport in paper space and activate it? I want to let
the user specify a rectangle (like the MVIEW command) and an existing view name.
With this data I want to create a new viewport.
Answer
To create a new viewport in paper space, perform the following steps:
1. Create a new object of type AcDbViewport.
2. Set the view coordinates (with setWidth(), setHeight() and setCenterPoint()).
3. Append the new viewport to the paper space.
4. Get the view the user specified (AcDbViewTableRecord).
5. Set this view on the new viewport with acdbSetCurrentView().
6. Activate the viewport with AcDbViewport::setOn().
NOTE: The AcDbViewport::setOn() function only works if your command has been
registered without the ACRX_CMD_TRANSPARENT flag. If this flag is set,
AcDbViewport::setOn() returns with eCommandWasInProgress and you cannot activate
the viewport until you set tilemode to 1 and back to 0.
The following code demonstrates how to do this:
下面是示例代码:
[it618postdisplay>0]
[sell=5]
  1. void fCreateViewPort()
  2. {
  3.   // Only works in paperspace
  4.   AcDbObjectId mCurViewportId = acedGetCurViewportObjectId();
  5.   if (mCurViewportId == AcDbObjectId::kNull)
  6.   {
  7.     acutPrintf("\nCommand only works in paperspace.");
  8.     return;
  9.   }
  10.   AcDbViewport *pCurViewport;
  11.   if (Acad::eOk != acdbOpenObject(pCurViewport,mCurViewportId,AcDb::kForRead))
  12.   {
  13.     acutPrintf("\nCannot get active viewport.");
  14.     return;
  15.   }
  16.   if (pCurViewport->number() != 1)
  17.   {
  18.     acutPrintf("\nCommand only works in paperspace.");
  19.     pCurViewport->close();
  20.     return;
  21.   }
  22.   pCurViewport->close();
  23.   // Ask for the position
  24.   ads_point pt1,pt2;
  25.   if (RTNORM != acedGetPoint(NULL, "\nSelect first corner: ", pt1))
  26.     return;
  27.   if (RTNORM != acedGetCorner(pt1, "\nSelect second corner: ", pt2))
  28.     return;
  29.   // Ask for the view to use
  30.   char mViewName[133];
  31.   if (RTNORM != acedGetString(0, "\nEnter name of view to use: ", mViewName))
  32.     return;
  33.   // Create new viewport
  34.   AcDbViewport *pViewport = new AcDbViewport;
  35.   pViewport->setWidth(fabs(pt2[X] - pt1[X]));
  36.   pViewport->setHeight(fabs(pt2[Y] - pt1[Y]));
  37.   pViewport->setCenterPoint(AcGePoint3d(pt1[X] + (pt2[X] - pt1[X]) / 2,
  38.       pt1[Y] + (pt2[Y] - pt1[Y]) / 2,
  39.       pt1[Z]));
  40.   // Append new viewport to paper space
  41.   AcDbBlockTable *pTable;
  42.   AcDbBlockTableRecord *pPsBTR;
  43.   if (Acad::eOk != acdbHostApplicationServices()->workingDatabase()->getBlockTable(pTable, AcDb::kForRead))
  44.   {
  45.     acutPrintf("\nCannot get block table.");
  46.     delete pViewport;
  47.     return;
  48.   }
  49.   if (Acad::eOk != pTable->getAt(ACDB_PAPER_SPACE, pPsBTR, AcDb::kForWrite))
  50.   {
  51.     acutPrintf("\nCannot access paper space.");
  52.     pTable->close();
  53.     delete pViewport;
  54.     return;
  55.   }
  56.   pTable->close();
  57.   AcDbObjectId mViewPortId;
  58.   if (Acad::eOk != pPsBTR->appendAcDbEntity(mViewPortId, pViewport))
  59.   {
  60.     acutPrintf("\nCannot append viewport to paper space.");
  61.     pPsBTR->close();
  62.     delete pViewport;
  63.     return;
  64.   }
  65.   pPsBTR->close();
  66.   pViewport->setOn();
  67.   // Set the view
  68.   AcDbViewTable *pViewTable;
  69.   AcDbViewTableRecord *pViewTR;
  70.   if (Acad::eOk != acdbHostApplicationServices()->workingDatabase()->getViewTable(pViewTable, AcDb::kForRead))
  71.   {
  72.     acutPrintf("\nCannot get view table.");
  73.     pViewport->close();
  74.     return;
  75.   }
  76.   if (Acad::eOk != pViewTable->getAt(mViewName, pViewTR, AcDb::kForRead))
  77.   {
  78.     acutPrintf("\nCannot access view '%s'.", mViewName);
  79.     pViewport->close();
  80.     pViewTable->close();
  81.     return;
  82.   }
  83.   pViewTable->close();
  84.   if (acedSetCurrentView(pViewTR, pViewport)!=Acad::eOk)
  85.    acutPrintf("\nFailed to set view");
  86.   // Close the objects
  87.   pViewTR->close();
  88.   pViewport->close();
  89. }
[/sell]
[/it618postdisplay]
发表于 2016-9-8 09:39:26 | 显示全部楼层
学习学习学习
发表于 2016-9-21 18:09:25 | 显示全部楼层
我也来学习学习,提高水平
发表于 2017-8-24 14:03:07 | 显示全部楼层
我也来学习学习是怎么回事
发表于 2017-9-9 21:52:29 | 显示全部楼层
学习!!!!!!!!!!!!!!
发表于 2017-9-11 12:57:44 | 显示全部楼层
697613061697613061697613061697613061
发表于 2020-4-13 04:21:33 | 显示全部楼层
学习学习
发表于 2020-4-13 04:21:36 | 显示全部楼层
学习学习
发表于 2020-4-16 09:01:11 | 显示全部楼层
谢谢大佬分享
发表于 2020-4-16 09:09:07 | 显示全部楼层
谢谢大佬分享,正式我需要的
发表于 2020-4-25 16:19:57 | 显示全部楼层
谢谢分享!学习学习
发表于 2020-4-25 16:21:10 | 显示全部楼层
谢谢分享!学习学习
发表于 2020-6-9 08:15:29 | 显示全部楼层
我也来学习学习是怎么回事
发表于 2020-8-13 15:43:24 | 显示全部楼层
学习学习学习
发表于 2020-9-22 16:16:01 | 显示全部楼层
thank you sharing
GMT+8, 2026-11-22 09:53 , Processed in 0.347965 second(s), 36 queries , Gzip On, File On.
